Centerforce Clutches Investigation into the JK Throw Out Bearing Noise - JeepForum.com
 1Likes
  • 1 Post By Wood1
post #1 of 10 Old 09-21-2017, 03:33 PM Thread Starter
Centerforce
Vendor
Centerforce's Avatar
Centerforce Clutches Investigation into the JK Throw-Out Bearing Noise
At Centerforce we have received multiple calls in relation to a throw-out bearing ticking/squeaking noise. Through our investigation, we discovered there is a known inherent problem with 2006Ė2017 Jeeps. This includes factory-installed components, replaced O.E. components and part from other Jeep clutch manufacturers. JK and TJ owners have reported this problem and are looking to us at Centerforce to help find a cure.
We have reviewed our engineering and components to ensure they are the highest quality available and not causing this issue. With the help of some Jeep owners we have tested multiple areas; unfortunately, testing had mixed results with cases of the problem going away and in some cases returning immediately or many months later.
This bearing noise continues to plague JK and TJ Jeep owners. We have reviewed a few different Jeeps and have not been able to reproduce the noise in house. Currently we are looking for anyone experiencing this problem with a factory-installed clutch, Centerforce clutch or other manufacturer's clutch that would be able to bring their Jeep to our facility
in Prescott, Arizona where we have the equipment required to help find a resolution to this problem.
We want to fix this issue not only for Centerforce customers but for anyone experiencing this issue.
There are two issues that seem that seem to arise:
1. A ticking or skidding noise when the pedal is up.
2. A creaking or squeaking noise while the pedal is being depressed or released.
The YouTube video from Emer Grali below is a great example of the noise.
https://youtu.be/OaBAGGpn5mc
There are multiple examples of this problem on YouTube and on other Jeep forums. Although Centerforce is not the cause of the problem we are working to find a resolution for everyone. Here are some forum links we used as resources:
http://www.jeepforum.com/forum/f96/lets-fix- jk-throw- out-bearing- issue-867949/
http://www.wranglerforum.com/f210/new-tj- clutch-making- noise-throw- out-bearing- 1402690.html
http://www.jkowners.com/forum/stock-jk- tech-dept/14128- throw-out- bearing-noise.html
For more information please contact our technical service department at 928-771- 8422.
Centerforce Clutches Div. of Midway Industries, Inc.
Centerforce is offline
post #2 of 10 Old 09-22-2017, 06:42 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
You guys rock. Something to look at - I had a Spicer box in a ford truck that ate the oem TO by 33k miles then new only lasted 5-8 - after four fails we discovered the drivers side location dowel in the 530 block was low by about .0065". Surprised us as we had seen other assemblies off that far with no problems. .005 Offset dowel and it lived 75k miles (and was still running when I left the company).
jwmbishop is offline
post #3 of 10 Old 09-22-2017, 06:52 PM
mrcarcrazy
Well color me impressed. Next time I need a clutch in any vehicle Iíll take a second look for your offerings based on this post alone.
FWIW, ACT can suck a fat wet noodle from the interactions Iíve had with them on two separate cars over 15years ago. I will never run their clutches again and I take any opportunity to let people know how much I hate them.
Props to you on taking a proactive approach on this, I bet youíll get an Arizona dweller or 3 to come out.
Sent from my iPhone using Tapatalk
Current Jeep:
99 Sahara.
mrcarcrazy is offline
post #4 of 10 Old 09-22-2017, 06:59 PM
Wood1
This is one of the reasons I buy centerforce clutches. Excellent products.
Centerforce likes this.
Wood1 is offline
post #5 of 10 Old 09-22-2017, 11:32 PM
motoguy1251
Im on my 2nd right now in 100k. And it is failing as we speak. Please hurry.
motoguy1251 is offline
post #6 of 10 Old 09-24-2017, 11:08 AM
63expert
I bought my 2012 JKR with 18,000 miles on it in March. After a trail ride with lots of clutch action the TOB started making noise at about 22,500 miles. After driving a while now the bearing will intermittently make the noise with the pedal out, or squeak/creak during the pedal stroke.
I sure hope you guys find a solution for this issue.
63expert is offline
post #7 of 10 Old 09-25-2017, 08:55 AM
MacK
2015 JK Wrangler
I've been hearing this on my 2015:
Is that the same sound? It's been bugging me.
I don't want your d**n lemons! What the hell are these?! Demand to see life's manager! Make life rue the day it thought it could give Cave Johnson lemons! Do you know who I am? I'm the man who's gonna burn your house down! WITH THE LEMONS! I'm gonna get my engineers to invent a combustible lemon that BURNS YOUR HOUSE DOWN!
Mango Tango 2010 JK Wrangler Rubicon
Silver 2000 TJ Wrangler Sport
The 2008 Jeep Wrangler is not so much an SUV as it is an experience. It's slow and loud, handles poorly, has crummy interior materials and features doors that provide virtually no crash protection. But when it comes to off-road performance, the Wrangler is simply the best choice available.
MacK is online now
post #8 of 10 Old 09-25-2017, 07:13 PM Thread Starter
Centerforce
Vendor
Thank you, everyone, for the positive feedback! We feel that it is our duty to step up and correct this inherent issue, especially when the manufacturer is not making it a priority.
Originally Posted by MacK View Post
I've been hearing this on my 2015: https://www.youtube.com/watch?v=D1tE...ature=youtu.be
If either of you are located near us and interested, please drop us a PM or call at (928) 771-8422!
post #9 of 10 Old 09-27-2017, 11:10 AM
MacK
2015 JK Wrangler
I totally would, but I'm around 2300 miles away
MacK is online now
post #10 of 10 Old 09-28-2017, 04:35 AM
weaverkb
I would love to bring my 2013 JKU out there because it has the TO noise going on. It's a long haul from central Florida though.
weaverkb is offline
