CB Install - coming up. - JeepForum.com
post #1 of 5 Old 01-10-2012, 11:48 AM Thread Starter
discordian
This kit:
http://www.rightchannelradios.com/je...510xl-418.html
is scheduled to be delivered tomorrow. I opted for the JK tire-mount for the antenna (all the way on the right of the above picture) and the 4' Wilson Flex antenna.
Even though it's a different brand, I'm planning on basically following the Project JK writeup of installation. I like the way they route everything out of the way and pictures are always helpful. Knock on wood, I should be doing this after my club meeting (Midsouth Jeeps) this coming Saturday. Will try to take a few pictures along the way.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty."
~~Thomas Jefferson
discordian is offline
post #2 of 5 Old 08-08-2012, 07:10 PM
labbayk
heya! did you ever have a chance to take those pics and set your radio up? I ordered the RCR kit a few months after you and I still haven't set it up because I was weighing options. I wanted to do the license plate set up but I think I'm stuck with the spare carrier. Also, the 12 JK's have redesigned dashes so I was wondering what options were out there.
and when you wanted me i came to you
and when you wanted someone else i withdrew
and when you asked for light i set myself on fire
and when you wanted blood i cut my veins
and when you wanted love i bled myself again
then a vision came to me
when you came along
i gave you everything but then you wanted more
I am a slave to grunge \m/
labbayk is offline
post #3 of 5 Old 08-08-2012, 07:30 PM
TheBoss
Click image for larger version
If you use the spare tire carrier you may need to run a ground wire to the chassis . The rear door doesn't lend itself to being a good ground. As far as mounting the cb itself I used a mount from Arizona rockyroad it mounts above the windshield using the sportbar.
TheBoss is offline
post #4 of 5 Old 08-08-2012, 07:39 PM
labbayk
this looks very nice! thanks for the suggestion I have an idea what I can do now with this dusty kit.
when you came along
labbayk is offline
post #5 of 5 Old 08-08-2012, 08:08 PM
Rooster76
That's a good write-up I used it too.
I'm liking my footman loop no drill mount. I did a quick write-up on it here-> http://www.jk-forum.com/jk-cb-ham-ra...8/#post3011242
I would recommend taking your antenna wire up the rollbar. It will work out way better then the floor.
Another tip is to put some hairspray in the antenna cap after you adjust the SWR. That should keep it nice and tight. It's how you install mountain bike grips.
I was thinking that the mic wire would annoy me with it mounted up there. I put it on top of the radio when I'm not using it and you can clip the mic in and it will stay out of the way.
Good Luck
2012 JKR 2DR 6-Speed
Rooster76 is offline
cb , jk
Rattling coming from bell housing area and 33" install. Part203!!! GETTEMTJ TJ Wrangler Technical Forum 1 08-12-2010 03:27 AM
R/C lift Install--Before and....Afters coming this weekend! nismosis JK Wrangler Technical Forum 12 08-01-2010 06:53 PM
clanking coming coming hood area sifuentesjeeps YJ Wrangler Technical Forum 10 06-03-2010 06:49 PM
lift and tire install coming soon...have a gearing question rwmjeepjk JK Wrangler Technical Forum 6 01-07-2008 05:56 PM
Rev111 Install write-up coming soon! OrangeLJ TJ Wrangler Technical Forum 23 09-15-2007 11:41 AM
