Capabilities of a stock four door Rubicon? - JeepForum.com
post #1 of 20 Old 08-19-2013, 08:35 PM Thread Starter
jenniferjeep
2010 JK Wrangler
Just got my 2010 four door Rubicon. Yes! I waited for this for years! Step up from my 88 YJ. What are the stock capabilities of this vehicle?
jenniferjeep is offline
post #2 of 20 Old 08-19-2013, 08:39 PM
AlbertaJeeper
Incredible badass-ness ! Only real disadvantage is the breakover, but even that isn't very often
AlbertaJeeper is offline
post #3 of 20 Old 08-19-2013, 08:40 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Quite capable. The first three runs I made on the Rubicon trail was a heavy modded TJ, When I ran it with a stock JKURubi - I quickly learned tj has a better breakover and JK has better stability but does require a bit more steering work (does not turn as fast) and well a lot more skinny pedal (gotta be turning 1800 to feel like the old 4.0 did at 1300).
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #4 of 20 Old 08-19-2013, 08:43 PM Thread Starter
jenniferjeep
2010 JK Wrangler
What is breakover? I have never heard of this term.
post #5 of 20 Old 08-19-2013, 09:12 PM
aznjeep
aznjeep's Avatar
2014 WK
Breakover is the angle/clearance after the front tires clear an apex, or back tires if going in reverse. Or: http://adventure.howstuffworks.com/o...f-roading1.htm
-Ken
'96 XJ Sport
'14 WK2 Overland EcoDiesel
'13 JKUR 10A (sold)
'10 JKUR (sold)
'99 TJ (sold)
aznjeep is offline
post #6 of 20 Old 08-19-2013, 09:13 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Google breakover angle.....it is the maximum angle between front and rear tires at the frame...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #7 of 20 Old 08-20-2013, 08:09 AM
JIMBOX
A lotta differences between the 2dr/4dr
The 4dr can't
1)-turn as sharp
2)-go between the same trees
The 4dr has
1)-more cargo area
2)-more stability on hill climbs/rocks/freeway
3)-better towing capability
4)-better people access
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #8 of 20 Old 08-20-2013, 08:41 AM
bogleparsons
The 4dr can't
1)-turn as sharp
The 4dr has
1)-more cargo area
JIMBO
But the 2DR has
1. Looks like a Jeep not a Hummer
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #9 of 20 Old 08-20-2013, 09:31 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
Let us know - and show pics!
JeepCares is online now
post #10 of 20 Old 08-20-2013, 09:32 AM
BadHammers
Originally Posted by bogleparsons View Post
But the 2DR has
Easy fix: Remove the top and doors.
Simon Alexander
'14 WK2 Overland
'13 JKU Rubicon
Jeeps past 01 XJ, 08 JK, 11 KK
BadHammers is offline
post #11 of 20 Old 08-20-2013, 10:53 AM
bogleparsons
Amen!
post #12 of 20 Old 08-20-2013, 11:07 AM
BlkOpsRubi
BlkOpsRubi's Avatar
2011 JK Wrangler
But the 2DR has
This is almost worthy of becoming a signature quote!
BlkOpsRubi is offline
post #13 of 20 Old 08-20-2013, 11:24 AM
AndyE
But the 2DR has
Build Thread
AndyE is offline
post #14 of 20 Old 08-20-2013, 04:32 PM
Spank
2014 JK Wrangler
I did a "difficult" trail in my JKUR a couple weeks after I bought it and although I managed to dent the skidplate and tear off my SS, it handled it just fine. I should've looked up the trail before going on it, but it survived. They're extremely capable stock as are the Sahara and Sport models.
'14 Wrangler Unlimited Rubicon
Spank is offline
post #15 of 20 Old 08-20-2013, 05:24 PM
bbolander
Rubicon's are incredibly capable with their lower range transfer case and lockers, heavier duty components and quick-release sway bar. Things that need to be added to a non-Rubicon. As in any Jeep though, you might need a lift or larger tires or both to get more ground clearance depending on the type of trails and obstacles you want to do.
2012 Rubicon Unlimited Freedom Top, Mopar rock rails, Marathon seat covers, 2" Mopar lift, Mopar Sunbonnet, Bestop Duster. Prior 2006 Rubicon Unlimited modified, 98 Cherokee Classic, Three Early Broncos
bbolander is offline
