cant believe lifts are out already.. - JeepForum.com
post #1 of 6 Old 09-18-2006, 07:50 AM Thread Starter
paroxysym
2007 WK
just went on northride 4x4 and saw that they have a jk section up already with a 3" and 2" lift already for it. the 3" from full traction says you could run 35's with the kit. also they have trackbars, and bumpers out for it already. may sway me to buy one..
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #2 of 6 Old 09-18-2006, 07:56 AM
wrnglrguy
wrnglrguy's Avatar
Probably less lift for bigger tires because the JK's already come with bigger stock tires/rims than any Wrangler beofre it, ie., already has set up for bigger tires to begin with. That's kinda cool if you think about it. You can put a slightly smaller lift on it but run bigger tires than older Wrangler models. Money saver? Sounds like it .
wrnglrguy is offline
post #3 of 6 Old 09-18-2006, 12:45 PM
Dan-O
What they don't mention is if you need additional hardware. With the old Wranglers if you put a lift on, longer brake lines, CVs, SYE, trackbars, regearing, etc., were recommended or needed depending on the height of the lift. I would think going from say the stock tires of an X (30s), to 35s, would acquire additional hardware. Who's going to have the first death wobble thread, lol.
Dan-O is offline
post #4 of 6 Old 09-18-2006, 12:53 PM
Karamba
If it fits 32" stock, 35" should be about 2" of lift, and even some IFS on Toyota handles 2.5" without CV problems.
I would be REALLY surprised if 2.5" requires driveline modifications - in particular on the LWB Unlimited.
Karamba is offline
post #5 of 6 Old 09-18-2006, 01:01 PM
Sweeney
... and remember, the JK already has CV drive shafts and a fixed yoke transfercase along with significantly longer control arms which will allow for more lift with less change in axle position.
Sweeney is offline
post #6 of 6 Old 09-19-2006, 07:15 PM
35sUnlimited
35sUnlimited's Avatar
Why haven't we seen a lifted one with 35's yet? Come on you new JK owners get to work!!!!
I CAN'T WAIT to see one!!!!!
Tyler
04 LJ Pics:
Half top write-up:
Painted Ravines write-up:
35sUnlimited is offline
What is the best.... (suspension lifts and body lifts) RjAndJeep TJ Wrangler Technical Forum 24 06-03-2009 08:33 PM
A run down on suspension lifts.body lifts.spacers mightydog78 TJ Wrangler Technical Forum 5 02-27-2009 11:21 PM
Body lifts/Suspension lifts OffRoadin'Lover TJ Wrangler Technical Forum 4 11-18-2006 01:57 PM
Questions on lifts and body lifts WrangBlake TJ Wrangler Technical Forum 3 10-06-2006 01:46 PM
Lifts Lifts Lifts! bulldawg747 TJ Wrangler Technical Forum 1 05-12-2004 10:49 PM
