Can you give me some feed back on my current mod plan? - Page 3 - JeepForum.com
post #31 of 52 Old 04-23-2010, 02:52 PM
ncb
Just my personal oppinion, but I wouldn't go higher than an D rated tire. E will be stiffer and heavier.
ncb is online now
post #32 of 52 Old 04-23-2010, 06:35 PM
juiceparn
Two schools of thought on the load range. I much prefer C rated tires because my Jeep only weighs just over 4000 lbs. Run what you like but I feel like I get the benefit of airing down with more air in my tires with the "c" tire. I also don't wheel where rocks rip up tires so I can't speak to the wear or durability when compared to an E rated tire.
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #33 of 52 Old 04-23-2010, 11:19 PM Thread Starter
lotus03
2009 JK Wrangler
emailed Nitto to ask them if they could help me on which Trail Grappler could work with my 17" x 7.5" stock wheels and 3.5" lift
i think the tire i was looking at might be too wide even with spacers - i might be screwed on plan to use the stock wheels - already found painter i was gonna use.....
lotus03 is offline
post #34 of 52 Old 04-23-2010, 11:20 PM Thread Starter
lotus03
2009 JK Wrangler
What if you end up making the Jeep heavier by adding bumper and winch etc?
lotus03 is offline
post #35 of 52 Old 04-24-2010, 05:07 AM Thread Starter
lotus03
2009 JK Wrangler
My "living" first phase mod plan updated (sleep deprived & slightly hungover)
stock 2009 2 door JK (s package) deepwater blue with 6000 miles.
1) EVO Enforcer 2.5 (w/ 2.5" Diameter EVO SPEC King Remote Reservoir Shocks)(this is 3.5" lift)
a) EVO Plush Coils combined with EVO SPEC 2.5" with Reservoir Shocks
b) Front Adjustable Lower Control Arms
c) Rear Roll Center correction trackbar bracket
d) Brake line Extensions
e) Front and Rear Bump stop Extension
2) Wheels:
Mickey Thompson SideBiterฎ Alloy Wheel - Bolt Pattern 5x5 Size 17x9 Backspacing 4.5
or Mickey Thompson Signature Series Classic II Alloy Wheel in Satin Black - Bolt Pattern 5x5 Size 17x9 Backspacing 4.5
or Mickey Thompson Signature Series Classic II Alloy Wheel in Satin Black - Bolt Pattern 5x5 Size 18x9 Backspacing 5
3) Tires:
Mickey Thompson Baja MTZ Radial - 5275 - LT315/70R17 - 35X12.50R17 - OWL 121Q 68 D 3,195 50 8.5-10.0 9.5 11.9 9.8 34.6 19
or Mickey Thompson Baja MTZ Radial - 5290 - LT305/70R18 - 35X12.50R18 - OWL 126Q - 71 E 3,750 65 8.0-10.0 9 12.2 9.8 35.1 20.5
or Nitto trail grappler - 35x12.50R17 - LT E 121Q 205-730 21.0 34.84 13.19 8.5-(10.0)-11.0 3195@65 596
or Nitto trail grappler - 35x12.50R18 - LT E 123Q 205-700 21.0 35.04 13.39 8.5-(10.0)-11.0 3415@65 592
4) MBRP exhaust S5518 Black off road tail pipe, muffler before axle
5) re-gear from 3.73 to 5.13 – purchase Front and Rear Gears & Overhaul Kit Package
6) JKS rear upper control arms
7) JKS adjustable trackbars Front
8) JKS Rear Trackbar Brace
9) Tom Woods 1310 front & rear drive shafts (considering)
ouch.....
Rock On!
lotus03 is offline
post #36 of 52 Old 04-25-2010, 09:19 AM Thread Starter
lotus03
2009 JK Wrangler
thought of the day:
should i buy 17 inch wheels or should i buy 18's with my 3.5" lift
http://www.youtube.com/watch?v=95qZtwJNjxk
lotus03 is offline
post #37 of 52 Old 04-25-2010, 12:27 PM Thread Starter
lotus03
2009 JK Wrangler
In all of your mods I did not see any mention for Skid Plates / armor. I'd make ROCK Rails #1 before anything else including tires. Only cost $200 - $700 and will save you several thousand in Body damage. Mine have taken several hard hits and so far still look almost new.
It only takes getting stuck on a (rock, tree stump, high centered on hard dirt etc) ONCE to seriously funk up your body and ruin your day, week, month.
thanks a lot
lotus03 is offline
post #38 of 52 Old 04-26-2010, 12:40 PM Thread Starter
lotus03
2009 JK Wrangler
Originally Posted by N2rock View Post
Just pointing out (and you may have already noticed)- the first tire size you listed is for an 18" wheel. The 2nd size is for a 17" wheel. The wheel you listed in #1 is a 17".
35" with 5.13 gears, automatic, is what I'm running now. I originally had 4.10 gears- it wasn't horrible. And I waited a full year before re-gearing. But now that I am re-geared, I recommend it.
N2rock, when you made the decision to re-gear you knew you would be giving up your warranty cliams. Was that a difficult decision for you?
lotus03 is offline
post #39 of 52 Old 04-26-2010, 01:21 PM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
Originally Posted by lotus03 View Post
thought of the day:
what wheels do you have now? if you dont want to spend extra you can keep the stock 16" wheels. no problem with that
i would not get an 18" wheel. less tire choices and tires are more expensive. if you want new wheels 17" are a great wheel size. though 17" tires are a little bit more expensive than 16" wheels.
you dont have to worry about tire width and wheel width too much. i have 17x8.5 wheels and run 14.50" wide tires. i had 4.5" backspacing with no rub issues. though i had to change that to 3.5" when i had the rear coil-overs installed. you will be fine with a 17x9" wheel (4.5" BS) and 12.50" wide tires
im surprised you are going with evo and jks. why not get a complete kit like a Rock Krawler lift. i recommend any of their products. warranty is great, parts are beefy, smooth on highways and lots of flex off road. they really stand behind their products too. plus using one kit ensures everything works seamlessly together
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" • '07 Jeep JK • 426 HEMI 685 HP & 650 ft lbs
• Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #40 of 52 Old 04-26-2010, 01:26 PM
juiceparn
I think I'd have to add more than any bumper/winch/armor combination out there to make enough difference to make me wanna higher load rating. I was at a rock crawling event last weekend and most all of the buggies had C tires. When aired down they hold a bead much better and I only have to air down to about 15 PSI to get some great bulging. My wheeling buddy used D rated BFG's and he's at 10 PSI and his sidewalls hardly give at all. (he is in a heavily armored YJ)
post #41 of 52 Old 04-26-2010, 01:30 PM Thread Starter
lotus03
2009 JK Wrangler
thanks... my stock wheels are 17" and i'll probably by the mt sidebiters 17's. I'll check out rock krawler again but I like the company EVO and read a lot about King shocks. I'd love to have king shocks on my ride.
lotus03 is offline
post #42 of 52 Old 04-26-2010, 01:35 PM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
RK lifts can use Bilstien, King, or Walker Evans shocks.
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #43 of 52 Old 04-26-2010, 01:54 PM Thread Starter
lotus03
2009 JK Wrangler
"Liquor"...LOL....thanks for your comments...juiceparn thanks also...probably get the c's or maybe D. I think the mickey thompsons are D and is best i can do.
lotus03 is offline
post #44 of 52 Old 04-26-2010, 01:58 PM Thread Starter
lotus03
2009 JK Wrangler
you are saying that you dont like he concept of using different parts from different vendors and assembling it - that going with one company is definitely better? why not cherry pick and make it the way you want??
lotus03 is offline
post #45 of 52 Old 04-26-2010, 07:29 PM Thread Starter
lotus03
2009 JK Wrangler
i wonder if a basic teraflex leveling kit (gives u 2 inch lift in front and 1 in rear), 33" tires, 17" MT sidebiters, king shocks front and rear would be a great starting point? this would eliminate warranty issues and would be considered a safer ride
lotus03 is offline
Feed Back Please on Pro Comp Tires 33x12.50 ROADDOG516 YJ Wrangler Technical Forum 2 09-12-2009 11:58 PM
Feed back on Long Arm kits jayburd8 JK Wrangler Technical Forum 6 02-03-2009 05:17 PM
Crazy Lifts I want one and need feed back XJ Rocker TJ Wrangler Technical Forum 46 05-03-2008 11:49 AM
I might buy a YJ need feed back 99wjman YJ Wrangler Technical Forum 8 07-04-2006 04:05 AM
Any body done this that has feed back 87YJerryRig YJ Wrangler Technical Forum 4 09-22-2004 11:16 AM
