Can you give me some feed back on my current mod plan? - Page 2 - JeepForum.com
post #16 of 52 Old 04-21-2010, 07:59 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
Originally Posted by lotus03 View Post
Anyone know anything about Fabtech 5 Crawler System?
looks wild
that lift is a lot of money.
I had a friend that ran a fabtech lift on his truck and he hated it (and spent a ton of money on it)
If you want radius arms I would suggest rubicon express. They are tried and true and the price is a little bit easier to swallow.
-Matt
mattman8706 is offline
post #17 of 52 Old 04-21-2010, 08:10 AM
N2rock
N2rock's Avatar
1) Mickey Thompson Sidebiter Wheels - size 17x9 has 4.5 back spacing
2) Mickey Thompson Baja MTZ Radial 5290 - LT305/70R18 - 35X12.50R18 - 12.2 section width - load range E
or Mickey Thompson Baja MTZ Radial 5275 - LT315/70R17 - 35X12.50R17 - 11.9 section width - load range D
Just pointing out (and you may have already noticed)- the first tire size you listed is for an 18" wheel. The 2nd size is for a 17" wheel. The wheel you listed in #1 is a 17".
35" with 5.13 gears, automatic, is what I'm running now. I originally had 4.10 gears- it wasn't horrible. And I waited a full year before re-gearing. But now that I am re-geared, I recommend it.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #18 of 52 Old 04-21-2010, 08:30 AM
juiceparn
Go do some wheeling stock! You never know how well you'll do stock until you try. "wheeling" is a subjective term and means many different things to many different people. You may end up wanting to do more than you think now or if you're like me, you're mod list may shrink once you realize what your Jeep can do already. I wanted to lock both axles and go an inch higher for lift but I haven't needed either for 95% of the wheeling I do. A simple BB and some bigger tires for clearance (especially the 4 door) can take you places older open diff jeeps just couldn't get. The BLD is an amazing feature and can be a great poor man's locker if you learn how to use it. My point is , go find out the weaknesses of YOUR jeep, doing the wheeling YOU do. Like these guys have said over and over buy what you want or need 1 time and do it right.
07 JK 4DR 3.5" Rubicon Express, C gussets, Front XHD stubby, winch, Taboo Customs rear bumper with tire carrier, Taboo Customs Rock sliders.
juiceparn is offline
post #19 of 52 Old 04-21-2010, 11:45 PM Thread Starter
lotus03
2009 JK Wrangler
I've been researching pretty hard and even pulled a couple all nighters. My head is gonna explode...I read that Off Road Evolution is coming out with the EVO Enforcer Suspension System. It's a basic suspension system with 3.5″ of lift. It has King shocks and might be a sweet way to start the process for me. I can do this lift and then put on the 35's and wheels and re gear to 5.13 and I've been reading that with a 3.5 inch lift I'll need a new rear driveshaft also. Naturally have to determine how that MBRP muffler fits in there too. I can picture the Jeep in my head looking all nice and performing well.
lotus03 is offline
post #20 of 52 Old 04-22-2010, 01:35 AM
No_Return
If you are really worried about clearing the Garage door just Move. OK I'm Just Kidding.
Flat Fenders and 33" MT tires and Optional .75" - 1.5" leveling kit up front is starting to become a popular option and if that won't fit under your door WOW it must be under 6'-2".
In all of your mods I did not see any mention for Skid Plates / armor. I'd make ROCK Rails #1 before anything else including tires. Only cost $200 - $700 and will save you several thousand in Body damage. Mine have taken several hard hits and so far still look almost new.
It only takes getting stuck on a (rock, tree stump, high centered on hard dirt etc) ONCE to seriously funk up your body and ruin your day, week, month.
Tires & Wheels Lift Kits ... Listen to N2ROCK and MATTMAN... They have both tried a lot of stuff and have Nice Jeeps.
My Rubicon is mostly Stock for now only because until I break or wear out something I tend not to replace it. Call me a cheepskate.
One does not establish a dictatorship in order to safeguard a revolution; one makes a revolution in order to establish a dictatorship. - Orwell
No_Return is offline
post #21 of 52 Old 04-22-2010, 01:55 AM Thread Starter
lotus03
2009 JK Wrangler
thanks... I appreciate everyones comments
lotus03 is offline
post #22 of 52 Old 04-22-2010, 06:47 AM Thread Starter
lotus03
2009 JK Wrangler
My "living" first phase mod plan updated
for my stock 2009 2 door JK (s package) deepwater blue with 6000 miles.
1) EVO Enforcer Suspension System - this is basic suspension with 3.5 inch lift
2) Mickey Thompson Sidebiter Wheels - size 17x9 has 4.5 back spacing
3) Nitto trail grappler 35x12.50R17LT E 121Q 205-730 21.0 34.84 13.19 8.5-(10.0)-11.0 3195@65 596
4) MBRP exhaust S5518 Black off road tail pipe, muffler before axle
5) re-gear from 3.73 to 5.13 purchase Front and Rear Gears & Overhaul Kit Package
6) install rear drive shaft
Not sure if I need/should get:
A) JKS adjustable trackbars front & rear
B) JKS quick discos Front
C) front & rear lower control arms
Rock On!
lotus03 is offline
post #23 of 52 Old 04-22-2010, 07:41 AM
N2rock
N2rock's Avatar
Comment about the driveshafts. The front driveshaft typically needs replaced before the front. If you think about it, the front is the shorter driveshaft. So as you lift, it is the one that gets the worst angle. Not saying that you won't need to replace the rear, it just won't be as critical as the front. I know guys that have done 3.5" lift and not need to replace the rear.
N2rock is offline
post #24 of 52 Old 04-23-2010, 05:22 AM Thread Starter
lotus03
2009 JK Wrangler
noticed that there isnt a general consensus on the 2dr - one vendor told me that rear drive shaft is recommended
also control arms is all over the map - it may be best just to get all of them and not worry about the debate anymore
lotus03 is offline
post #25 of 52 Old 04-23-2010, 07:33 AM
N2rock
N2rock's Avatar
That would definitely be "doing it right the first time, no questions". If budget is not an issue, I would definitely just do it all at once and never think twice about it.
N2rock is offline
post #26 of 52 Old 04-23-2010, 09:15 AM Thread Starter
lotus03
2009 JK Wrangler
thanks a lot
should I ask my mechanic of choice if they warranty their work - for example the re-gear
lotus03 is offline
post #27 of 52 Old 04-23-2010, 09:44 AM
N2rock
N2rock's Avatar
thanks a lot
Re-gearing. Most shops will only warranty for the length that the gear manufacturer warrants the gears. And the gear manufacturers typically do like 60 or 90 days on the gears. The shops typically won't warranty beyond that because if the gear fails (from a manufacturer defect) beyond that period, then the shop is stuck footing the bill for new gears.
N2rock is offline
post #28 of 52 Old 04-23-2010, 01:41 PM Thread Starter
lotus03
2009 JK Wrangler
1) EVO Enforcer 2.5 (w/ 2.5" Diameter EVO SPEC King Remote Reservoir Shocks)(this is 3.5" lift)
a) EVO Plush Coils combined with EVO SPEC 2.5" with Reservoir Shocks
b) Front Adjustable Lower Control Arms
c) Rear Roll Center correction trackbar bracket
d) Brake line Extensions
e) Front and Rear Bump stop Extension
2) Keep Stock wheels - 17"x7.5" - coat & paint them
5) re-gear from 3.73 to 5.13 – purchase Front and Rear Gears & Overhaul Kit Package
6) JKS rear upper control arms
7) JKS adjustable trackbars Front
8) JKS Rear Trackbar Brace
9) Tom Woods 1310 front & rear drive shafts (considering)
10) Spidertrax spacers (possibly..need to confirm)
Rock On!
lotus03 is offline
post #29 of 52 Old 04-23-2010, 01:43 PM
N2rock
N2rock's Avatar
pretty sweet grocery list there! I would be happy with that
N2rock is offline
post #30 of 52 Old 04-23-2010, 02:09 PM Thread Starter
lotus03
2009 JK Wrangler
thanks man
forgot about spacers cause im gonna use the stock wheels
lotus03 is offline
Feed Back Please on Pro Comp Tires 33x12.50 ROADDOG516 YJ Wrangler Technical Forum 2 09-12-2009 11:58 PM
Feed back on Long Arm kits jayburd8 JK Wrangler Technical Forum 6 02-03-2009 05:17 PM
Crazy Lifts I want one and need feed back XJ Rocker TJ Wrangler Technical Forum 46 05-03-2008 11:49 AM
I might buy a YJ need feed back 99wjman YJ Wrangler Technical Forum 8 07-04-2006 04:05 AM
Any body done this that has feed back 87YJerryRig YJ Wrangler Technical Forum 4 09-22-2004 11:16 AM
