Can you give me some feed back on my current mod plan? - JeepForum.com
post #1 of 52 Old 04-20-2010, 03:53 AM Thread Starter
lotus03
2009 JK Wrangler
Hi, i purchased a 2009 2 door X JK and am ready to do some mods (first ones). I'm really excited about it but dont want to make any silly mistakes. Appreciate any advice you can provide and am really psyched. For the next year I will ride on the beach a few times and some light trail riding but mostly will be putting around on the street. Here's my current plan:
1) Mickey Thompson M/T SideBiter Wheels - I read that for my JK the offset range is supposed to be (mm): 15 to 35 but these wheels on MT website say for 5 on 5 its -12. Not sure if I'll be able to use these wheels?
2) Baja MTZ Radial - 31X10.50R15LT
3) thinking not to do any lift right now but possibly later on. My garage is small and worried about being able to fit in there but will be moving in the next year. I was looking at teraflex & the AVE Nth degree looks really sweet too.
4) Do you think I will need wheel spacers? Do you recommend a size with this set up? I would purchase spidertrax i think and they are also same color as my ride.
5) Gibson Performance Split Rear; Dual Exhaust Kit
6) should i purchase shocks?
7) i will be hiring someone to do this work for me
This is what i am considering right now. Do you recommend anything else or have any comments?
Any feed back would be excellent and much appreciated.
All The Best,
David
lotus03 is offline
post #2 of 52 Old 04-20-2010, 04:31 AM
johnch0512
Hey buddy. With the 31's. You wont need any wheel spacers. That all sounds pretty good. How long until you said you were gonna lift it, because there is no point in my mind to get smaller tires to ride on if you plan on lifting it in the near future.
johnch0512 is offline
post #3 of 52 Old 04-20-2010, 10:49 AM
N2rock
N2rock's Avatar
1) Forget "offset"- you need to look at the back spacing amount. To run a 15" wheel, you are going to need at most 4" back spacing, 3.75" would be preferable. Anything more than 4" will rub the caliper. And even some with 4" back spacing will rub. So best bet is to go 3.75" back spacing, OR move up to a 16" wheel (no guess work involved with 16") and go with 4" or 4.5" back spacing
2) 31" is TINY! Most JK's come stock with 32" tires. Some come with smaller tires. But they look bad with tires that small. Go at least 32". If you plan on lifting, you'll want to go even taller (33" or 35" depending on the amount of lift)
3) Pull your jeep in the garage and park it so the rear wheels are directly under the garage door. Now measure the distance from the roof to the garage door. I'm sure you'll have plenty of space left to lift. Which lift you decide on is going to depend on how tall you want to go. You only need 2.5"-3" of lift to fit 35" tires. 2.5" lifts can be had fairly inexpensive. Figure out your height and budget
4) Forget spacers. Buy the right wheels with the proper back spacing. Stock wheels have 6.25" back spacing. If you lift it, you need to move the wheels outward. Usually 4"-4.5" back spacing will suffice. Only time you need spacers is if you lift it and try to use the stock wheels. But if you're buying wheels anyway, might as well get the right ones to begin with and not worry about spacers.
5) I have no opinions on exhaust. I'll stick with the stock until I tear it off on the trail
6) if you lift, you will need taller shocks. If you don't lift, there is really no reason to bother
7) You can do the work yourself- it's not rocket science That will save you a ton of money
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 52 Old 04-21-2010, 12:57 AM Thread Starter
lotus03
2009 JK Wrangler
John you are right thank you
N2rock thanks a lot man
revised concept:
1) Mickey Thompson Sidebiter Wheels - size 17x9 has 4.5 back spacing
2) Mickey Thompson Baja MTZ Radial 5290 - LT305/70R18 - 35X12.50R18 - 12.2 section width - load range E
or Mickey Thompson Baja MTZ Radial 5275 - LT315/70R17 - 35X12.50R17 - 11.9 section width - load range D
3) AEV / Nth Degree 3.5" Premium Suspension System with Bilstein Shocks
4) Gibson Performance Split Rear; Dual Exhaust Kit
5) regarding my garage issue i measured it: room left from garage door to top of vehicle is about 12 inches. The side of the vehicle has total of about 24 inches combined of room left to make it into the garage (12 inches each side if i enter centered).
6) anything else I should think about or add/revise??
EDIT:
7) MBRP S5518 Black off road tail pipe, muffler before axle OR MBRP Jeep JK Wrangler Performance Exhaust System - T-409 Stainless Steel (Black) OR Gibson Performance Split Rear; Dual Exhaust Kit
8) 5.13 Front and Rear Gears & Overhaul Kit Package
Thanks a lot!
Dave
lotus03 is offline
post #5 of 52 Old 04-21-2010, 01:06 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I was getting ready to type pretty much all of this out but N2rock summed it up very well.
-Matt
mattman8706 is offline
post #6 of 52 Old 04-21-2010, 01:07 AM Thread Starter
lotus03
2009 JK Wrangler
thanks Matt - i was also wondering if 37's would go better with 3.5 inch lift
lotus03 is offline
post #7 of 52 Old 04-21-2010, 01:09 AM
alaskanthunder
Dave
I'd skip that.
You will get sick of the drone at highway speeds. I took mine off and put the stock muff back on.
Many other people have had good results with the MBRP exhaust.
In my opinion, leave the exhaust alone.
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline
post #8 of 52 Old 04-21-2010, 01:16 AM Thread Starter
lotus03
2009 JK Wrangler
I stumbled across this - with 35's I'll have to decide between 4.11 - 4.56 - or 5.13:
34-35" tires
minimum 2.5" BB/3" lift,
will rub at full flex with 2.5BB
trim/remove front air dam
new gears may be needed on automatic transmissions, overdrive not able to be used (possible upgrade to 4.88's or 5.13's but not necessary)
4.10's ok for manual, but 6th gear obsolete.
trim pinch weld at rear tire
36-37" tires
minimum 3.5-4" lift
some trimming may be required on front bumper/fenderwells
new gears 4.88 or 5.13's (4.10s will be insufficient for both manual and auto)
lotus03 is offline
post #9 of 52 Old 04-21-2010, 01:37 AM
BlueTickHound
2010 JK Wrangler
work yourself
I own 3 jeeps and before I got my first one never did any automotive work. Now i do almost everything. At first you won't be fast. Take your time, take breaks, and make it part of the fun.
Also AEV is a great lift.
listen to these guys on the forum. lots of good opinions and even some hard earned wisdom
I had a big mod kit for my rubi but have decided to leave it stock for awhile so I can get the new mod smile on my face in about 6 months.
welcome and enjoy
BlueTickHound is offline
post #10 of 52 Old 04-21-2010, 01:44 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
My advice to you is to spend some time here on the forum.
There are many options to consider and many good examples to review within these pages!
I've proudly owned my JK for a year and a half, I've been on this forum for six months and I just started my mods' last week
You just got here, so why not stick around and when the time is right you'll know exactly what you want! You will have the knowledge to make educated decisions and a new group of friends to help you spend your money, oh I mean share the excitement with!!!
Welcome and do it right the first time
Jim
JLC08JK is offline
post #11 of 52 Old 04-21-2010, 02:24 AM Thread Starter
lotus03
2009 JK Wrangler
ok thanks a lot for all the comments
lotus03 is offline
post #12 of 52 Old 04-21-2010, 03:04 AM
Seanie
34-35" tires
36-37" tires
minimum 3.5-4" lift
I have 4.10's on mine and have no problem, so if you have those and decide to go to 35's, regearing isn't necessary
(depending on what you use it for). I have to turn O/D off when I'm above 50 on the highway when there are hills. But if you have to regear, you might as well do 5.13's.
Don't drink the water, there's blood in the water... DMB
Seanie is offline
post #13 of 52 Old 04-21-2010, 04:08 AM Thread Starter
lotus03
2009 JK Wrangler
Originally Posted by alaskanthunder View Post
I'd skip that.
thanks. yeah if i went with MBRP im not sure of the pro's and con's between these:
1) MBRP S5518 Black off road tail pipe, muffler before axle
2) MBRP Jeep JK Wrangler Performance Exhaust System - T-409 Stainless Steel (Black)
lotus03 is offline
post #14 of 52 Old 04-21-2010, 04:21 AM Thread Starter
lotus03
2009 JK Wrangler
I have 3.73 dana 30 front and dana 44 rear
so if I went with 5.13 I would purchase Front and Rear Gears & Overhaul Kit Package - found one for 500 bucks
my vehicle has 6,000 miles on it but still probably go with overhaul kit as opposed to installation kit.
I think thats all i need to purchase and "just" have to pay someone to do the job. I dont need a new carrier or locker cuz I have 3.73 stock I read.
thanks!
lotus03 is offline
post #15 of 52 Old 04-21-2010, 08:54 AM Thread Starter
lotus03
2009 JK Wrangler
Anyone know anything about Fabtech 5” Crawler System?
looks wild
lotus03 is offline
Feed Back Please on Pro Comp Tires 33x12.50 ROADDOG516 YJ Wrangler Technical Forum 2 09-13-2009 12:58 AM
Feed back on Long Arm kits jayburd8 JK Wrangler Technical Forum 6 02-03-2009 06:17 PM
Crazy Lifts I want one and need feed back XJ Rocker TJ Wrangler Technical Forum 46 05-03-2008 12:49 PM
I might buy a YJ need feed back 99wjman YJ Wrangler Technical Forum 8 07-04-2006 05:05 AM
Any body done this that has feed back 87YJerryRig YJ Wrangler Technical Forum 4 09-22-2004 12:16 PM
