can the stock radio connect to an amp to power a sub? - JeepForum.com
post #1 of 14 Old 09-16-2010, 11:52 PM Thread Starter
mudman1
hi everyone, i'm thinking about getting a sub and an amp..but i want to keep the stock radio. any time in my life that i've had a good car stereo, it got stolen.
so, does the stock radio even have the ability to connect to a an amp with a sub?
thanks
mudman1 is offline
post #2 of 14 Old 09-17-2010, 12:15 AM
KaboomNuggets
2009 JK Wrangler
It sure can. With (what we use to call a step down) don't know the technical name for it you can add a sub and amp to pretty much any radio. Just make sure you get a bass control knob for the amp so you can controll the output of the sub.
KaboomNuggets is offline
post #3 of 14 Old 09-17-2010, 12:21 AM
CHIPMAKER
2010 JK Wrangler
Asuming you dont have a factory sub, you will need an adaptor. Maybe this would work...
Axxess ALOC608 - Line-Out Converters - Sonic Electronix
Also there are many amps that will accept speaker level connections. Some will even turn on when detecting a signal, then you don't need a turn on wire.
2010 Camaro 2SS/RS
1997 Lo Tahoe
2012 Ram Shorty Lo
2013 Honda F6B
CHIPMAKER is offline
post #4 of 14 Old 09-17-2010, 06:59 PM
Unlimited2010
easy to tap into the front speakers with the line out converter, run he amp power wire though the p/s side of the dashboard (will post pics later), mount the amp under the p/s front seat (pleanty of room)!!!!! lock the box and sub to the car seat securing loops in the back. Makes it easy to remove if needed when not locked!!!!!
-R
Unlimited2010 is offline
post #5 of 14 Old 09-17-2010, 07:18 PM
Unlimited2010
Pic of my sub! too dark to take other pics now!
-R
post #6 of 14 Old 09-17-2010, 08:10 PM
LIMETIME
2010 JK Wrangler
I am in the process of doing this now. What % did you adjust the line level converter to?
2010 Surf Blue - Beach Duty
LIMETIME is offline
post #7 of 14 Old 09-18-2010, 10:53 AM
Unlimited2010
you are probably going to set according to your preference. sure it will be different for each onverter, amps, head units.........
per my pics, see where i ran the power wire through. puts it right by the battery.
plenty of room for amp as shown in my pic, too.
-R
post #8 of 14 Old 09-18-2010, 04:20 PM
LIMETIME
2010 JK Wrangler
I set mine up similar to yours, but I was able to hide all of the wiring under the carpet. The side where I made the amp connections is where the center console is, so no wires are visible.
LIMETIME is offline
post #9 of 14 Old 09-18-2010, 07:44 PM
allibaster
-R
What converter did you use?
'13 JKU 10th Anniversary
allibaster is offline
post #10 of 14 Old 09-18-2010, 08:59 PM
Unlimited2010
they were ones i picked up back in 1998 from radio shack for $15.XX i believe. no ides on brand. sorry.
can check later.
i have never been great with wire management........this is actually pretty good. you can't see them unless you bend down and look under the seats!!!!!
-R
post #11 of 14 Old 09-18-2014, 06:57 AM
gambit1026
Can anyone tell me the color of the 4 front speaker wires going back to the stereo
gambit1026 is offline
post #12 of 14 Old 09-18-2014, 06:59 AM
gambit1026
Or a pic would be awesome
post #13 of 14 Old 09-18-2014, 07:48 AM
TexanTJ
2014 JK Wrangler
thanks
Mudman- When amp shopping look for one that have "speaker level inputs".
Going this route, you can locate one of the rear speaker channel wires off your roll bar, splice the speaker level input in, your're good to go. (no need to even pull the head unit.)
Then run your remote power turn on wire to an ACC power supply that comes on with the ignition.
Also, if you already have an amp and it doesnt have the speaker level input, you can purchase something like this
http://www.crutchfield.com/shopsearc...vel_input.html
2014 JKU Sport - Wife's Mall Crawler on 35s. Badlands Winch, 2" Coil Spacers, 1" PA BL
1999 F250 7.3 - 290K Miles and Counting
"I am not going to censor myself to comfort your ignorance."
TexanTJ is offline
post #14 of 14 Old 09-18-2014, 09:05 AM
JoonHoss
2011 JK Wrangler
I had been told many times by many people that the factory head unit has the sound (base, specifically) frequencies tapered off, and that you can't/won't get a full range of base to amplify from the factory head unit?
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
Stock bumper with no D rings, what do I connect a tow strap to? Pallando TJ Wrangler Technical Forum 22 12-04-2009 03:55 PM
U-Connect Question with RES radio ace22 JK Wrangler Technical Forum 3 09-09-2009 10:28 AM
TJ stock bumper tow bar connect parks31 TJ Wrangler Technical Forum 0 05-07-2009 09:32 PM
Radio Stole - Should I get a stock radio? veddhead TJ Wrangler Technical Forum 5 03-20-2007 11:20 AM
No Power to Radio YKnot YJ Wrangler Technical Forum 7 03-21-2006 01:19 PM
