Can anyone diagnose this steering issue? - JeepForum.com
post #1 of 5 Old 04-01-2013, 08:39 AM Thread Starter
Wavedatya
2010 JK Wrangler
Ok. I've read and posted in a few threads and I want to see if anyone experiences this.
What it feels like:
When turning or making sharp turn it feels like when it's stuck in 4x4 and driving on dry ground. But not as extreme as that. That wobble tire feel. Like as if the wheels are wobbling. I feel it trough the steering wheel and it prob shimmies about 1/2 an inch side to side. This only happens when turning either left or right and over bumps it feels a little harsher than before.
It's really bugging me and right now don't want to have to pay for mechanic to look at it and pin point the exact problem. I have a couple ideas on what it could be but if someone experience this same issue please chime in and let me know what the fix was.
Thanks
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #2 of 5 Old 04-01-2013, 09:03 AM
222Doc
222Doc's Avatar
sounds like Dw starting. Check the track bar bolt hole. There is a sticky on this, Dw go through it. Your profile has some info, I can see that its stock? is it still? No lifts or other changes?
222Doc is offline
post #3 of 5 Old 04-01-2013, 09:09 AM Thread Starter
Wavedatya
2010 JK Wrangler
Hey. No lift. Same tire diameter just slightly wider than stock.
post #4 of 5 Old 04-01-2013, 09:29 AM
JTPhoto
JTPhoto's Avatar
Sounds like your hub u joints are starting to bind up. When they get dry and the roller bearings seize the u joint caps seize on and do not rotate well causing a sticking feeling. This happens whether in 4wd or not.
Usually that is accompanied by squeaking as the u joint tries to rotate.
Check by lifting the frontend, turn the wheels and rotate the wheel by hand. Inspect the u joints as you rotate.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #5 of 5 Old 04-01-2013, 10:35 AM
ronjenx
ronjenx's Avatar
Usually that is accompanied by squeezing as the u joint tries to rotate.
This same thing has happened on other 4wd vehicles I've had.
The binding will be subtle at first. It will get worse over time.
ronjenx is offline
