Can adj ball joints correct my caster? - Page 2 - JeepForum.com
post #16 of 21 Old 10-28-2013, 04:55 PM Thread Starter
04WJfreedom
04WJfreedom's Avatar
Originally Posted by Pokey02
It sounds like you need to shorten the front upper control arms. Do you have an angle finder? There is a good article from another forum regarding caster: http://project-jk.com/jeep-jk-tech/j...affect-my-jeep
I don't have an angle finder but can get one. But it does look like I need to shorten the upper CA's. Just don't know how much to shorten them? is just a slight adjustment going to make a big difference?
2012 JK Unlimited Sahara
Rock Krawler 3.5" X-Factor MID arm lift
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
04WJfreedom is offline
post #17 of 21 Old 10-28-2013, 05:05 PM
Pokey02
Yes, a slight adjustment can make a big difference. Start by shortening a full turn (maybe two), reinstall the control arms, then take another measurement. Repeat until your caster is where you want it.
13 10a JKUR - Metalcloak 2.5" lift
06 LJ Impact Orange - Savvy 3" lift, Savvy UA and 33s
Pokey02 is offline
post #18 of 21 Old 10-28-2013, 05:16 PM
ncb
Make sure the upper adjustable control arms will adjust shorter than the stock arms. Some adjustable uppers are too long to run with out adjustable lowers.
I think most start with adjustable front lower control arms for this reason.
ncb is offline
post #19 of 21 Old 10-28-2013, 05:20 PM Thread Starter
04WJfreedom
Thanks for the help guys I might try shortening the uppers tomorrow if I have time and see if I can take a measurement.
35x12.5x17 BFG KM2
4:88 Yukon gears
KOR Drive shafts
post #20 of 21 Old 10-28-2013, 06:32 PM
JTPhoto
JTPhoto's Avatar
You will also have to take onto consideration your pinion angle. You may not get all your caster back without jeopardizing pinion angle.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline
post #21 of 21 Old 10-28-2013, 06:55 PM
SLADE
Pinion angle shouldn't be an issue with only 3.5" of lift, but your right about keeping the pinion angle in mind.
Once you go so high, you often have to compromise between the pinion and caster angle to make everything work. You can't completely neglect one for the other and they are both equally important.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
