cam bolts? - JeepForum.com
post #1 of 4 Old 04-26-2007, 07:08 AM Thread Starter
greggradwohl
cam bolts?
It appears to me, these are used instead of adjustable control arms for 3” or more lift (tell me if that’s incorrect).
What exactly are they?
How do they work?
Is this a bad solution?
greggradwohl is offline
post #2 of 4 Old 04-27-2007, 01:33 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
i hate them. and i can't say that with enough vehemence over the internet to really convey how much.
it's a metal disk, with a hole offeset and a bolt through it. there are lips on the axle end of the control arm mounts (front = lower, rear = upper) that said disk fits between. when you turn the bolt, the disk will push against these mounts, and the axle will rotate accordingly due to the offset hole. pinch a quarter between your thumb and forefinger, off-center. spin it. they work like that.
yeah, i'd say between 3-4", you are definitely going to need to address your caster.
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #3 of 4 Old 04-27-2007, 06:40 AM Thread Starter
greggradwohl
Should I just avoid these? This is not going to be a "show" jeep. She is spending most of her time on the mountain - durability/reliability is key.
post #4 of 4 Old 04-27-2007, 08:34 AM
igofshn
Locked @ both ends
igofshn's Avatar
Avoid them
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
Need some bolts - front hub to knuckle bolts (12 pointers) Tobey YJ Wrangler Technical Forum 9 10-14-2016 06:36 PM
Want to replace stock control arm bolts with grade 8 bolts... Mino TJ Wrangler Technical Forum 7 01-23-2010 10:02 AM
Torx head starter bolts - Anyone know what kind of bolts? patricknolan TJ Wrangler Technical Forum 0 08-13-2009 08:02 AM
Tool for taking off hardtop bolts and windshield hinge bolts TheDiabetic TJ Wrangler Technical Forum 10 03-30-2006 05:49 PM
Removal of snapped body mount bolts and bolts in general? SpedJeep YJ Wrangler Technical Forum 15 10-16-2005 09:01 PM
