calibrate speedometer? - JeepForum.com
post #1 of 10 Old 12-07-2011, 07:37 PM Thread Starter
jtjohnston
I have just put on 16" snow tires, down from the 17" rim - on my new 2008 JK Wrangler (new for me).
Is my speedometer still working correctly? It seems like I'm driving awfully slow at 100 kph?
Do I need to go to the dealer to have the computer adjusted?
I lost 3 inches of height! Makes jeepy look awfully petite!
jtjohnston is offline
post #2 of 10 Old 12-07-2011, 07:40 PM
DrHolliday
2011 JK Wrangler
rim size has nothing to do with it, need to know the tire sizes... An AEV procal can correct for just about any tire size.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
DrHolliday is offline
post #3 of 10 Old 12-07-2011, 08:00 PM Thread Starter
jtjohnston
Why would I change the axle ratio?
http://www.aev-conversions.com/pdf/i..._Reference.pdf
post #4 of 10 Old 12-07-2011, 08:05 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
Originally Posted by jtjohnston View Post
for several reasons, but its not what you need.
what the pro cal does is change the ratios available. your constant variables are your rear end ratio and the output speed of the driveshaft. what you've changed is the outer diameter of the tire, which is also a variable to the whole system.
you need to calibrate the computer, with a pro-cal or other similar device. that way the computer will know the change in tire height and the speedometer will work accordingly.
My builds:
and
or follow us on
spyder6 is offline
post #5 of 10 Old 12-07-2011, 09:36 PM
BManz
2011 WK
You can play with this Excel file to quickly see speedometer changes if you change tire diameter or axle ratios:
http://www.jeepforum.com/forum/f96/s...lator-1298121/
BManz is offline
post #6 of 10 Old 12-08-2011, 06:31 AM
aristobrat
2010 JK Wrangler
To recap what others have said, if the overall size of your tire changed any (32" to 31", etc), then your speedometer will not be working correctly.
If you want to verify your speedometer, use a GPS that shows your current speed, and compare it to your speedometer. If you don't have one, or can't borrow one, a lot of smartphones have free apps that do that too.
If the overall size of your tire did change, to recalibrate your speedometer, you can have your dealer flash the new tire size in (and continue to pay your dealer each time you swap tires), or you can pay for a ProCal once, and make the change yourself when needed.
The second page of the ProCal PDF you uploaded shows how to change tire sizes. Oh, and you need to measure the actual physical size of the tires on your Jeep. Do not go by the size stamped on the side of the tire, as that's often not accurate.
aristobrat is offline
post #7 of 10 Old 12-08-2011, 06:33 AM
WXman
I've had my JKU for 6 months and I've been through 5 different wheel/tire combos already. My AEV ProCal has paid for itself 3 times already. I love it.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #8 of 10 Old 12-08-2011, 03:39 PM
jrmandryck
Ditto all about the overall rim/tire combo size
truth is so precious that she should always be attended by a bodyguard of lies...
jrmandryck is offline
post #9 of 10 Old 12-09-2011, 07:48 AM
WXman
Just FYI.. what I am discovering is that with my ProCal, I have to set the ProCal to .5" LESS than the actual measured tire height while on the Jeep. This is the only way I can get my speedo to match up with GPS readings. It was this way with both my 32s and 33s.
WXman is offline
post #10 of 10 Old 12-09-2011, 07:58 AM
Noxian
2011 JK Wrangler
My understanding is the dealership can make adjustments for tires up to 32inchs also.
But I recommend the Procal. Love mine, lots of other cool stuff it can do too.
Noxian is offline
How do i calibrate my speedo Gearhead231 YJ Wrangler Technical Forum 25 08-31-2010 01:43 PM
Anyway to calibrate the 42RLE to match the 4.0L silvanus TJ Wrangler Technical Forum 7 02-25-2009 08:36 AM
Calibrate Speedometer tready29483 YJ Wrangler Technical Forum 7 09-27-2006 12:34 PM
Speeding ticket - Calibrate?? Stray Cat YJ Wrangler Technical Forum 6 08-12-2003 08:09 PM
Re Calibrate Speedo 69440dart TJ Wrangler Technical Forum 1 07-31-2003 01:23 PM
