cai or snorkle - JeepForum.com
post #1 of 15 Old 01-23-2013, 10:13 PM Thread Starter
benjmjeep
cai or snorkle
i have a 2013 rubi wondering what would net me best fuel efficiency and performance overall
benjmjeep is offline
post #2 of 15 Old 01-23-2013, 10:18 PM
LeeMasterGT
Everything I've ever READ ( Not DONE or EXPERIENCED) said that these things by themselves wouldn't help to the point they would be noticeable. I would love some experience from somebody that actually shows real gains.
From a logical standpoint it wouldn't make sense that you would really see gains in performance just with the CAI or snorkel by themselves. The point is to increase efficiency of air moving through the engine. Adding a CAI or snorkel may help at the front end... But then you have the throttle body, the headers and the exhaust that are still the stock size, meaning they 'pinch back down' in a manner of speaking and you lose all the gainsthat you got by increasing the flow coming in... Because there is limited space for the air getting out. This is my thought process, but as I said... I have no real world experience testing it.
LeeMasterGT is offline
post #3 of 15 Old 01-23-2013, 10:51 PM
TWISTEDII
Air temp may be cooler, so it may help some, but like you said, the air will bottleneck at the narrowest point.
TWISTEDII is offline
post #4 of 15 Old 01-23-2013, 10:59 PM
LeeMasterGT
And I also figure that even if you change out the entire line, meaning CAI, improved headers, bigger throttle body, larger exhaust... To really get the most out of the engine you'd need to re-tune the engine. Which probably means a chip or programmer to reset the computer. All in all I would think you might be able to gain... 40 horses?? but for all that aftermarket work you're probably into your engine a grand.
post #5 of 15 Old 01-23-2013, 11:59 PM
fratis
fratis's Avatar
the narrowest point being the throttle body itself. people tend to forget about the throttle body butterfly. they look at the outside diameter of the throttle body and think they need a larger diameter tube. if the hp were in a direct relationship to the intake tube diameter then running the engine without the filter and intake tubing should result in unlimited power.
if one doesnt waterproof everything else then a snorkle is just and ugly ornament.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #6 of 15 Old 01-24-2013, 01:13 AM
MeatCurtains
I don't really think you are going to see any difference at all from either one.
Back in the day I used to think CAI's were good, now I know better. They just are. No performance gain, just sound.
As for the snorkel, the function isn't to feed cold air for power, it is to keep things away from the intake. You will see the largest benefit from these in extremely dusty environments. Sure, if you seal everything up really good you could probably go diving with your rig, but it just isn't really supposed to do that.
Even though. I always thought I would want a snorkel for the "cool" factor. I just can't make myself pull the trigger though.
MeatCurtains is offline
post #7 of 15 Old 01-25-2013, 03:59 PM Thread Starter
benjmjeep
Yeah my friend was trying to explain it but y'all cef said it better might just stay stock in the engine and regear
post #8 of 15 Old 01-25-2013, 04:37 PM
JTPhoto
JTPhoto's Avatar
With the 3.8 you are able to run a bigger throttle body off the Viper V10 and it is direct bolt on and plug in. I believe the difference is something like 54mm to 72mm. Some gains in throttle response were noticed but no one has done a Dyno to prove or disprove whether that ads HP or not.
Not sure if the Viper TB will fit the 3.6 ..
CAIs will make you susceptible to dust and water intake while offroading.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #9 of 15 Old 01-26-2013, 09:27 PM
paul84043
Cai is not worth it. A snorkel is a worthwhile investment if you plan on doing any water fording or puddle splashing..
A hydrolocked engine engine is no bueno.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #10 of 15 Old 01-26-2013, 09:54 PM
neverhide34
2011 JK Wrangler
Is it sad that I secretly wish for hydrolock just to justify a Hemi conversion?
I would leave it all alone unless you really want to splash around. And no real benefit from CAI. One thing for certain: they are both costly investments. I can think of many other ways to spend +/-$300 on my JKU.
Keep Calm, Chive On
neverhide34 is offline
post #11 of 15 Old 01-26-2013, 09:59 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
The real "narrow" point in the intake, TB header and exhaust is the cam timing/lift on the valves. That controls total engine airflow. So unless you are into redoing your total airflow path, not much to be gained.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #12 of 15 Old 01-27-2013, 09:09 AM
HOKIES2010
2011 JK Wrangler
I would wish for the hydrolock myself if it didnt mean additional thousands to get the Hemi lol.
Having hydrolocked a vehicle and having a friend that hydrolocked his lifted JKU in a small amount of water. I am glad I bought a snorkle.
That said I just have to get around to installing it.
If snorkle is the choice you might as well get the breather tube relocation kit. River Raider make a nice one. I choose their cowl snorkle as well. Less of an eye sore to me personally and you don't need a new hood. Good luck
My Build
Couldn't have done it without
HOKIES2010 is offline
post #13 of 15 Old 01-27-2013, 08:00 PM
Tanimal
I did a Superchips and Rugged Ridge snorkel. So far I like it and I don't know if any MPGs were gained considering my speedo/odometer was so far off because of the jump from the small tires to 35s but one of my buddies was telling me he was getting +1-2mpg with the RR snorkel. Even if I got +1mpg least the mods are slowly paying for themselves or at least that's what I tell myself to make myself feel better about always buying crap for the Jeep. The cheap insurance is also a huge reason I went with a snorkel, would rather spend 300 bucks for a precaution than hydro-lock.
Learning as I go and it's worth every penny!
Tanimal is offline
post #14 of 15 Old 01-28-2013, 03:52 PM
chris79
JK Wrangler
Snorkel, it has a functional use. I had an 08 with a CAI and Magnaflow muffler....the 3.8 is what it is, can't really upgrade the performance or MPG, do NOT waist your money trying to!!
chris79 is offline
post #15 of 15 Old 01-28-2013, 06:03 PM
Kichu182
2011 JK Wrangler
Also, while the snorkel isn't necessarily something that will turn your Jeep into a submarine, it will do something to help with splashy water; unlike a CAI which unless done VERY right will make you more susceptible to hydrolocking
Kichu182 is offline
