Buying a JK :) - Page 2 - JeepForum.com
post #16 of 31 Old 04-24-2013, 11:36 AM Thread Starter
Jclilk
A buddy told me that the rubis have a d44 in the front but the actual axle is from a 30?! Uhm wtf is this lol
Jclilk is offline
post #17 of 31 Old 04-24-2013, 12:46 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
The only thing the jk44 and jk30s share is tubes and outers
My builds:
and
or follow us on
spyder6 is offline
post #18 of 31 Old 04-24-2013, 01:53 PM
PhatJK
2009 JK Wrangler
Originally Posted by Jclilk View Post
Ok so I'm selling my 86 CJ7 for a JK. Im looking at 2 JKs but don't know which to go with. '08 Jk Rubicon or '13 JK sport new? Please help me I've heard 08 jks got a bad engine or w.e idk I'm confused
Generally the 07-11 JK have better value because you don't pay for the large depreciation of the 13JK when you drive it off the lot.
Rubicon tends to hold their values more than the Sport or Sahara so you may pay premium for the Rubicon.
Highly modded vehicle doesn't mean it's better unless you intend to buy a readied modded vehicle for rock crawling or for similar hard pursuits. Who know what gremlins are lurking underneath the running gear after the hard life the previous owner put it through.
If I am shopping for a used JK, I would be looking for a low mileage 11 Rubicon with minimal or zero mod. There is one lady at work who has a similar vehicle so if I buy that Rubicon, I would buy a babied JK Rubi and I am less likely to experience bad mechanical hiccup due to some bad monkey wrenches. A 12JK is too new with potential engine problems. A 13JK is a brand new vehicle and I avoid buying brand new vehicle based on the financial hit, unless it comes with a killer deal. Due to the popularity of the JK, Jeep isn't giving away killer deals anymore.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #19 of 31 Old 04-24-2013, 04:04 PM
Beardacus
I recently picked up a '13 sport and I cant stop raving about this new motor. If the option for a '13 is there I would really consider it for the engine alone.
'08 WK - '13 JK
Beardacus is offline
post #20 of 31 Old 04-24-2013, 05:56 PM
Remmy18
Don't forget to consider the 4:1 transfer case in the Rubis. I know a few guys that are replacing their TCs with the 4:1 or installing a Rubi Crawler. The 3.8 is doable but the 3.6 is kick *** in comparison. Also your need to regear is less with the 3.6 so you may not need to regear it if you go to larger tires. Drive em both first for sure and good luck. Bite the bullet and get a 2012 Rubi! That's what I ended up doing.
Remmy18 is offline
post #21 of 31 Old 04-24-2013, 09:27 PM
CJ7Dac
two years ago I went from an 84 lifted cj7 to a 07 4 door rubi, I have never driven a jeep with the new engine so I don't know how underpowered it is compared to the new one but honestly its not that bad, I have 35"s on it and don't really have any issues as a daily driver, I hit 75-80 mph every day and getting up to speed has never been an issue. The only time I have noticed power issues was when I was over 8000 feet driving up a mountain highway with 4 guys and fully loaded with gear. It really depends how much you want to mod it and how and where you wheel it. If your in Florida, i really don't see the need for a rubi since its more meant for rock crawling. As for that auto sway bar disconnect I find it fairly worthless and I am just waiting for it to break since it locks back up whenever you go over 18 mph...
CJ7Dac is offline
post #22 of 31 Old 04-26-2013, 11:35 AM
HOKIES2010
2011 JK Wrangler
In FL as well with 37s, no issues with the right gears ratio. I felt underpowered in the moutains of central VA and WV. I wanted to be able to use 6th gear on the hwy without loosing speed. Having a heavy JKU could have been a big part of the issue. Have no idea how a 2dr would have faired. But a gear change fixed my problem completely.
OP - The auto is the issue with the 3.8 more than the 3.8 itself. I used to sell cars. See if a dealer will let you take a JK with a 3.8 overnight. Most don't have problems doing that with used vehicles.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #23 of 31 Old 04-28-2013, 01:40 PM Thread Starter
Jclilk
On a 08 2 door Rubi I can go 35s with no issues but if I go 37s I need to regear!?
Jclilk is offline
post #24 of 31 Old 04-28-2013, 06:24 PM
222Doc
222Doc's Avatar
No on a New rubi 012+ you can just toss on the 35"s and what is need to clear them. auto or manual. some even go 37 with a Rubi,s 4:10. But Od is about worthless.
011 down if its an auto it will be very slow with 35"s. That auto has a, 2:20 first gear? thats what kills it. Then the Od is way to tall.
222Doc is online now
post #25 of 31 Old 04-28-2013, 06:37 PM Thread Starter
Jclilk
Im go with an 08 manual obv lol so I would still need to regear?
Jclilk is offline
post #26 of 31 Old 05-12-2013, 10:29 PM
Deadhead88
2010 JK Wrangler
http://www.pahighlander.com/Temp/JK_Gearing_Chart.jpg
Gear ratio chart for the jk auto and manual... I haven't gone 35's yet, but according to the chart for a manual rubi.you shouldn't have a problem with 35's.
Stock 2010 rubicon
Soft top
Half doors
Deadhead88 is offline
post #27 of 31 Old 05-15-2013, 09:49 AM Thread Starter
Jclilk
You got another for the 3.6l JK? I mite be buying a sport 2013 with 3.73 gears
Jclilk is offline
post #28 of 31 Old 05-15-2013, 09:55 AM
Deadhead88
2010 JK Wrangler
That I do not have. But you may be able to find one on google if anyone has made one yet. That is where I found that one to see if I would be ok with 35's without a gear swap
Stock 2010 rubicon
Soft top
Half doors
post #29 of 31 Old 05-15-2013, 10:05 AM Thread Starter
Jclilk
Looks, good but I mite be getting the 2012 or 2013 sport with the 3.73 so I wanna make sure I can put 35s
Jclilk is offline
post #30 of 31 Old 05-15-2013, 10:16 AM
Deadhead88
2010 JK Wrangler
Im not positive on the 3.6 but I would imagine with 3.73's you would lose quite a bit of power going with a 35
Stock 2010 rubicon
Soft top
Half doors
