Buying advice, please... - JeepForum.com
post #1 of 5 Old 06-16-2010, 08:11 AM Thread Starter
Super1
2010 JK Wrangler
Im committed to buying a used four door Jeep Unlimited, 2007 or newer and I want to spend under $20k.
The Jeep would be used mostly for a five mile ride driving to-and-from work, but I plan on taking it on the beach about 10 times a year and on trails (nothing too serious) a few times a year too.
This is my plan and, not being a Jeep owner, Id like other opinions:
Buy a used Jeep Unlimited X with about 30K-50K, off lease or such. That should run about $18K.
Lift the Jeep 2 with a spacer/shock kit, $300.
Replace stock steel wheels/tires with Pro Comp 17 rims and 285/70/17 tires, $1,200.
Add a Trailer Hitch, $200.
Maybe later Ill replace the front bumper with something more rugged later on.
So, whats wrong with that plan?
Super1 is offline
post #2 of 5 Old 06-16-2010, 08:26 AM
redrockin7
Sounds like an ideal plan for someone with your intentions... a 2-3" lifted JK with 33s can handle its own out on the trails (esp. "mild" ones like your plan states) and the beach.
Be careful the more serious "mod bug" doesn't bite you and get you into more expensive lifts, 35s (minimum), which leads to re-gearing and other stuff, bumpers, fenders, etc.
If you have some self control though, your plan sounds great!
My only suggestion would be to get a 6-speed and/or get the best set of gears you can get in the rig to start with. The 3.xx gears just suck IMO, especially with an auto, and if you plan to tow, you want the best gear you can get. Doing it with 3.xx gears isn't going to go to well, without turning OD off, which maybe you should do anyway, I don't know b/c I don't tow. Anyway, if you can score a 6-speed with 3.73 (would be livable - much better than 3.21 but believe this combo is rare and only a more recent option) or 4.10 gears (better yet) or the automatic with 4.10 gears, you should be OK with the 33s, and your plans, including some light towing. Not sure exactly which jeeps came with 4.10 other than the Rubi, but i think there are some non-Rubi's with 4.10s to start out there - tow package option or otherwise.
Don't expect a speed demon or anything, ever, in a Jeep, but it will get around fine.
redrockin7 is offline
post #3 of 5 Old 06-16-2010, 08:42 AM
N2rock
N2rock's Avatar
in '07, all models of Unlimited that have either auto transmission, or factory tow package came with 4.10's
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 5 Old 06-16-2010, 08:52 AM
redrockin7
There you go, OP. If you truly are looking for a used one, I would look for one of these 07s, but that's just my opinion.
One thing to be careful of though, is that some of the very early 07s had D35 rear axles (maybe not 4-door, but definitely some 2 doors?) - and you want none of that. So make sure whatever you get has a D44 rear axle...
post #5 of 5 Old 06-16-2010, 02:34 PM Thread Starter
Super1
2010 JK Wrangler
Thanks, everyone.
Super1 is offline
Buying advice... 5point9Limited TJ Wrangler Technical Forum 16 03-14-2010 03:29 PM
I need some TJ buying advice, please! AuburnTiger92 TJ Wrangler Technical Forum 9 05-15-2009 08:06 PM
Advice on buying an 04 Brendan93 TJ Wrangler Technical Forum 6 07-18-2007 07:35 PM
Buying advice Roll-Bar TJ Wrangler Technical Forum 5 07-13-2006 01:54 AM
Buying Advice gustaia TJ Wrangler Technical Forum 5 11-10-2005 01:09 PM
