Buying 08 X w/auto 3.73 gears and 17x7.5 Tire size question - JeepForum.com
post #1 of 6 Old 07-01-2007, 03:06 PM Thread Starter
dstephns
2015 JK Wrangler
HI everyone and thanks ahead of time. I'm new to Jeep Wranglers and I'm going to order an 08 X 2dr with auto and 3.73 diff. My understanding is that the tire diameter on the stock X's is 28" (?). I'm thinking of going with the 17X 7.5 and the stock Rubicon tires 32" diameter tires. My off roading will be mostly on snowy and muddy rutted forest roads and some pretty long highway grades 6% or so - nothing spectacular and not 4 wheel drive. Am I going to take a big hit with highway driving with the 17x7.5 wheels and 32" diameter tires w/3.73 diff? If so can you recomend a tire size (other than stock X) that I would see little negative impact. Also, should I just keep the stockers and don't worry about it. They just look a little small to me. Everything else will remain stock. Thanks.
dstephns is offline
post #2 of 6 Old 07-01-2007, 03:19 PM
UTAH
UTAH's Avatar
Welcome to the forum, dstephns.
Your drivability should be just fine with 32" tires and that axle ratio (3.73). Having said that, there're a few things I think you could do to keep your JK more highway friendly.
For one thing, I don't know if I'd go with the stock Rubi tires. They're GY MT/R's - which give a harsher ride and don't do as well on the street as ATs (performance-wise and MPG-wise). Don't get me wrong, GY MT/R's are a great tough off road tire and I like 'em. I just see your concerns about "highway driving" and think a good AT tire (like the BFG AT or Pro-Comp AT) might be a better fit.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #3 of 6 Old 07-01-2007, 03:28 PM Thread Starter
dstephns
2015 JK Wrangler
Thanks
Thanks for the quick response. Thats the exact info I'm looking for. By the way I really enjoy reading these forums. They're alot help for us newbys and thanks for the welcome!
dstephns is offline
post #4 of 6 Old 07-01-2007, 06:31 PM
Dannyboy18
Ever think of trying the new Pro Comp Xtreme A/T? They are in between the Pro Comp A/T and M/T.
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline
post #5 of 6 Old 07-03-2007, 09:36 AM
LakeTravisJK
I did something similiar with my 2-dr 07 JK. I have the 4.10 w/ auto. I originally had the 225's(29.2") and upgraded to 265x75xR16 BFG AT's(~31.5"). With the original small rubber, the acceleration seemed pretty good and the gas milage averaged ~17-17.5 mpg. Now with the larger rubber, the acceleration seems a bit slower, but the big change is the overdrive is completely useless for most of my driving. I turn it off with the switch each time I start it. The gas milage is now ~16 mpg or 1-1.5 mpg worse than stock rubber.
but I do enjoy the improved off-road performance!
LakeTravisJK is offline
post #6 of 6 Old 07-03-2007, 10:30 AM Thread Starter
dstephns
2015 JK Wrangler
Thanks again everyone
I think I will still go with a little bigger wheel and tire than the stock. You guys are great I really appreciate the responses.
dstephns is offline
max tire size with 4.10 gears stevoYJ YJ Wrangler Technical Forum 11 06-12-2009 06:03 PM
Tire size question for gears and lift. whitecopter TJ Wrangler Technical Forum 6 12-26-2008 03:39 AM
3.21 gears tire size? (noob) victor903@email JK Wrangler Technical Forum 3 05-31-2007 10:17 AM
Gears & tire size durangojeep TJ Wrangler Technical Forum 16 11-26-2006 03:22 PM
tire size/lifts/gears Tonybreaux TJ Wrangler Technical Forum 4 10-29-2003 01:20 PM
