Burning Oil ... What needs to be replaced? - JeepForum.com
post #1 of 87 Old 12-18-2012, 07:08 AM Thread Starter
Jazeeperz
2010 JK Wrangler
Hey all,
My JKUR is burning a quart of oil between oil changes. Is there something that needs to be replaced that would alleviate this? If so, what is the typical cost of the part?
Thanks in advance
Chris
Stock 2010 4 door Rubicon
Jazeeperz is offline
post #2 of 87 Old 12-18-2012, 09:11 AM
tjkj2002
2002 KJ Liberty
Rebuild engine with better rings on the pistons,and placed correctly.
Cheaper solution is to use 5w-30 oil instead and make sure your PCV system is working correctly.
tjkj2002 is offline
post #3 of 87 Old 12-18-2012, 09:18 AM
janders82
2010 JK Wrangler
This actually seems to be a common issue with the 3.8...I've haven't read any threads where the issue has been resolved. I would suggest checking your oil levels regularly between changes. Also, a higher viscosity oil may help
2010 JKU Automatic w/ 5.13 Gears
2.5" TeraFlex w/ Rancho XL9000s
17" XD Addicts
295/70/17 Nitto Trail Grapplers
janders82 is offline
post #4 of 87 Old 12-18-2012, 11:39 AM
rirrgang
Only a qt between changes? How long are your change intervals?
I add a qt every couple thousand miles. Now that I don't commute on the freeway for 110 miles a day, I changed my interval from 10k to 7.5k miles.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #5 of 87 Old 12-18-2012, 02:56 PM
SoK66
2009 JK Wrangler
That's the key question. If you mean a qt between the recommended 6,000 mile oil changes I wouldn't sweat it. I change mine at 3k simply because it sees so much dusty off road and local low speed use. It uses maybe a 1/4 of a quart of 5w-30 between changes.
The 3.8L is a notorious oil burner. Be SURE to check your oil every time you fill up and you'll get a much better fix on whether you have a real problem or not. Common simple fixes that have been reported are changing to a higher viscosity oil and replacing the PCV valve. However, some have internal issues that have to be dealt with by tearing the engine down. Some Mexican built engines had their oil control rings installed upside down, otheres have ovalled bores. Another issue that popped up on another forum was failed valve guide seals. The latter can be fixed without a major tear down, just holding the valves up with compressed air, removing the keepers and valve springs and swapping out the seals one cylinder at a time. Best left to a shop that knows what they're doing.
SoK66 is offline
post #6 of 87 Old 12-18-2012, 03:00 PM
paul84043
Question, is it actually "burning" it, meaning you can see/smell it? Or is it vanishing into the land of lost socks?
If you can't actually tell where it's going, then you can replace your PCV valve and possibly be able to slow it down. It's got to be going somewhere, there are just a lot of pople that say they can't tell where it's going...
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #7 of 87 Old 12-19-2012, 06:59 AM
jstrubberg
2009 JK Wrangler
Switch to 5w-30.
jstrubberg is offline
post #8 of 87 Old 12-19-2012, 07:05 AM
Jiblet
a perfectly healthy engine could use a quart of oil between changes, especially if those changes are 4 or 5,000 miles apart, even more so if you do a lot of stop and go or long idling.
1/4 of a quart per 1000 miles ain't going to get you into the 3.8 oil-burners club. Plenty of JK owners would kill to only burn a quart between changes.
What is your change interval? Time, miles, engine hours? What is your typical use? short trips, traffic, cold starts?
Jiblet is offline
post #9 of 87 Old 12-19-2012, 08:13 AM
SoK66
2009 JK Wrangler
Those are the key questions, combining long change intervals with 5w-20 is a recipe for trouble. As hot as they have the 3.8L operating in the JK, with high underhood temps and an auto trans with insufficient cooling capacity the oil can only take so much. One of the reasons I change at 3k miles on mine is the high operating temps. You can mitigate those high engine temps somewhat with an auxiliary trans cooler kit, but the heat from the catalysts rises up under the hood and gets trapped. Add in that pond water 5w-20 and it will thin out & blow right past the rings, get sucked down the valve stems, etc.
SoK66 is offline
post #10 of 87 Old 12-19-2012, 12:24 PM Thread Starter
Jazeeperz
2010 JK Wrangler
I change the oil every 6k miles. I typically run 150-200 miles a week (mostly interstate). There are 96k miles on the clock. I have noticed this issue for nearly the last 30-35k miles. I was thinking changing the PCV but it is not as easy to do as it is on older vehicles. May just start putting the 5W-30 in to see how it responds. And yes, there are no exernal leaks.
post #11 of 87 Old 12-19-2012, 07:17 PM
IrishOneill
Didn't realize this issue was so prevalent. Thanks for the advice on this issue and the reassure meant knowing I am not alone.
IrishOneill is offline
post #12 of 87 Old 12-19-2012, 08:37 PM
farmer-dave1
Trust me your not alone. Even my chrysler minivan with the 3.8 uses some oil, as does my jeep.
farmer-dave1 is offline
post #13 of 87 Old 12-19-2012, 08:51 PM
Jiblet
Sounds like a healthy engine to me.
Are you using a synthetic oil? Try the 5w-30, it won't hurt.
The PCV valve isn't too bad to change on the JK and you're about due. Don't bother simply inspecting the PCV valve, its a $10 part, just replace it.
Have you considered new plugs/wires?
using up only a quart over 6000 miles with 96k on it sounds normal, good even.
The rigs burning 4 quarts in 3,000 miles; those are the guys with problems.
Jiblet is offline
post #14 of 87 Old 12-20-2012, 08:00 AM
rirrgang
As much as I'd like to use 5w-30 instead of 5w-20, my mechanic advises against it. Oil passages and variable valve timing mechanisms as sensitive to thicker oil. I don't know if the 3.8 has VVT or not but I've just gotten used to adding a qt about every 2k miles. So far I've got 94k on the JK and it seems to still run as dood as new. For an experiment I did run one oil change on 5w-30 and it still burned the same amount over the coarse of an oil change.
Just my .2 worth.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #15 of 87 Old 12-20-2012, 08:06 AM
ronjenx
ronjenx's Avatar
Just my .2 worth.
No vvt in the JK 3.8L engine.
The oil passages in the 3.8 can handle 5W-30 just fine.
In fact, it's what is recommended in other parts of the world.
ronjenx is offline
