Burly looking 33" tires for stock 18" Sahara wheels
#1 | |
As the title states, I am looking for some burly-er looking tires for the stock 18" wheels that came with my '08 Sahara. It will be on the street mostly. I just want a tougher look. I am having a tough time finding some. Discount tire and NTB don't have any tough looking tires.
I am buying a 2" BB lift this week. Also, If I replace the wheels, will the tpms work? Thanks! -Chuck
#2 |
DETN8R
Try 4 wheel parts, they have the Super Swamper Bogger. Thats about as Burly as it gets....They also have BFG Mud Terrain, Pro Comp, Mickey Thompson, etc.
'08 DETN8R Yellow Unlimited Rubi 6-Spd / Soft top / Power / Side Air Bags Installed: R.E. 3.5" (4" now) Super Flex Kit & Ft. driveshaft/Full Traction Rear Adj. Trackbar/Rancho (4" long arm) 9000XL shocks/Superior 4.88 Gears & Evo Rear Axle Shafts/37" Goodyear MTR's/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Prototype Rear Bumper/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant/Cobra 75 WS XT C.B./Prototype Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on custom mount & brace... ____oooo [ l_,[____], l---L -[OlllllllO] ( )_) ( )_)--)_) |
#3 | |
-Chuck |
#4 |
Also, I only have 3.73 gears. I did not have an option for 4.10. Can I go with larger wheels than the 32" on there now? I was hoping to have a size just over 33.5-ish".
-Chuck |
#5 |
Summit Racing has the Mickey Thompson MTZ for your size. I love my MTZ's and very tough looking.
Ken S. 1952 Buick Roadmaster 1994 Jeep Grand Cherokee Limited (sold to family) 1997 Jeep Wrangler TJ 1997 Ford Probe GTS Turbo 2.5l V6 I'll find you someday and when I do, you'll know its me. |
#6 | |
I'm running 4.10's with an auto on a 2-door. Around town it's takes off great, but on the highway, it suckks!!. If there's the slighest hill or headwind, its downshifting. I need 4.56's or 4.88's to get back to stock. I would think that 3.73's are still too tall IMO - lots of guys here run 35's on 3.21's and don't complain, but I don't know how - ESPECIALLY on an auto. 6spd must make a HUGE difference. |
#7 |
Toyo MTs, best MT out there.
2007 Red Rock Sahara - 15X8 Cragar soft 8s w/ Toyo OP M/T 35/13.5R15, 2" BB w/Superlift Shocks. 2007 Stone White Unlimited X - 15X8 Cragar soft 8s w/ Toyo OP M/T 33/12.5R15, 2" BB w/Superlift Shocks. 1982 CJ-7 Renegade - Dissasambled and waiting for an infusion of $$$$ *SOLD* 2006 Silver SW Rubicon *Crashed* 1997 White TJ Sport |
#8 |
Gold Member
As for as size goes, 286/65-18 will fit just fine. BFG All Terrains will suit you nicely because they are quiet which is good for a daily driver and give good all around performance and good looks. Check out www.tirerack.com
285/65-18 comes out to be 32.5" tall, which is a little taller than your stock tires. Width will not be an issue.
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#9 |
I hope the choice in 18" tires gradually gets better. Pretty much all the tires mentioned are not available in any 18" even remotely close to 255/70-18. The All Terrain TAs seem best way to go for now.
#10 |
I went to a local off road shop. They told me that the '08 Sahara unlimited can't have 16" wheels. Is that true? That would limit a lot of tires and wheels.
-Chuck |
#11 |
Go Wolfpack
#12 |
#13 |
Thanks for the replies. I wonder if there is a difference between the 2 and 4 door when it comes to wheels. I wish I knew where to look it up.
-Chuck |
#14 |
I just called 4wd.com and they weren't sure if the 08' sahara's had different rotors that were too large for 16" wheels. I can't find any info on the change.
-Chuck |
#15 |
Per Jeep brochure and Jeep.com. The 2008 JK 2dr Sahara and Unlimited Sahara have the same size brakes, etc. as far as wheel fitment, same brakes as the 2008 2dr and 4dr X.Stock wheel on Unlimited X is 16", stock wheel on Unlimited Sahara is 18" and stock wheel on Unlimited Rubi is 17". JK have bigger brakes than the TJ so that may be what's confusing some people. So 16" will fit, but maybe not the ones the 'local shop' sells. Not all 16" are the same, but obviously there are some that fit the Unlimiteds. Shop elsewhere than this 'local shop'. PM some of the other folks on this forum who have JK Unlimiteds and have oversize tires on their rigs. Some folks use 15" with huge tires if you want a mall crawler's tires to really stand out.
Sixth Jeep Last edited by wyocommander; 02-12-2008 at 06:24 PM.. Reason: added data |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
