a bumpy ride home - JeepForum.com
post #1 of 10 Old 06-02-2010, 11:09 AM Thread Starter
LovinFirstJeep
a bumpy ride home
so last night i went fishing. and on the way back home this is what i had to deal with.
i just tied it up with some wire and took off the shock at home.
LovinFirstJeep is offline
post #2 of 10 Old 06-02-2010, 11:15 AM
plac
at least it was just the shock which is easily replaceable.
2015 Subaru WRX
plac is offline
post #3 of 10 Old 06-02-2010, 11:23 AM
1222
RIP John
1222's Avatar
Your shocks must me acting as the bump stops.
(2011-2016)
1222 is offline
post #4 of 10 Old 06-02-2010, 11:34 AM
plac
ya, its almost impossible to break a shock like that unless you were doing heavy offroading.
2015 Subaru WRX
plac is offline
post #5 of 10 Old 06-02-2010, 11:39 AM
1222
RIP John
1222's Avatar
When you raised your Jeep 2-1/2 inches did you add bump stop spacers to compensate? Looking at one of your other pics it doesnít look like it.
(2011-2016)
1222 is offline
post #6 of 10 Old 06-02-2010, 11:54 AM Thread Starter
LovinFirstJeep
yeah i didnt add bump stops. but the road i was on when it broke, is flater then flat.
post #7 of 10 Old 06-02-2010, 12:50 PM
1222
RIP John
1222's Avatar
That doesnít matter. Most likely the major damage to the failed shock had been done before your fishing trip. It just happened to be the last straw and failed. If you donít correct the problem more things will break. Next time it just might be the mount itself. You have to pay attention to the small stuff. Itís all related and needs to be corrected.
Every time the shock acts as a bump stop itís a very violent hit. Something has to give. This time your shock, next time the mounts.
(2011-2016)
1222 is offline
post #8 of 10 Old 06-02-2010, 02:02 PM Thread Starter
LovinFirstJeep
yeah i know what u mean. ill be gettin all new lift real soon anyway.
post #9 of 10 Old 06-02-2010, 09:06 PM
medcop
I broke a bar pin on my RC shocks and was NOT wheeling at the time. The bar pins are a weak point in my opinion. Also, I know my shocks are not acting as bump stops.
Get a bar pin eliminator and be one with the crappy design of the bar pin itself.
medcop is offline
post #10 of 10 Old 06-02-2010, 11:03 PM
1222
RIP John
1222's Avatar
You donít have to be ďwheeling at the timeĒ for a bar pin to break. Iím not saying that for absolute certainly that the shock is acting as the bump stop, just most likely since the Jeep was lifted. Did you ever actually check the length of up travel on you stock shocks? Thereís a reason that bump stops are included in most kits. Theyíre not just for limiting coil compression. If you donít wheel it then most likely you can get away without them. Why chance it though?
(2011-2016)
1222 is offline
bumpy ride!!! johnch0512 JK Wrangler Technical Forum 20 04-20-2010 11:34 AM
Air Noise/bumpy Ride Destruction JK Wrangler Technical Forum 13 04-08-2008 03:45 PM
Why is my jeep ride so BUMPY!!! bumblebee92gt TJ Wrangler Technical Forum 19 05-16-2005 11:39 AM
33's=bumpy ride?? clarky711 YJ Wrangler Technical Forum 1 02-24-2003 02:36 PM
bumpy ride-please help!!!! tcross34 TJ Wrangler Technical Forum 3 03-22-2002 06:26 PM
