Bumper/winch too much weight? - JeepForum.com
post #1 of 10 Old 03-12-2011, 04:34 PM Thread Starter
durable1
I am probably going with a Rubicon when I get my severence check from work this summer. I want to remove the front bumper right away then get an after market bumper and a winch. Will I need to do anything to the suspension because of the added weight? If so, how involved?
durable1 is offline
post #2 of 10 Old 03-12-2011, 05:24 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Get some leveling spacers for the front springs - the amount of height needed would be based on before and after measurements...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 10 Old 03-12-2011, 05:44 PM
Vin
A little more height would be nice, but you don't drop that much.
Vin is offline
post #4 of 10 Old 03-12-2011, 06:00 PM Thread Starter
durable1
I don't really like either stock bumper. So...when I replace the rear I should add spacers there too? Or, better yet, just do both at the same time I guess.
durable1 is offline
post #5 of 10 Old 03-12-2011, 06:24 PM
RockyClymer
RedRock4Wheeler
The stock JK has some rake to it from the factory - also, you probably won't be putting a winch on the rear, so, if you want keep the rake the same, I would measure before and after bumpers and winches and then determine what you need to get back to those dimensions.
NRA Life member
post #6 of 10 Old 03-12-2011, 07:03 PM Thread Starter
durable1
Makes sense. Thanks!
durable1 is offline
post #7 of 10 Old 03-12-2011, 08:53 PM
ColoradoTJ
ColoradoTJ's Avatar
I just put on an Expedition One Basic Dx bumper and Superwinch ep9 with Viking rope. My Jeep set level before and experienced no sag after install. A lot depends on the weight of the winch and bumper. My new bumper is not much more than a winch mount. The Viking rope saves a good bit of weight over the standard steel cable.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #8 of 10 Old 03-13-2011, 08:30 AM
IndianaJeepJK
2009 JK Wrangler
i have a set of(4) 3/4 daystar spacers for sale ($40shipped) that would sit on top of your springs...you could just put the front 1's on since that's probably the distance you'll sink down with the new bumper and winch.
2009 JKU 2.5TF,1.25BL by RC, ORFAB Stubby, Superwinch, 35" Toyo MTs, 16" Black Rock Steelies, etc. etc....
www.OFFdutyOFFroad.com
IndianaJeepJK is offline
post #9 of 10 Old 03-13-2011, 08:32 AM
IndianaJeepJK
2009 JK Wrangler
x2 the rope vs. steel cable saves about 40lbs I think i read somewhere in stats for the same winch but with different rope/wire set ups.
post #10 of 10 Old 03-13-2011, 09:39 AM Thread Starter
durable1
ColoradoTJ,
I just checked this bumper out. It may be for me. I see an option is for "wings" but they show no pics.
How do you like the Superwinch?
durable1 is offline
JK Bumper/winch weight problem noah2626 JK Wrangler Technical Forum 28 03-09-2011 06:10 AM
Spring Rates V. Travel (weight of bumper & winch) Running925 TJ Wrangler Technical Forum 17 08-12-2010 01:03 PM
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 01:35 PM
Rugged Ridge XHD Non Winch Bumper Stronger than Bumper w/ Winch Plate??? mlupacchino JK Wrangler Technical Forum 7 04-21-2009 06:01 PM
Extra weight on Rear Springs compared to front springs (winch compared to bumper) Sparty TJ Wrangler Technical Forum 3 12-17-2005 07:03 PM
