Bumper Sag with Mopar Offroad Bumper/Winch? - JeepForum.com
post #1 of 9 Old 09-11-2007, 08:44 AM Thread Starter
rchs.band
rchs.band's Avatar
I installed the rear Mopar Offroad Bumper and love it...
Now, I want to install the front Mopar Offroad Bumper and add a winch down the road. Will this cause any bumper sag? If so, what can I do and how hard is it to make right?
Thanks!
2007 Wrangler Unlimited Rubicon
rchs.band is offline
post #2 of 9 Old 09-11-2007, 10:16 AM
wrnglrguy
wrnglrguy's Avatar
The weight might cause the springs to sag a little. If it does, a cheap easy way to fix it would be 3/4" spring spacers in the front. That might require you to change shocks up front (to account for the longer travel), but I doubt it since you will have the winch on there. I am lifting my Jeep next month and will be adding the spacers up front at that time so when I do add the winch, it won't sag.
wrnglrguy is offline
post #3 of 9 Old 09-11-2007, 10:23 AM
BrettDez
I do have that bumper and a winch installed. I have a 3/4" to 1" sag right now. Where can I order these spacers you mentioned? ANd how difficult or easy is the install? The sag is noticable because I park my 07 Rubicon right next to another 07 Rubicon, easy to spot my sag, lol.
-Brett
My Jeep: 2012 Jeep Wrangler Unlimited Rubicon, 6-Spd Manual, Cosmos Blue
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #4 of 9 Old 09-11-2007, 11:42 AM
wrnglrguy
wrnglrguy's Avatar
Try these websites. You can Google search 2007 Jeep 3/4" spacers.....
http://www.4wheelerssupply.com/catal...h/471_1_36_529
http://www.bizrate.com/automotiveper...520446441.html
http://www.jcwhitney.com/Coil-Spring...cw?TID=8073560
post #5 of 9 Old 09-11-2007, 11:46 AM
jdrogers
You can get 3/4" spacers from your local dealer for about $6 each. Just order two additional front coil spring isolators. Stack these on top of the existing ones.
They look like this:
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #6 of 9 Old 09-11-2007, 01:04 PM
BrettDez
Would getting stiffer coils instead of adding spacers have any advantage? (If there are any stiffer than the stock rubicon coils)
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #7 of 9 Old 09-11-2007, 03:03 PM
jdrogers
Stiffer coils have the advantage of retaining or increasing the suspension travel.
I ended up using stiffer coils on my Rubicon. Adding the bumper with a Superwinch EPi9.0 caused the front to sag 3/4" from stock. I had always felt the front was much lower than the rear on my JK so I replaced the coils with much stiffer ones. Now my front is 2" higher than it was stock. The JK is just about level. The front "looks" a little high so I have some new stiffer rear coils I will be installing soon...
Scottsdale, AZ
jdrogers is offline
post #8 of 9 Old 09-11-2007, 03:20 PM
BrettDez
Do you happen to know the part number for the stiffer coils...though I don't really want to be 2" higher than original in the front...anyone know any coils that should bring me back to normal? I want to retain my suspension travel for flexing, but also would like to return to normal height.
-Brett
"The Smurf":
Previous Jeeps:
BrettDez is offline
post #9 of 9 Old 09-11-2007, 06:11 PM
roketman
I have the Mopar bumper with a Warn winch. When I had my lift installed, the front end still sagged. A 3/4 spacer leveled it up perfect.
02 Yellow TJ Sport. The axles and transfer case are 2004 Rubicon with Solid diff covers. Rubicon Express 5.5 long arm with Rancho 9000 shocks. PSC hydraulic steering. Poison Spyder tube fenders rockers and crusher corners. Blue Torch Fab front stubby, winch plate, and rear bumper. ORF cage with Rockhard harness bar. Corbeau CR-1 seats with Corbeau 4 point harness. 35" Hankook MTs on Raceline Rock Monster beadlocks. Warn M800 winch.
roketman is offline
JK / Mopar - Winch & Bumper Filmpros JK Wrangler Technical Forum 40 12-03-2010 12:27 AM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 05:33 AM
Need Winch Options For Mopar Offroad Bumper JackBauer JK Wrangler Technical Forum 8 11-18-2009 11:51 AM
Mopar Front Offroad Bumper Q Fog Light Q rchs.band JK Wrangler Technical Forum 11 09-29-2007 10:45 PM
Mopar Offroad Winch Bumper - Fog Lights Question BrettDez JK Wrangler Technical Forum 9 08-17-2007 09:59 AM
