Building Rock Rails - Page 4 - JeepForum.com
post #46 of 56 Old 12-14-2010, 06:29 AM
thedirtman
thedirtman's Avatar
To help you visualize your projects use cardboard and masking tape to build it first. I have also used wood but old boxes are cheap and are closer to the thickness of steel. If you don't have any go to your local recycle center and get some.
If you learned something new today, you had a good day.
thedirtman is offline
post #47 of 56 Old 12-14-2010, 06:54 AM
Warlord2
There is a posterboard thats foam, rigid and 3/16" thick that Ive been finding very helpful. Can be found at like arts and crafts stores for cheap. A sharp exacto knife will cut it easy and clean as well.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #48 of 56 Old 12-14-2010, 06:55 AM Thread Starter
paul84043
Wow, you know, I had never even considered building a mockup first.... good idea!
paul84043 is offline
post #49 of 56 Old 12-14-2010, 07:28 AM
mav383
2009 JK Wrangler
NEW Sliders
Made these a few weeks ago. Didnt have time to do the round step thing but that will be soon. They are made of 2" square 5/16 wall tube. I mounted them alot like the rubicon sliders, to the body only, along the pinch seam with supports running inward to the body.
It'll Buff Out!!
mav383 is offline
post #50 of 56 Old 01-29-2011, 09:11 PM Thread Starter
paul84043
Well, it's been a nasty cold winter and no time to work on the rails....
Finally got a 40 degree day so we cleaned up the rails and got them primed.
They look awesome, I actually really like the white primer, too bad there's no way to keep that looking good!!
Just a little touch up on the primer and another warm day to get the bedliner rolled on...
post #51 of 56 Old 01-29-2011, 10:40 PM
1222
RIP John
1222's Avatar
From the pic they look like Rubi rails. Great job.
(2011-2016)
1222 is offline
post #52 of 56 Old 01-29-2011, 10:44 PM
1222
RIP John
1222's Avatar
Originally Posted by paul84043 View Post
...I actually really like the white primer, too bad there's no way to keep that looking good!!
Those do look terrific all primed up but you’ll actually like them more with the final finish. Nice work.
(2011-2016)
1222 is offline
post #53 of 56 Old 01-30-2011, 12:07 AM Thread Starter
paul84043
I can't wait to get them on, my 6 year old daughter keeps bugging me about getting the "step" on the Jeep. With the temps we've been having, I need to make sure they have plenty of time to cure. We'll probably do the bedliner, and then after a day or so bring them into the basement and let them sit for a week or so...
I'm the most impatient person on the planet....ugh...
Protip.....if you're doing something like this, buy TWO different colors of the same kind of primer....spray one color on the first coat, then the other for the second.. I thought of this when I was attempting to put on the second coat and couldn't tell where I'd covered...
Hindsight...
post #54 of 56 Old 01-30-2011, 12:07 AM
voodooJK
Nice work!
Colorado Jeep Club member #959
Originally Posted by Willy Wonka View Post
What you are witnessing, dear friends, is the most enormous miracle of the machine age.
voodooJK is offline
post #55 of 56 Old 01-30-2011, 12:22 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
I always use a dark color primer under a black finish, I learned this along time ago with scratches showing as a light grey mark.
You did a great job
We look forward to seeing more builds from you!
Jim
JLC08JK is offline
post #56 of 56 Old 10-02-2013, 08:53 AM
S_Bartfast
Sensational effort there!!!
Has there been any progress in the last couple of years?
Also, could I get detailed measurements from you?
I'm interested in building exactly what you have there and would like to knock up some plans on my computer.
If you could, could I get you to measure and note down all the dimensions and I will make a set of plans for any other would be backyard fabricators to follow. Things like steel thickness, distances between holes (centre to centre) and angles of cuts. I know it's not the way you worked your self, but I have been building a roof rack for my JK and have found having a computer model of the design invaluable. Any plans I create I will of course make freely available.
In any event, I'm really impressed with your work.
S_Bartfast is offline
2011 Unlimited Stock Rubicon rock rails along aftermarket rails. theplasterman JK Wrangler Technical Forum 6 12-06-2010 07:20 PM
Rock Rails blackruby56 TJ Wrangler Technical Forum 20 10-16-2009 11:00 AM
rock rails on my new ruby (Stock steps with stock rock rails?) captbobrcc JK Wrangler Technical Forum 2 11-23-2008 09:39 AM
rock rails over stock rubi rails redmuddog JK Wrangler Technical Forum 8 12-02-2007 07:35 PM
daystar rock krusher rock rails? hansimusmaximus TJ Wrangler Technical Forum 0 03-30-2006 11:00 PM
