Building a correct lift - JeepForum.com
post #1 of 18 Old 01-21-2014, 07:42 AM Thread Starter
zpayne08
I'm getting ready to buy a lift and want to make sure I have everything covered. Here's the parts list:
Teraflex 2.5" cool lift with no shocks
Bilstein 5100 shocks front/rear
Bilstein steering stabilizer shock
Front trackbar
Rear trackbar
Front lower flexarms
Eventually QD sway bars
Do I not need the front upper flexarms or rear upper/lower flex arms??
zpayne08 is offline
post #2 of 18 Old 01-21-2014, 08:38 AM
COLOUXJ
2010 JK Wrangler
If your stock steering stabilizer is in good shape you do not need to replace it. But that is a good starting point. Pretty much the setup I have now minus the front trackbar.
COLOUXJ is offline
post #3 of 18 Old 01-21-2014, 08:39 AM
MikeHoncho88
2015 JK Wrangler
2 door or 4 door?
rear upper flexarms if its a 2 door. teraflex install instructions have a chart for which arms they recommend for which version of the jeep. Or just do all 8.
“Race fans, I had inferred from my one trip to the Brickyard 400, fell into one of two categories: tattooed, shirtless, sewer-mouthed drunks, and their husbands.” - Steve Ruchin
MikeHoncho88 is offline
post #4 of 18 Old 01-21-2014, 09:10 AM Thread Starter
zpayne08
It's a two door. I've been talking to a teraflex rep over the last couple weeks but want other opinions. I can't afford to do all the extra stuff at once so I'm probably on a start with the lift/shocks and the front lower arms and track bar. May go with upper arms in front too just to finish the front out.
Another question is since it has a daystar spacer lift how do I know which parts are factory and which is the spacer lift when I have the jeep in my shop for surgery?
zpayne08 is offline
post #5 of 18 Old 01-21-2014, 09:13 AM Thread Starter
zpayne08
Oh, and I forgot about the exhaust. If I get the 2.5" AFE hi-tuck catback will that work without the spacer? I want an exhaust anyways so figured I'd knock it out of the way next paycheck
zpayne08 is offline
post #6 of 18 Old 01-21-2014, 09:46 AM
ROCKR8R
Steering stabilizer is a waste of money unless yours is crushed.
What size tires are you running and your gear ratio?
-Dan
ROCKR8R is offline
post #7 of 18 Old 01-21-2014, 09:57 AM
duneslider
Haven't there been a lot of negative reviews of the bilstein stabilizer, creates a pull to one side because it is a nitrogen charged shock? Maybe this is just an internet rumor?
I got a new rancho one for free when I ordered my rancho shocks and I noticed zero difference between the stock and new one.
duneslider is offline
post #8 of 18 Old 01-21-2014, 10:03 AM
ferninaz
ferninaz's Avatar
Front trackbar
Rear trackbar
You probably do not need the stabilizer unless you have a damaged one. I would spend that money to buy a bracket to move the steering stabilizer up and out of the way.
Why get a new rear trackbar when you can get a bracket that lifts the trackbar. The stock one will work for you for now.
I would get the QuckDisconnects early in your build, you will flex more and the ride is a lot more enjoyable off road with the front sway bar disconnected.
If you are going to get the control arms, I advise you get all 8 and be done with it. I don't know that you need them though, mine have 30000 miles on them and they are still in good shape minus the lower fronts which I replaced because of some trail damage.
Good luck making decisions on all this stuff.
ferninaz is offline
post #9 of 18 Old 01-21-2014, 10:13 AM Thread Starter
zpayne08
I'm runnin 33x12.50r17 Mickey Thompson MTZ with 3.21 gears and stick shift. The dealer put it all on when they got it new. If that's the case I'll just leave the stabilizer alone for now
zpayne08 is offline
post #10 of 18 Old 01-21-2014, 05:41 PM
Maertz
2009 JK Wrangler
sell the stock stabilizer also and spend the money elsewhere...
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #11 of 18 Old 01-21-2014, 05:50 PM Thread Starter
zpayne08
thinkin about saying screw it and just buy it all lol. getting the kit, bilsteins, trackbars, and the control arm kit. taxes are coming up plus im getting some $$$ back on an extended warranty that had 4 years left on a vehicle i traded in.
will the AFE exhaust be enough to miss the drive line boot or will i still need spacers?
zpayne08 is offline
post #12 of 18 Old 01-21-2014, 05:57 PM
MikeHoncho88
2015 JK Wrangler
The catback isn't the part that needs a spacer. The Y pipe is the part that needs to be replaced. As far as I can tell the AFE catback doesn't include the Y pipe, although they do sell a Y pipe separately. The spacers teraflex sells work fine and are cheaper than a y pipe.
post #13 of 18 Old 01-21-2014, 06:24 PM Thread Starter
zpayne08
oh ok. thatll cut down the price a few hundred bucks. i mean i will eventually put on an exhaust but its not a priority if it needs spacers anyways. i looked on their website and only saw the y pipe for the 4 door, maybe i missed it
zpayne08 is offline
post #14 of 18 Old 01-21-2014, 06:46 PM Thread Starter
zpayne08
and since shocks are new (jeep has under 7,000 miles) i may spend an extra $7 on the lift with shock extensions and use the stock shocks for a while until i free up $350. it is the exact same kit other than the adapters correct?
zpayne08 is offline
post #15 of 18 Old 01-21-2014, 07:20 PM
MikeHoncho88
2015 JK Wrangler
IIRC The kits are the same with the exception of the shocks. The Bilsteins are good. They are noticeably better then the Teraflex shocks. I would guess the stock shocks would ride pretty well with the extensions. I'd like to try Rancho Shocks next, everyone loves them, and they are adjustable.
2.5 , coil , jk , lift , teraflex
