Bug-Out! Build - JeepForum.com
 3Likes
post #1 of 199 Old 08-28-2013, 09:57 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
Bug-Out! Build
Made my choices ... started buying stuff.
I read all I can read and I can't handle any more opinions! I decided what I'm doing for my Jeep.
First I am naming it Bug Out! Many of my friends have bug out bags and such and I guess I do too if you count my hunting gear bags. But what good are bug out bags if you can't go anywhere? So I bought my JKU in Commando Green back in May. I will have work on decals for the name.
Bug Out!, Bugout! or Bug-Out! - not sure yet...
Lift Kit:
I decided on a 2.5" TeraFlex coil lift. http://www.quadratec.com/products/16190_2501_07.htm I can do the shocks later if I need to.
I can't afford new wheels all around at this point, so I'll stick with the stock 32's (255/75R17 OWL) and install Spidertrax spacers. The spacers showed up today. Eventually, when the cash becomes available I'll get proper wheels and 33" tires.
Armor:
Previously I had installed Smittybilt SRC Side Armor.
I still have not decided on bumpers - but I don't have the cash for those yet so I have time to figure it out.
Installing:
So this evening I decided to simply install those spacers. After two hours in the heat and humidity I finally found my tools. For the life of me I could not find my 3/4 deep well impact socket. Without that the lugs nuts were staying put. I've been putting it off but I finally HAVE to clean my garage. Maybe this weekend? By the time I found what I needed it was dark and I was sweaty and hot. I did the fronts tonight. Tomorrow it will be nothing to do the rears. At least I know where my tools are now.
Next month I should be able to buy the lift kit. I hope it's cooler when I try to install that.
It's a small "build", but it's my build and my budget.
Photos: https://www.flickr.com/gp/40875543@N02/R6m57L
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out!
I don't always go topless, but when I do I go Commando!
wilgeno is offline
post #2 of 199 Old 08-29-2013, 06:10 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
It's the little things - like being able to find your tools!
Took 20 minutes in the sauna like weather to install the rear wheel spacers. Beer me!
Bug-Out!
wilgeno is offline
post #3 of 199 Old 09-08-2013, 01:15 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
Ordered parts
I have a sickness and it must be cured! With more Jeep parts! Just ordered a lift kit, TeraFlex 2.5" coil lift, from 4WheelParts. I was able to get 5% off and free shipping! Now the tough part comes - W A I T I N G
Bug-Out!
wilgeno is offline
post #4 of 199 Old 09-08-2013, 02:45 PM
4wdjeepguy
I'd install the Teraflex rear track bar bracket brace instead of the drop bracket they include.
4wdjeepguy is offline
post #5 of 199 Old 09-08-2013, 03:15 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
This lift comes with just the one rear track bar bracket, drivers side I think. They sell a separate track bar bracket for the other side. Is this what you're talking about? http://www.quadratec.com/products/16191_9011_07.htm
Bug-Out!
wilgeno is offline
post #6 of 199 Old 09-08-2013, 03:29 PM
4wdjeepguy
Yep. You're just adding extra stress to the frame side bracket with the included drop bracket. The brace you linked is what I was referring to. It will prevent your axle side bracket from failing and will still allow you to recenter your rear axle.
post #7 of 199 Old 09-08-2013, 03:48 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
Thanks for this info. I am a total noobie with this stuff. I grew up in my Dad's gas station garage, but today I'm a pure computer geek. I can read and research anything but I have no experience in actual setups. Part of the reason I am choosing Teraflex is recommendations in these forums and in part the TeraFlex YouTube videos. They offer a lot of information that appears to be more than just promotional. This video taught me a lot.
One question. Can this part be added later on? It looks like it. I'm not in a huge hurry to go rock crawling. We just get a lot of snow in MN.
Bug-Out!
wilgeno is offline
post #8 of 199 Old 09-08-2013, 05:14 PM
4wdjeepguy
You can add it later, but you'll have to remove the drop bracket. I'm just recommending it now so you don't have to drill a hole in your existing frame side bracket to install the drop bracket.
post #9 of 199 Old 09-08-2013, 05:50 PM
gwar11d2
2009 JK Wrangler
The kit comes with drivers side axle bracket...at least mine did a couple years ago. I dont think they do the drop bracket anymore...
Edit: pic on quadratec looks like the drop bracket... hmm
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #10 of 199 Old 09-08-2013, 05:57 PM
4wdjeepguy
Sorry just saw you wrote that you're going with the coil lift. I saw "shock extensions" and assumed it was the BB. You should get the brace I was talking about with your kit.
Can't delete this comment since I'm not a premium member..
post #11 of 199 Old 09-08-2013, 06:00 PM
4wdjeepguy
The quadratec lift he originally referenced comes with the frame side drop bracket. Not the axle side track bar brace.
post #12 of 199 Old 09-08-2013, 08:48 PM
Vin
IIRC Teraflex sells the axle side bracket with the coil lifts and the drop bracket with the Spacer lift now.
Vin is offline
post #13 of 199 Old 09-13-2013, 08:52 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
UPS came to my house today! I think my weekend plans are set.
Bug-Out!
wilgeno is offline
post #14 of 199 Old 09-14-2013, 08:44 AM
4wdjeepguy
Looks like I was right
post #15 of 199 Old 09-14-2013, 02:13 PM Thread Starter
wilgeno
Bug-Out!
wilgeno's Avatar
Yes, only the frame side trackbar bracket. Oh well. I'll do the other later if I need.
So far today I'm working on my Jeep. The lift kit is about 1/2 installed just a little more to do on the rear before doing the front. So far it's going in without issues.
Bug-Out!
wilgeno is offline
