#1 | ||
Budget Co2 system
Got mine in.
Tank = $85 (http://www.beveragefactory.com/draftbeer/tanks/co2.shtml) Regulator = $38 (http://www.wheelersoffroad.com/co2systems.htm) 30ft hose = $38 (http://www.wheelersoffroad.com/co2systems.htm) Those above are the bare minimum requirements (fyi- the hose comes equipped with an end for filling tires, so you wouldn't even have to worry about buying that). So for under $200 you can have the minimum requirements. It cost me $7 at a welding supply shop to have the tank filled (10lb tank) In my case, I added to it PowerTank HD tire inflator (Thanks to 1222 for pointing me to this item Heavy duty mounting bracket = $40 (http://www.outbackequipped.com/accessories.asp#bracket) So even with these additions, I still am a lot less than a comparable Powertank system. Now where I wanted to mount the bracket, it would not work due to the design of the floor. So I had RockRash 4x4 fix it up for me- he welded on a "foot" to the front edge of the bracket. Then he powder coated it because the welding (of course) messed up the paint. ![]() ![]()
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
#2 |
Make mine a Jeep!
Nice air set-up. I like it. I had considered something similar at onetime. A couple of question though. How do you like the air hose? Is it the small diameter hard plastic type or is it kind of soft and pretty flexible (which I want)? The reason I ask is because I’m looking for a little longer hose than I have now and the price you paid is a good one plus it looks good in the pics.
Oh yea, about the fire extinguisher mount, who makes it. Thanks. |
#3 |
nice system you put together there
2001 XJ... 3.5" RE Lift, 31" BFGs, Bilsteins, Defender roof rack, Dana 30 HP front True Trac and 4.10s, Dana 44 Rear True Trac 4.10s, SYE, tom woods D/S, SUPER CLEAN LOW MILES |
#4 | ||
Not sure who makes the mount. I just bought it from that website posted in the description above.
#5 |
Gold Member
Maybe this is a silly question, but here it goes anyway. Why CO2? Why not just a portable air tank you can fill up at home with a compressor or at gas station for free or twenty five cents. Is there a connection on the bottle you have that you can just fill up with air from a compressor instead of CO2?
2007 Black Unlimited Sahara, Black Hard Top, Khaki Soft Top, Khaki Interior, 3" Black Diamond Springs and sway bar links, Rancho Steering Stabilizer, Helo Black Maxx 6 17 X 9 wheels, BFG AT TA KO 315/70-17 Tires, Poly Peformance High Steer Kit, Poly Performance Upper and Lower Front and Rear Adjustable Control Arms, Poly Performance Rear Track Bar Bracket, Poly Performance Chromoly Tie Rod, Offset Upper Ball Joints, Mopar Front and Rear Bumpers and Skid Plate, Warn 9.5ti winch, ARB High Output Compressor with tire inflation kit, PIAA 510 SMR Fog Lights , Silverstar Headlights, Bilstein 5100 series shocks, 5.13 gears, Alpine IDA-X001, Infinity 6020CS, Infinity 6022si, Alpine MRP-F250, JBL P1024, Alpine MRP-M650 http://www.jeepforum.com/forum/f129/hothead-headliner-1237401/ http://web.me.com/stevenpeltierjr/Living_It_Up/Welcome.html |
#6 | |
A 10lb bottle of CO2 will fill up 12 of my 35" tires from 6.5 pds to 29 pds.
#7 | ||
I have a 7 gallon air tank in my garage that I use on my motorcycles- works perfectly for that. But... The stations around here that have air, the air is $1 (not twenty-five cents unfortunately), and it requires $2 worth to fill the 7 gallon tank. And then (I discovered) a 7 gallon tank (which is a pretty big tank) is only good for a single 35" tire Before getting the Co2, I have been using this portable compressor: http://www.jcwhitney.com/SUPERFLOW-HEAVY-DUTY-AIR-COMPRESSOR/GP_2012883_N_111+10201+600017719_10101.jcw But it is pretty slow- takes 4-5 minutes to air the 35's from 15psi to 30psi. Plus now my wife is also wheeling her JK, and we discovered that the compressor will over heat and shut off after airing up 6 tires- leaving one of us (me) to drive with 2 tires at 15psi to go find a gas station and pay $1 for air ![]()
#8 |
that sux, in California air is free if you ask the cashier. I believe its the law here to help with people rolling around on flat tires and prevent a blow out.
Thats a cool setup, I may have to copy you.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights. |
#9 |
Rock, nice. I'm sitting here looking up mounts for my Viair, and trying to figure out where to mount my tank. Now you have me thinking
, hope you and Mrs. Rock had a great Christmas, stay out of trouble tomorrow night.Matt
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest. 2002 Wrangler Sahara RIP 1979 CJ 7 258 RIP 1975 Cherokee S 401 RIP |
#10 | |
Locked @ both ends
#11 |
Thats what I pay. Oddly enough though I have found prices from 1-4 bucks per pound... CRAZY
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
