Budget boost or just wait - JeepForum.com
post #1 of 10 Old 07-15-2013, 10:03 PM Thread Starter
Ibanez0154
I was debating doing a BB to give my rig some more ground clearance. Obviously my budget is tight for this right now. Is it worth to do a BB or should I just wait to do a 2.5" lift. Also, if I did a BB, could I do a lift on top of that?
Ibanez0154 is offline
post #2 of 10 Old 07-15-2013, 11:52 PM
SilverStreaker
I've had the 2.5" bb from Teraflex for over a year and have not had any issues. My plan has been to upgrade parts as needed and I just had to order a synergy drag link but that's all I've had to get so far. On my list is upgraded shocks, heavy duty track bar and other parts that would have come with a complete lift but like I said its been a year and I've been able to spend the money saved on a lot of other "essentials" for my jeep.
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #3 of 10 Old 07-16-2013, 12:20 AM
CJATE
I'm in the middle of a BB. Tires and wheels are the expensive part.
Just get wheels and 33's, when they are slick, then do lift and 37's
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #4 of 10 Old 07-16-2013, 07:06 AM
222Doc
222Doc's Avatar
the synergy drag link is a FLIP drag link. You will need to drill the knuckle side out or ream that. You must also raise the trackbar mount UP to keep the relation of the two parallel. If not BUMP steer will be a issue.
If you added a BB on top of say a 2.5 spring you are now at 4.5 lift and will need MANY things. cardan drive shafts. track bars the list grows as the lift goes up.
222Doc is online now
post #5 of 10 Old 07-16-2013, 07:31 AM
ncb
I'm thinking about purchasing the Synergy DL. I thought the instructions stated it can be installed in stock configuration vs. being flipped.
ncb is offline
post #6 of 10 Old 07-16-2013, 08:45 AM
SilverStreaker
You are correct. I will be installing mine in the Stock configuration.
post #7 of 10 Old 07-16-2013, 10:58 AM
SLADE
If you can, start off with coil springs. It's better to start with a coil and fine tune with a spacer.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #8 of 10 Old 07-16-2013, 01:47 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
If you ever plan on upgrading, go with coils.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #9 of 10 Old 07-16-2013, 05:51 PM Thread Starter
Ibanez0154
Thanks for the feed back everyone. I'm still undecided on what to do.
post #10 of 10 Old 07-16-2013, 06:21 PM
Tanimal
You don't have to flip it. You can use it in the stock position. As long as your drag link is parallel with your track bar or pretty close.
Learning as I go and it's worth every penny!
Tanimal is offline
