Budget Boost and Body Lift question - JeepForum.com
post #1 of 6 Old 10-27-2007, 09:06 PM Thread Starter
rooster5333
rooster5333's Avatar
Ive got the Teraflex BB and 33's. Just not as big as I wanted now that its done. So now Im going 35's but I want more lift as well. That in mind if I go with a 1" body lift what if anything will I need to do? What do i need to take into consideration?
If I have to make major changes Im just going to take the Teraflex BB off and go with the Black Diamond kit.
Thanks for the help...
rooster5333 is offline
post #2 of 6 Old 10-28-2007, 11:03 AM
scrogg
The 2.5" BB will allow for the 35" tires.
You should be able to install the body lift with no other issues. No extensions of any kind needed anywhere.
scrogg is offline
post #3 of 6 Old 10-28-2007, 11:28 AM
UTAH
UTAH's Avatar
I have the 1" M.O.R.E. body lift.
Since you have the auto trans, a 1" body lift should be a piece of cake and require no other mods. The JK auto trans is cable-activated so won't need linkage changes, same with the transfer case.
The JK is real easy to body lift because of other things as well: The radiator fan is electric and is attached to the body along with the radiator, so you don't need to redo the mounts. And, all the body mounts are easy to get to (but you do need to remove the front grill to get to the front mounts).
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #4 of 6 Old 10-28-2007, 02:00 PM
davenkodi
so i have googled this m.o.r.e. lift and can't seem to find it anywhere.... any help guys?
davenkodi is offline
post #5 of 6 Old 10-28-2007, 02:46 PM
Marauderk
http://www.mountainoffroad.com/more.htm
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
post #6 of 6 Old 10-28-2007, 03:11 PM
davenkodi
thanks a lot.
Body lift VS. Budget Boost jake7893 TJ Wrangler Technical Forum 48 08-20-2009 07:59 AM
What's the difference between a Budget Boost and a Body Lift staquinas TJ Wrangler Technical Forum 26 08-06-2009 01:14 AM
Jeep (budget boost or body lift) JCWrestler TJ Wrangler Technical Forum 14 07-02-2008 05:20 PM
body lift or budget boost RON310 TJ Wrangler Technical Forum 15 10-17-2007 09:29 PM
Budget Boost & Body Lift Bad Idea? DesertTJ TJ Wrangler Technical Forum 17 02-24-2007 05:25 AM
