Broken Plastic piece around stick shift - JeepForum.com
post #1 of 11 Old 04-22-2009, 04:10 PM Thread Starter
JLCJ7
That cheap looking black plastic bezel piece is pulling up around my gear shift causing the rubber boot to pull out. It looks like the plastic clips or whatever holds it are broken.
I found this one but it is $70 and alluminum. I have not seen anyone who sells the black ones yet. Havent checked the dealer since Im sure its way over priced.
JLCJ7 is offline
post #2 of 11 Old 04-22-2009, 04:10 PM Thread Starter
JLCJ7
ok link didnt post here it is:
www.quadratec.com/products/52110_900.htm
JLCJ7 is offline
post #3 of 11 Old 04-23-2009, 07:17 AM
fernjack
Had mine replaced on waranty but when it happens again I`ll go with the billet one.
fernjack is offline
post #4 of 11 Old 04-23-2009, 09:14 AM
wilywillie
Mopar= $20 from dealer. Whole clamp and boot.
I broke mine getting the boot off to swap out the console. The "bezel" is just a clamp for the base of the boot (can't be seperated), and slides/clicks into the forward console.
My PROBLEM is the rubber boot being stiff, and popping the stick out of 1st and 3rd.
wilywillie is offline
post #5 of 11 Old 05-04-2009, 08:35 PM
PSKJEEP
i got my warrantied. I even broke it myself trying to mess with the radio. they should cover it as long as you are under your miles
PSKJEEP is offline
post #6 of 11 Old 05-05-2009, 01:31 PM Thread Starter
JLCJ7
i have 37000 miles. I thought the warranty was up at 30000. Either way, i just bought one since it was only $26
JLCJ7 is offline
post #7 of 11 Old 05-05-2009, 01:35 PM
Avian
3yr/ 36,000mi minimum mandated by law IIRC.
Detonator Yellow JK-X
150w windshield mount long range KC's
bumper mount Hella 500's/ 130w KC drivers
Uniden Bearcat CB/PA
Mopar bumper
Moabs/ BFG KM's
Avian is offline
post #8 of 11 Old 05-05-2009, 03:25 PM
BeerMonkeY
the dealer broke mine trying to fix my clutch,they replaced it of course, but they are flismy and cheap
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #9 of 11 Old 05-06-2009, 04:26 AM
mdls4
How about this, I had the same problem and just drilled through the existing plastic molded screws and put in new chrome finished ones from a local hardware store.
Hard to tell in these pics because of the flash, but it actually turned out really nice and shiny in person!
mdls4 is offline
post #10 of 11 Old 05-06-2009, 07:15 AM
planman
Thanks to all Mod erators
planman's Avatar
I did the same thing but used black screws. Then, I added additional weatherstripping under the trim to reduce road noise from the transmission.
planman is offline
post #11 of 11 Old 12-18-2010, 10:42 PM
rtilotta
rtilotta's Avatar
I think this is the part via the Mopar site:
Mopar Catalog - 2007 - Jeep - WRANGLER X RHD 4X4
BOOT ASSEMBLY, GEAR SHIFT CONTROL LEVER UPR MAN TRANS
At least, I hope it is... $22.75, less than $30 with shipping/handling.
Raymond Tilotta
305/65/R17 on ProComp 17x9s
2.5" SkyJacker Lift
rtilotta is offline
broken plastic on shift boot Timbo TJ Wrangler Technical Forum 22 04-21-2010 08:47 PM
Plastic piece just after the front fenders strat_53711 TJ Wrangler Technical Forum 2 03-01-2009 03:51 AM
Plastic piece behind bumper rebelkid17 TJ Wrangler Technical Forum 9 12-02-2008 11:28 AM
forign piece of plastic in tranny 91GTA350 YJ Wrangler Technical Forum 5 08-09-2005 08:31 AM
How Do I Take Off The Chrome Plastic Piece Around the Headlights? yurmom22 TJ Wrangler Technical Forum 5 10-30-2003 09:08 PM
