Quantcast Brakes - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Brakes
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 04-08-2009, 04:37 PM   #1
Joneser
Brakes
I bought my wife a new RH drive 08 JK for her mail route. I know she does alot of starting and stoping but at 11,000 miles the rear brake pads are gone but the fronts have half the pads left...any of you wheelers experience only the rear pads going first?
04 Rubicon, RE 3.5" Super Flex, Tom Woods drive shafts, Old Man Emu Shocks, JKS bar pin eliminators, Daystar 1" body and motor mount lift , Olympic bumpers, Teraflex Steering box skid, Jeep Medic engine skid and tummy tuck, Shrockworks sliders, Powerslot rotors, Hawk brake pads, Spidertrax 1.5" wheel spacers, Borla cat-back exhaust, Airaid intake and throttle body spacer, Gen-right hood louvers, Optima red top battery, Bestop spare tire carrier, Skyjacker tie rod, Monroe steering stabilizer, Herculiner on the floor, OR-Fab sport cage, Kilby full length rack, Cobra CB and antenna, T-Max 9000 lb winch, A-Z Fabrication winch mount, Zenon 6" flares, custom fabed Stinger, Alpine stereo with JL audio sub and I-pod, Garmin with 08 TOPO, Viar on board air compressor... Etc...
Joneser is offline   Reply With Quote
Old 04-08-2009, 04:48 PM   #2
N2rock
N2rock's Avatar
Yes, it has been well documented on many forums. The rear brakes are wearing out twice as fast as the fronts. I don't think anyone has found a good reason why. Maybe DC is putting softer pads in the rear for some reason
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 04-08-2009, 04:52 PM   #3
Joneser
I should have searched first I guess...thx
Old 04-08-2009, 04:59 PM   #4
N2rock
N2rock's Avatar
Sorry... Did not mean to imply you should've searched. Just saying a lot have found the rears to go bad quickly
My last tire rotation (21K miles)- my rear pads are about 25% left, and my fronts are about 75% left. So I'll be doing my rear pads real soon.
Old 04-08-2009, 06:06 PM   #5
BiGEN
my rears were gone at 20k.... i plan on doing a overhaul on my brakes.. upgrading to bigger ones.. i dont think my 37's like the small ones...
plus i downshift alot... so my brakes were really not used alot...
FOR SALE!
R.E. Monotube Shocks - $200 NEW PRICE
VAJeepTrailDogs
[/color]
BiGEN is offline   Reply With Quote
Old 04-08-2009, 07:04 PM   #6
ctown67
i replaced mine as well around 20k. The mechanic told me that every time i drive off road or on a dirt road for a length of time i should run some water over the rear calipers. he wasn't judging, just giving me a tip. so if i get off road i rinse, just like rinsing the boat.
supposedly there is no dust sheild to keep the stuff off the calipers.
good luck.
List of stock parts that have been eviscerated.
power steering pump, tie rod, front left knuckle, horn, weld on rear track bar, rear track bar bracket, both rear fenders, front passenger fender, punctured spare tire, rear bar pins, steering stabilizer shock, front drivers side shock, spare tire carrier.
ctown67 is offline   Reply With Quote
Old 04-09-2009, 12:40 AM   #7
ronjenx
ronjenx's Avatar
It's not just a JK thing. The rear pads on my 2001 VW Golf wore out way before the front, which are still less than half worn. I have seen this on vehicles with drums on the rear, too.
Most of the braking load is taken by the front brakes. I don't know why it is so common for the rears to wear out first.
Size of the pads and rotors, maybe.
ronjenx is offline   Reply With Quote
Old 04-09-2009, 06:17 AM   #8
mrsig
At 8700 my rears went down to the rotors.. I need new shoes and rotors. Dealer did not cover it.
Then at 20,275 I had to replace the rear shoes again!
It not right... I do a lot of wheeling but I clean my brake before I head home than clean the heck out of the Jeep after..
JK 4 Door Auto, 35" MTKs, River Raider Snorkel, Dana 44 Axles w/410 Gears, Front & Rear E Lockers , TF 2.5" Suspension Lift, BDS 2" BL, 10,000 lbs Front or Rear Winch, To see mods & my Jeep in Action @ http://www.aaof.us/jeep.htm Member of CCJ, White Jeep Club Member #137, CEO of Black Sheep 4x4s http://www.blacksheep4x4s.org
Founding Member of Everglades Jeeps & 4x4s, Events Coordinator, Trail Chief & Ramp Master
mrsig is offline   Reply With Quote
Old 04-09-2009, 06:42 AM   #9
NYCJohn
2009 JK Wrangler
Most likely to prevent front wheel lockup the hydraulic pressure may be biased to the rear. This will keep the Jeep more controllable in hard braking and reduces nose dive as well. Looking at the brakes on my 09 Sahara I have to say this is one area Jeep did not skimp on. The rotors are pretty large and I feel the brakes work very well.
NYCJohn is offline   Reply With Quote
Old 04-09-2009, 07:57 AM   #10
weiva
My recommendation would be to do so once the brakes are cool. 500+ degree rotors plus 60 degree water may cause them to warp.
weiva is offline   Reply With Quote
Old 04-09-2009, 08:17 AM   #11
tricked919
I don't get it - this defies Car Physics 101 ...something is up. The only thing I can think of is that DC biased the rear brakes in the EBD programming.
tricked919 is offline   Reply With Quote
Old 10-13-2009, 11:22 AM   #12
ODAMO
BLDs might be the culprit
I'm beginning to think that the more off roading thats done the more the brake lock diff action there is and hence --severe duty opperation. it's kinda like riding the brakes all the time.... Anyone else think this?
ODAMO is offline   Reply With Quote
Old 10-13-2009, 11:50 AM   #13
ronjenx
ronjenx's Avatar
According to a Jeep Engineer, the BLD doesn't apply the brakes often enough, or with enough energy dissipation, to cause early rear pad wear.
Old 10-13-2009, 12:23 PM   #14
Tireguy
2009 JK Wrangler
I'm partial to the (re)distribution of brake force to the rear theroy. Gm and Ford trucks have accelerated rear wear being more common on a rear disc setup as well.
Now, I can see the TCS using the rear brakes to slow down a slipping/spinning tire(s), but you would have to be intentionally trying to break the tires loose every chance you get (mud/snow/ice) to get that accelerated wear on the pads.
Tireguy is offline   Reply With Quote
Old 10-13-2009, 06:27 PM   #15
Evil_Trolloc
I was surprised when I did the rear brakes at 12,500 miles.. Put a couple K on with the 36's, I know that didn't help the lifespan any
So I'd also guess its just the valving and the rear is getting more pressure.. I bought a set of pads at the local "advanced autoparts" for about 30 bucks.. Life time warranty.. Just wear them out and exchange.. The brakes are so easy to do on the jeep, I can deal with it =b
08 rubicon / 2dr / 6spd / 3.5" rockkrawler / 1" BL / 36" TSL's / superior rear axle shafts, JE Reel 1350 rear DS / skidrow oil/trans skid / riddler covers / EVO C gussets / RK truss / custom grill gaurd / CB / Herculiner / home brew sliders / plenty of scratches
Evil_Trolloc is offline   Reply With Quote
Glock Forum
