Brake pedal intermittently goes to floor - JeepForum.com
post #1 of 17 Old 07-05-2015, 11:12 AM Thread Starter
JWMan
Hi,
By any chance any one of you had come across with brake pedal going to the floor every now and then.
My Jeep Wrangler is 2009. Done only 70000Kms. In general, I keep up-to-date services. Jeep is in very good condition. I donít do off road drives.
Couple of months ago I started feeling that suddenly brake pedal hitting almost the floor, but brake applies. Iíve taken it to a local garage and tested and suggested to replace the Master Cylinder Pump. They replaced the pump with new one; made by Mopar. Couple of days later again I felt itís going to the floor.
I went back to the garage and they did a complete bleed out on all four wheels individually. Checked all over and no leaks were found. They checked the brake pads. Brake pads are about 40K Kms done.
On my way back from the garage it happened again; just once. Then I guess after 2 days it happened again and now keep happening at least once every two days or even every day.
I guess there is nothing else to replace.
Has anyone come across such a problem before? Any suggestions?
JWMan is offline
post #2 of 17 Old 07-05-2015, 02:21 PM
rich6700
Replace the master cylinder
rich6700 is offline
post #3 of 17 Old 07-05-2015, 04:53 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Master cylinder.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #4 of 17 Old 07-06-2015, 07:12 AM
Neo1130
2015 JK Wrangler
Master cylinder or air in the brake lines... I just replaced brake lines on a buddies Jeep a couple weeks ago because there was a split in the hard line that acted like what you describe.
Neo1130 is offline
post #5 of 17 Old 07-07-2015, 01:11 PM Thread Starter
JWMan
Originally Posted by RockyClymer View Post
Master cylinder.
The master cylinder pump is replaced with a new one.
After replacing the master cylinder pump it was OK for few days, but the problem appeared again.
Is this something to do with the ABS controller?
JWMan is offline
post #6 of 17 Old 07-07-2015, 01:13 PM Thread Starter
JWMan
Bleed out done on each wheel. There are no leaks. Brake lines appear in good condition.
JWMan is offline
post #7 of 17 Old 07-07-2015, 03:39 PM
VEGASROBBI
The Master Cylinder mounts on the brake booster which is mounted to the firewall, there is no Master Cylinder Pump I know of. There is a vacuum pump used on some JK's to increase vacuum to the booster under load. I am referring to a gas JK, not diesel.
The HCU(Hydraulic Control Unit) is mounted on the fenderwell along side the ABS module. The HCU contains the pump motor, valve body, accumulators, inlet valves, etc.
MoTech
LS Specialists
500 South Buffalo Drive, Las Vegas NV 89145 702-491-7710
www.LSWrangler.com
VEGASROBBI is offline
post #8 of 17 Old 07-07-2015, 07:49 PM
JohnRodriguez
you have air in the ABS motor. take your jeep out o a dirt road and do about 5 or 6 complete stops form about 30 mph, then bleed the brakes. if you take your jeep into the dealer, they use a starscan tool to simulate the ABS motor functioning to bleed the brakes of all the air. the dirt road will save you the $ they will charge you to hook up the tool.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #9 of 17 Old 07-07-2015, 11:02 PM Thread Starter
JWMan
I'm sorry if I misinterpreted, that's how the garage guy told me. Many thanks for correcting me.
My Jeep is gas not diesel
This is the part they replaced.
Is it that my HCU gone bad?
JWMan is offline
post #10 of 17 Old 07-07-2015, 11:04 PM Thread Starter
JWMan
Thanks. Let me give it a try
JWMan is offline
post #11 of 17 Old 07-08-2015, 12:27 AM
rich6700
I'm sorry if I misinterpreted, that's how the garage guy told me. Many thanks for correcting me. My Jeep is gas not diesel This is the part they replaced. Is it that my HCU gone bad?
That's a picture of the master cylinder reservoir.
rich6700 is offline
post #12 of 17 Old 07-08-2015, 06:51 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
they probably replaced master and reservoir - guys, he's in Dubai - we're loosing some in translation. He DID mean master cylinder (and it IS a pump lol).
I agree with air in the ABS pump.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #13 of 17 Old 07-08-2015, 08:45 AM Thread Starter
JWMan
Sorry guys, picture was inconclusive. It didn't copy the complete picture.
This is the complete unit. This was replaced.
JWMan is offline
post #14 of 17 Old 07-08-2015, 10:06 AM
VEGASROBBI
No worries I think we just need to make it clear what part you replaced. In a hydraulic system you have rams at both ends which move the fluid, in this case you have the master cylinder on one end and the caliper pistons on the other.
Many hydraulic systems have a hydraulic pump or in this case the ABS pump motor which is inside the hydraulic control unit.
I agree you should do a scan bleed to get rid of air in the ABS assembly after you have done a thorough manual bleed.
This probably no longer applies but back in the 1990's we had a lot of issues with the Kelsey Hayes ABS systems. The pedal would randomly drop to the floor and the truck would slowly roll to a stop it was very unnerving. The problem was low voltage: sometimes it would be from a weak battery or alternator but in most cases it was due to corrosion in the cables not supplying enough power to the hydraulic control unit, when the voltage would drop the unit would react by dumping pressure.
MoTech
LS Specialists
www.LSWrangler.com
post #15 of 17 Old 07-08-2015, 02:24 PM
Maertz
2009 JK Wrangler
It was a pain to bleed my abs unit. To bleed it takes a very expensive scan toll only shops and dealers normally have. I was successful in locking up my brakes on gravel roads activating the abs then bleeding my lines and repeat a few times...
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
