Brake Pad Replacement Using Hawk Brake Pads - JeepForum.com
post #1 of 33 Old 08-20-2011, 03:51 PM Thread Starter
joe002
Eventually your disc pads wear out (on JKs, typically the rear ones go first). I ordered some Hawk LTS High Performance Jeep JK Brake Pads from JeepSwag.com, and installed them. Here’s what I did.
There are a few symptoms of low brake pads: brake noise when applying brakes (the brake pads have a tab that makes the brakes squeal when they are really low), a need to press the brake pedal in more, if you look at the pads you'll see they aren't as thick, and/or your brake fluid is low (even though you don't have a leak). Here's a shot of my brake fluid - lower than the stock fill:
I could visually see the pads were low and the fluid was low, so time for a change. The pads were well packed in the box (securely held together so they didn't bang around in shipping), plus they supply plenty of brake grease. Note that you don't get new clips with these pads, so you'll have to clean and re-use the stock ones:
I started with the passenger rear wheel. Block your tires, jack up your Jeep under the axle, add a solid support under the axle, remove the wheel:
Here's a view of the pads and rotor. The pads are to the left and right of the rotor (lighter brown smoother surface - offset to the right). There's still some material left, but I wanted to replace them anyway:
There are a couple of ways to get to the pads on the JK, but the Factory Service Manual recommends removing the two caliper mounting bolts. This is the top bolt (the bottom bolt is at the bottom of the picture with a white marking on it):
You'll need a thin wrench to hold the inner nut, and a wrench or socket for the outer bolt:
Once you get the two bolts off you can remove the caliper:
Do not let the caliper hang by the brake line - you need to support it! Here you can see the supported caliper (I had an old plastic holder), and the old brake pads still in place:
Here's a close up of the outer pad - you can see the stock clips on the top and bottom. I found that it's not a bad idea to use new clips:
The pads should come off easily - slide the top off first then the bottom. Note that you never want to touch the rotor surfaces as any contamination is not helpful. Here are the pads removed. Note that the inner pad has the clip that makes a noise when the pad material is too low (there's about 1/8" of material left before it hits the noise tab):
Next, you need to compress the brake piston in the caliper. If your brake fluid reservoir is completely full then you'll have to remove some fluid as compressing the piston will raise the level in the reservoir. Once you're sure there's room for the fluid in your reservoir you use a clamp to slowly compress the piston. I only had a 3" clamp, and slightly larger clamp would have been a little easier to use. Also note that you may need to put a socket in the piston if your clamp can't reach down far enough to compress the piston:
You can re-use your old clips, but you need to carefully inspect your old clips to ensure none of the tabs are broke or loose. I suggest getting new clips and Permatex Disc Brake Quiet which will help the clips hold to the caliper:
Put the Disc Brake Quiet on the bottom and sides that will come in contact with the caliper - don't get any on any other surfaces:
Carefully clip each clip back in place - note that the side tab points toward the rear:
Since my rotors are good, I'm going to keep them the way they are (if you want to replace your rotors you need to do it now). Next, you need to clean off the surface of the clips and use the supplied grease on the clips (I tend to try to keep the grease away from the rotor edge):
Also put grease on the piston. It's OK with this grease to get it on the rubber boot:
And finally put some grease on the inside of the arms of the caliper. You put the grease on the wear marks:
You can now put your new pads on the Jeep. Put the bottom part in first, edge in the top, then slide the entire pad over until it's in contact with the rotor. Remember that the inside pads has the noise clip. You can now put the caliper back on. Since you compressed the piston it should easily go back in place. The mounting bolt nuts are spring loaded so you need to push against them as you slip the assembly in place. Next, torque (don't quote me, but the Factory Service Manual says 26 ft. lbs. rear, and 26 or 32 ft. lbs. front (different numbers in different parts of the manual)) the bolts back on to hold the caliper. I noticed that they had some kind of thread locker, so I added some blue Loctite:
Here's what it looks like with the new pads installed. In the future you can look for the slot in the pad and when you can't see it anymore you can figure it's time to replace the pads again:
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #2 of 33 Old 08-20-2011, 03:52 PM Thread Starter
joe002
Always finish up with Brakleen. Spray down the inside and outside surface of the rotors to remove any grease, dirt, fingerprints, etc. that you may have accidently gotten on the surface. Don't spray it on the outside surface of the pads as you'll wash off the grease you want to keep:
Put your wheel back on, torque it down and repeat on your other wheels. Here's my brake fluid level after replacing all of my pads. After taking this picture I added a little more to top it off:
After installing the brakes you need to burnish the pads. The Hawk instructions say to make 6 to 10 stops from 30-35 MPH applying moderate pressure, then make 2 to 3 hard stop from 40-45 MPH, and then allow the brake pads to cool for 15 minutes. I did 10 and 3.
joe002 is offline
post #3 of 33 Old 08-20-2011, 03:59 PM
Caribic-TJ
I use the same brake pads.
08 JKU Rubicon
98 TJ fully locked
Caribic-TJ is offline
post #4 of 33 Old 08-20-2011, 04:36 PM
Alaska-HWY JK
Good write up. Did mine in June, same pads. 100,000km backs were pretty much gone fronts had a little life left.
Alaska-HWY JK is offline
post #5 of 33 Old 08-25-2011, 06:53 PM
wheels082
2010 JK Wrangler
I also used and recommend the Hawk pads.
wheels082 is offline
post #6 of 33 Old 08-25-2011, 07:44 PM
Apexer
I use Hawks on my Mustang - LOVE them. Will also use them on my Jeep when the time comes. Nice write up !
Mark
1993 XJ - Project UP ( as in unlimited potential, or nowhere to go but UP )
Apexer is offline
post #7 of 33 Old 08-26-2011, 06:49 AM
20181c
2009 JK Wrangler
Great pics and write up.
09 Rubi Unlimited Stone White
ORH liner, Cooltech, CB, Weathertech, Thule Track system.
20181c is offline
post #8 of 33 Old 08-26-2011, 07:45 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Where else can you buy Hawk pads? Quadratic only lists them for TJs (which I also need to do!) Napa lists nothing for my JK. (not that I was looking for Hawks at Napa, but anything!) Another question, I've got 42k on my JK, I noticed the other day on an hill that my e brake wouldn't hold until the last notch. Is this indicative of bad pads or something else? Aka, an adjustment of some sort?
Edit: Napa's site lists 5 different pad types... another lesson learned... The local ghetto Napa stinks!!!
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #9 of 33 Old 08-26-2011, 08:18 AM
Green98TJ
2010 JK Wrangler
Great pics and write up!
Contact Jason at KOR for all your Jeep Needs.
2010 JK Mountain
Green98TJ is offline
post #10 of 33 Old 08-26-2011, 09:57 AM
yoda13
Force Wheeler
yoda13's Avatar
This is a wonderful writeup Thank you!
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #11 of 33 Old 08-26-2011, 02:13 PM
durable1
Thanks for your time. Great write-up!
durable1 is offline
post #12 of 33 Old 08-26-2011, 05:25 PM Thread Starter
joe002
Thanks all, glad to help. It’s a great job you can do in your garage.
CoriolisSTORM - The parking brake is separate from the rear pads. I haven’t looked into their adjustment or the replacement of the shoes.
joe002 is offline
post #13 of 33 Old 02-20-2012, 09:26 PM
PhatJK
2009 JK Wrangler
Thanks for the write-up. I plan to replace my read brake pads at my next tire rotation interval, approximately 2000 miles to go.
09 Unlimited Rubicon
Teraflex 2.5" spring lift kit
ORFAB tire carrier
PhatJK is offline
post #14 of 33 Old 02-21-2012, 12:41 AM
GunDude
2011 JK Wrangler
Where do you get a thin wrench to hold the inner nut and what size nut is it? Great write up also!
GunDude is offline
post #15 of 33 Old 02-21-2012, 04:48 AM
OleBlue73
1973 CJ5
About what mileage intervals are the factory pads lasting? My wife's 09 Rubicon JKU is still on it's original pads at almost 70,000. Most of the driving has been back and forth to work and on roadtrips.
1973 CJ5, 304, T15, D20
2009 JKU, Rubicon
2005 TJ, X, 4.0, 6 speed
OleBlue73 is offline
Hawk Performance HPS High Performance Street Disc Brake Pads? NW Jeep TJ Wrangler Technical Forum 54 11-02-2011 09:54 PM
replacement brake pads for taraflex conversion drummerchukb1 TJ Wrangler Technical Forum 2 01-16-2011 06:38 PM
Hawk HPS brake pads any good? ChrisYJ - Italy YJ Wrangler Technical Forum 4 11-15-2008 07:13 AM
YJ Brake Replacement (Pads, Rotors, Drums) - How much? l3it3r YJ Wrangler Technical Forum 15 09-29-2008 09:05 PM
Need help with replacement brake pads and rotors bshwckr TJ Wrangler Technical Forum 10 07-26-2006 12:45 AM
