Bolt Missing - Please Help - JeepForum.com
post #1 of 6 Old 02-15-2011, 06:54 AM Thread Starter
mthomp83
2010 JK Wrangler
To preface...I have the AEV 3.5" so my rear stabilizer links were moved to the front.
So I was walking to my Jeep this morning and I noticed something out of place. One of the bolts from the stabilizer bracket was missing at the axle tab.
Does anyone know why this would have happened? Does anyone know what I can do to fix it? What size and grade bolts does AEV use?
2010 JK Rubicon - Flame Red - 3.5" AEV Premium Suspension Lift w/ Bilstein 5100 Shocks, 17" AEV Savegre Wheels, 35x12.50 r17 BFG KM2's - Rugged Ridge XHD Modular Front Bumper w/ 10,500lb Winch - Rugged Ridge XHD Rear Bumper w/ Swing Out Tire Carrier - Poison Spyder JK Evap Skid Plate - KC Slimlite Long Range
mthomp83 is offline
post #2 of 6 Old 02-15-2011, 07:52 AM
Joevacs
2010 JK Wrangler
If you are referring to the tab on the axle, in your picture, that is a little rusty and has nothing attached to it; that's where the original position for the swaybar link was attached. the bracket it is attached to now apparently came with the lift.
Wait a minute, I just looked at your picture again. It looks like the plate has spun out of place. I see what you mean now. Look at the bolt on the other side of the Jeep and get a grade 8 bolt from the hardware store to match it's size and length. It must've vibrated loose. Might want to torque all you bolts while you're at it.
2010 Rubicon, 4" lift, Currie control arms and trackbar, 40" Procomp MTR
Joevacs is offline
post #3 of 6 Old 02-15-2011, 07:59 AM Thread Starter
mthomp83
2010 JK Wrangler
thankfully it is not rusty, its just dirty but yea i called the shop where i had the lift installed and he said to just bring it by and he would put in a bolt but i'm going to have him retorque everything....this is driveable but i dont want a control arm bolt or something more important coming out
mthomp83 is offline
post #4 of 6 Old 02-15-2011, 08:06 AM
Blu-Jacket
2009 JK Wrangler
When you replace the bolts, use some top locks. They're an all metal lock nut that can be found in grade 8's. If you have a Fastenal close by they will carry the hardware. Also, definitely check your torque specs.
Blu-Jacket is offline
post #5 of 6 Old 02-15-2011, 08:56 AM
Liquor
BOUNTY HUNTER
Liquor's Avatar
2008 XK Commander
invest in a craftsman torque wrench. be sure to cal it according to specs. usually 12-18 months.
i didnt think these had a torque value. anyways, its real easy and torque should be checked once a month and before and after wheeling. keeps everything safe for you and your family
i check my beadlock and suspension components when I do my monthly tire pressure and engine/drivetrain fluid checks. only takes an hour or so on a weekend. time to blast some AC/DC and have a couple beers.
2007 Unlimited Sahara Steel Blue - I call it "CAIN"
2002 TJ Sport - Sold
"CAIN" '07 Jeep JK 426 HEMI 685 HP & 650 ft lbs
Your Jeep and Gaming Social Network
2012 Sponsors:
Magazine Feature:
Liquor is offline
post #6 of 6 Old 02-15-2011, 09:03 AM Thread Starter
mthomp83
2010 JK Wrangler
thanks for the input guys!
mthomp83 is offline
Missing a bolt lyoncc YJ Wrangler Technical Forum 8 04-26-2010 09:00 PM
My header is missing a bolt LandoCommando TJ Wrangler Technical Forum 4 10-08-2009 08:58 PM
am i missing a bolt?? southernss TJ Wrangler Technical Forum 10 04-25-2009 05:01 PM
What bolt am I missing? czjeeper YJ Wrangler Technical Forum 11 01-08-2009 07:52 PM
missing bolt slav1north TJ Wrangler Technical Forum 3 05-28-2008 01:35 PM
