Bogging/Shuddering in 4th, 5th, 6th any RPM - JeepForum.com
post #1 of 5 Old 07-06-2009, 09:40 AM Thread Starter
Jordon83
2009 JK Wrangler
It just starting doing it this morning. It does not always do it in 4th and it is only slightly in 5th, but 6th is bad. I thought maybe I was shifting at too low of an RPM but that did not change it, then I thought maybe I was letting off the clutch too quickly, not that either. When it happens it slows the vehicle down and shakes the shifter rather violently. Any ideas on what this could be? Or may I be doing something wrong, I have not changed my driving style, and the Jeep only has 4K on it. Does not do it when downshifting through gears.
Jordon83 is offline
post #2 of 5 Old 07-06-2009, 04:54 PM
Imped
Imped's Avatar
Probably transmission mount. It doesn't sound like you know what to look for so I would take it to the dealer and have them diagnose it since you're probably still under warranty.
OlllllllO
IndyORV
Imped is offline
post #3 of 5 Old 07-07-2009, 07:59 AM
b_c
have you changed your air filter lately?
greater love hath no man than this, that a man lay down his life for his friends -john 15:13
b_c is offline
post #4 of 5 Old 07-07-2009, 08:28 AM
opasno
2009 JK Wrangler
I've had the same issue. Mine is when I give it a bit of gas (when I'm cruising/just driving). Happened to me last winter (had about 3,000 KM), but went away the day I took it into the dealer. Started happening again just last month at 10,000 KM. But of course, when I think about going to the dealer, it goes away.
Hasn't happened for a while now again.
opasno is offline
post #5 of 5 Old 07-07-2009, 09:40 AM Thread Starter
Jordon83
2009 JK Wrangler
It has stopped doing it. I did not know if this was a common thing with the tranny or if I was experiencing something new.
Wouldn't a trans mount do it in every gear?? Even if I shift too early or bog it down the vehicle hardly shakes, I'd think a mount would be more frequent and it would worsen the symptoms when bogged in any gear.
Jordon83 is offline
Jeep is shuddering...? HMTwin TJ Wrangler Technical Forum 4 11-21-2009 05:11 PM
tranny shuddering?? Beltfed09 JK Wrangler Technical Forum 9 08-28-2009 10:46 PM
Shuddering in decelaration (NOT DW) Florida_Model TJ Wrangler Technical Forum 6 06-27-2009 06:49 AM
Need some help (shuddering) BlackJeepin TJ Wrangler Technical Forum 11 06-03-2008 05:39 PM
crazy shuddering ? JaredBoys JK Wrangler Technical Forum 13 03-30-2008 07:22 PM
