body lift question - Page 2 - JeepForum.com
Closed Thread
post #16 of 49 Old 06-15-2013, 09:09 PM
Rtone1583
2009 JK Wrangler
Originally Posted by SLADE View Post
That does not translate to additional tire clearance. You still have the same amount of tire clearance you did before you added the spacer. You've only altered the ride height.
That's making my head hurt.
Trying to figure out how, exactly, increasing the ride height does NOT increase tire clearance.
By this reasoning, installing a 4" lift (which only alters ride height) will not allow you to run tires larger than stock.
I must be living in strange world since I'm running a 4.5" lift and can fit 37" tires.
Rtone1583 is offline
post #17 of 49 Old 06-15-2013, 10:10 PM Thread Starter
straight-pipe
wow...thanks I think....didn't ask anyone opinion as to my reasons, if one must know, it's just to boost it up. I used to own a v-10 2500 ram and i kinda dig looking down on people tiz all and I don't mind the look...each their own I guess.
94 ZJ 5.2L
07 JK 3.8
straight-pipe is offline
post #18 of 49 Old 06-15-2013, 10:31 PM
ncb
This thread won't last long.
ncb is online now
post #19 of 49 Old 06-16-2013, 07:56 AM
tyvanwie
Is this a joke? Or do you just have no idea what you're talking about?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #20 of 49 Old 06-16-2013, 09:48 AM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Don 't feed Slade....he is trolling again. And yes, he has no idea what he is talking about, or at best uses double speak...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #21 of 49 Old 06-16-2013, 10:07 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm still waiting for the hero of this movie to save everyone!
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #22 of 49 Old 06-16-2013, 10:12 AM Thread Starter
straight-pipe
Originally Posted by JeeperDon View Post
Good luck then. After 6 years in Canada (salt, humidity, rust), the bolts may be tough to get out, might break.
I deal with that everyday, been in the autobody trade for 24 years and I have a fully equipped GM dealership to play in so I'm not concerned with ...bolts.
94 ZJ 5.2L
07 JK 3.8
post #23 of 49 Old 06-16-2013, 10:44 AM
ncb
I'm confused. If one needed more clearance to keep a tire from rubbing the fender how would a small spring spacer (not a budget boost kit) get rid of the fender rub?
ncb is online now
post #24 of 49 Old 06-16-2013, 10:53 AM
RIPNBST
You guys saying spring spacer lifts don't provide more clearance should only have a mouse, no keyboard for you.
RIPNBST is offline
post #25 of 49 Old 06-16-2013, 11:01 AM
ncb
I think Slade is saying if you simply add only a small spring spacer, not a (budget boost) spacer lift.
A spacer lift (budget boost) has longer shocks (or shock extensions) and bump stops which results in added clearance for larger tires.
Simply adding a small spacer to a stock JK will increase clearance in the garage, but not on the trail at full stuff.
Edit- not trolling or being a PITA. Just keeping facts straight.
ncb is online now
post #26 of 49 Old 06-16-2013, 11:10 AM
ncb
The difference is in the term "spring spacer" and "spacer lift" aka budget boost.
ncb is online now
post #27 of 49 Old 06-16-2013, 11:21 AM
JTPhoto
JTPhoto's Avatar
I agree.. The extended bumpstop has to accompany the spring spacer to increase ride height and to prevent rub.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #28 of 49 Old 06-16-2013, 11:22 AM
SLADE
Simply adding a 1" coil spacer does NOT increase the distance between your tire and body at full bump. The 1" coil spacer just simply adds 1" to your ride height.
Your 4.5" lift also allowed you to install the needed bump stop that allowes your 37's to clear at full bump.
I do find it amusing. Some people just have trouble following.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #29 of 49 Old 06-16-2013, 11:23 AM
SLADE
Are you still having trouble with real world measurments and not understanding how extending Bump stops limit suspension travel? There is no trolling on my end, just a lack of understanding on yours.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #30 of 49 Old 06-16-2013, 11:30 AM
SLADE
Exactly.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
Closed Thread
