body lift question - JeepForum.com
Closed Thread
post #1 of 49 Old 06-15-2013, 06:16 AM Thread Starter
straight-pipe
body lift question
I've done a 2" coil lift and I want to get a bit more height. I don't want to go more radical with a suspension lift than what I have.
My attention is turned to body lifts.
My question is if I want to install a 2" BL what will I be facing in regards to stretched hoses and stuff like that...what is the most lift I can do without having to mess with too many things?
07 JK 4 dr 3.8 auto 2" coil lift.
94 ZJ 5.2L
07 JK 3.8
straight-pipe is offline
post #2 of 49 Old 06-15-2013, 07:08 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Body lifts are tacky in my and many others opinions. I suggest you got the wrong lift to start with. I helped a friend add a 4" 'stock-arm' kit to his '11 and it stands nice, clears 35's with stock fenders.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 49 Old 06-15-2013, 07:12 AM
Rtone1583
2009 JK Wrangler
What size tires are you currently running? You may be able to get that extra little bit by bumping up the tire size. Might even be able to bump the tire size plus a one inch BL. Depending on tire size you could gain two inches overall.
As far as the BL, I would say that 2" would be the max you'd want to go may even be the max you can go.
This looks like a pretty good write up on what you can expect.
http://wayalife.com/showthread.php?4...ep-JK-Wrangler
Rtone1583 is offline
post #4 of 49 Old 06-15-2013, 07:14 AM
Rtone1583
2009 JK Wrangler
That answers the OP's question in what way?
post #5 of 49 Old 06-15-2013, 07:27 AM Thread Starter
straight-pipe
don't care about it looking tacky, just need some input from someone who has done one and if they have run into any problems
94 ZJ 5.2L
07 JK 3.8
post #6 of 49 Old 06-15-2013, 07:30 AM Thread Starter
straight-pipe
I am running 265 duratrax and I am not interested in running a bigger tire. My MPG is pretty decent and i don't want to mess with a good thing there.
94 ZJ 5.2L
07 JK 3.8
post #7 of 49 Old 06-15-2013, 07:52 AM
JeeperDon
JeeperDon's Avatar
Good luck then. After 6 years in Canada (salt, humidity, rust), the bolts may be tough to get out, might break.
Web Admin for
post #8 of 49 Old 06-15-2013, 09:25 AM
Tanimal
Why do you want more height?
Learning as I go and it's worth every penny!
Tanimal is offline
post #9 of 49 Old 06-15-2013, 10:05 AM
rayder1
You're running 265's, don't want bigger tires but want to go past 2" lift. ....and the reason?
Yeah....you maxed out your lift without having to modify stuff. Read the massive number of lift posts and you'll get an idea of what you're looking at.
rayder1 is offline
post #10 of 49 Old 06-15-2013, 04:27 PM
SLADE
If your looking to a Body Lift for more "lift", your looking at it for the wrong reasons.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #11 of 49 Old 06-15-2013, 05:47 PM
SubAtomicGenius
2011 JK Wrangler
Note that most JK enthusiasts avoid body lifts. If you're looking for more height, the real reason should be to clear bigger rubber, not to just get more height. And that is achieved with a lift kit - perhaps coil spacers - but not a body lift. Just my $0.02.
Also, a 4" lift on a JK is a really big lift, typically used to run 37-inch tires. They are expensive to do right.
SubAtomicGenius is offline
post #12 of 49 Old 06-15-2013, 05:51 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
They say I am opinionated....so be it, a body lift on a JK looks plain dorky....fugly IMO.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #13 of 49 Old 06-15-2013, 05:55 PM
SLADE
A 1" body lift allows more tire clearance than a 1" coil spacer. A coil spacer does not allow for any additional tire clearance.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #14 of 49 Old 06-15-2013, 06:34 PM
rayder1
Uh....it creates 1" separation between the top of the spring (suspension to frame) and the bottom of the spring (axle). Therefore you have more tire clearance. Without changing shocks, though, a spacer lift steals a bit of shock travel.
rayder1 is offline
post #15 of 49 Old 06-15-2013, 06:40 PM
SLADE
That does not translate to additional tire clearance. You still have the same amount of tire clearance you did before you added the spacer. You've only altered the ride height.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
Closed Thread
