body lift - does it matter the brand? - JeepForum.com
post #1 of 7 Old 08-03-2009, 02:15 PM Thread Starter
rballman
well i am looking at getting a 1" body lift. does it really matter on the brand? anything special to look for?
I was thinking of getting the Rough Country 1.25" lift for $99.
2007 Wrangler X - Jeep Green, 4" lift, 4.88s, locked rear, custom bumper/fender/cage, rolling on 35s w/ 15s
Colorado Jeep Club member #2007
rballman is offline
post #2 of 7 Old 08-03-2009, 03:45 PM
UTAH
UTAH's Avatar
I've put 1" body lifts on both my JK's - a '07 manual trans X and a '09 auto trans Sahara.
The quality of a body lift probably matters little on a JK. That's 'cause on a JK there's no need to mess with the fan shroud. And, on the auto trans, the shift linkage is cable actuated - again not an issue. So, all you've got is the pucks and longer bolts.
The most I and others have had to do with our manual trans JK's is cut away the rear of the internal shift boot.
Bill
'97 Land Rover D90
'03 TJ Rubicon
'14 JK-8 Freedom Edition
'14 KL Cherokee Trailhawk
UTAH is offline
post #3 of 7 Old 08-03-2009, 04:58 PM
Rudinater
2009 JK Wrangler
Question about body lifts, when you do a body lifts does that effect how high the shifters sit. I'm talking about the shift for the auto/manual trans and the transfer case shifter.
I find both of these kind of low normally and would hate to have them a inch or two lower.
Thanks
Rudy Ackerman
In Oregon for now
Red 09 Unlimited Rubicon - Teraflex 4inch long arm lift, Elka shocks, 5:38 gears, 37inch GY MTR's, Expedition Core front bumper with Warn PowerPlant HD, RS-E rear bumper and carrier, RS-E step rock sliders.
Rudinater is offline
post #4 of 7 Old 08-03-2009, 05:04 PM
JeepUserName
Does a body lift have the potential to impact the warranty as a suspension lift would?
JeepUserName is offline
post #5 of 7 Old 08-04-2009, 11:55 AM
Grant211
i have a MORE 1 inch body lift and have zero compliants. You can see pics in the link in my signature.
2007 JK Unlimited Sahara
2.5" Teraflex Budget Boost, 1" MORE Body Lift, KC Slimlights, ProComp 7047 Wheels, 305x65x18 (34's) BFG AT KO's, Airraid CAI, Riddler Differential Covers, Headlight & Taillight guards, etc...
Grant211 is offline
post #6 of 7 Old 08-04-2009, 12:26 PM
N2rock
N2rock's Avatar
I can't comment on manual. But the auto it does nothing- leaves it exactly the same.
Not really. If doing it to an auto, the only thing that you really change is adding in a steering adaptor- Actually I'm not even sure if that is just the 2" BL, or with both 1" and 2". Regardless, that little adapter is not going to cause any problems.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #7 of 7 Old 08-04-2009, 02:17 PM
tricked919
A BL is a BL is a BL ... Composite or aluminum, they all do the same thing.
I'm a fan of the 1" kits. As mentioned, on an auto, it has absolutely no negative implications on anything. The 1" kits are almost un-noticeable with the rear bumper mod, and where else can you get an inch of lift for $100 and 2hrs of your time? ...of course assuming that you already have a BB or other mild suspsension kit.
I would not do a BL before a suspension lift, considering all the great inexpensive options that will yeild FAR more performance benefits. For me, the BL was a great supplement to my OME kit because I rubbed at full stuff when disco'd and the BL was the difference in eliminating the rub. I'd do one again in a heartbeat.
I will say that getting the washers off the stock hardware was very difficult, as was removing the studs from the front bushings. If you have a bench vice, its much easier.
tricked919 is offline
doesit matter what brand 80-w90 i use? or is it all the same chaznad TJ Wrangler Technical Forum 6 03-15-2009 04:39 PM
Body Lift brand differences Faramir66103 TJ Wrangler Technical Forum 3 01-22-2009 06:49 PM
How high and what brand body lift lilman TJ Wrangler Technical Forum 8 10-09-2008 08:07 PM
Body Lift company/brand question jim_bert TJ Wrangler Technical Forum 5 08-21-2008 12:14 PM
Brand of Gas, does it matter? Jeep225 YJ Wrangler Technical Forum 20 03-07-2006 06:32 AM
