On board air system - Page 3 - JeepForum.com
post #31 of 41 Old 12-13-2006, 01:50 PM
Bigbob
Bigbob's Avatar
Bob's theory; A 5 gallon tank with 100 psi will fill a 1 gallon tire 20 psi and have 5 gallons of 80 psi air left in it. That is considering no loss of air during the filling process. Most off road tires are bigger than 5 gallons.
Riddle: If you have a 23 gallon air tank filled to 200 PSI air pressure and you fill one 37"X12:50X15 MTR from 10 PSI to 27 PSI how many gallons of air are left in the tank?
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #32 of 41 Old 12-13-2006, 03:08 PM
scottyc
My calculations put the tank at 146 psi after filling a 1 gallon tire 20 psi. However a 1 gallon tire is tiny. The tire in your example below is over 40 gallons.
Trick question: the tank doesn't change size, so there are still 23 gallons of air. The pressure has changed. If anyone is curious what the pressure would be:
If you assume a perfectly cylindrical tire on a 12.5" wide rim (probably not the case), then your tire is 48.6 gallons. Starting with a 23gal tank at 200 psi and a 48.6 gal tire at 10 psi, and ending with a 48.6 gal tire at 27 psi, the tank (still at 23 gallons) would have a pressure of 164 psi.
scottyc is offline
post #33 of 41 Old 12-13-2006, 03:13 PM Thread Starter
surfcaster
Originally Posted by jdrogers
Now wait a minute... I used to do this all the time on my 2004 Rubicon.
The stock MTRs are rated to maximum load at something like 85 psi. This maximum psi is right on the side of the tire. I would fill the spare tire to 80 or 85 psi before a wheeling trip and then use this air to refill the other 4 tires. It was enough air to go from around 15 psi back to about 30 psi. Worked like a champ.
However, I have since purchased a small portable 12 volt air compressor that works pretty good. They are sold at stores like Pep Boys and Autozone for about $50 bucks. It much more powerful than the small ones everyplace sells for around $25 bucks. It will air up a stock MTR from 15 psi to 33 psi in about 3 to 4 minutes. Not a bad time for the price.
I was thinking of doing this but I never tried it. If it worked so well, why did you buy a portable compressor? In your opinion, which works better, the spare tire or the compressor?
surfcaster is offline
post #34 of 41 Old 12-13-2006, 03:43 PM
jdrogers
I got the compressor for several reasons.
1) So I didn't have to remember to go air up the spare every time before going wheeling.
2) The spare did not hold enough air to get the tires back up to normal street pressure. It was enough to drive home, but I would still have to go air up that last little bit.
3) If you have a tire problem and have to use the spare, then you no longer have a means to air up when you're done.
4) The compressor comes in handy helping others...
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #35 of 41 Old 12-13-2006, 05:29 PM
Bigbob
Bigbob's Avatar
LOL You are an egghead aren't ya! I just wanted to catch someone trying to figure out how many gallons of air is left in the tank. And try to get across that hauling around a 5 gallon tank with 150PSI of air in it is sort of senseless.
6 Speed, Hardtop
Bigbob is offline
post #36 of 41 Old 12-13-2006, 06:40 PM
mountravlr
Warn to the Rescue
Now that warn makes a combo air compressor/winch it may solve some problems. The compressor is substantial and will operate small impact wrenches in addition to the tire issues.
mountravlr is offline
post #37 of 41 Old 12-13-2006, 07:33 PM
scottyc
scottyc is offline
post #38 of 41 Old 12-13-2006, 07:46 PM
Bayou Boy
Only problem is that it's huge and blocks a to of airflow to the radiator. Might not be a big deal in the north, but for us down here that see 100+ that ain't gunna work.
Bayou Boy is offline
post #39 of 41 Old 12-13-2006, 08:51 PM
Border Dave
Got Sand?
Border Dave's Avatar
Not if you don't have a compressor and the nearest gas station is 20 miles away! At least you'd be able to air up enough to get on the highway to get to the gas station.
Border Dave is offline
post #40 of 41 Old 12-13-2006, 09:57 PM
Bigbob
Bigbob's Avatar
I meant it in a good way of course. I failed math all the time so the only thing "egghead" about me is my scrambled brains.
6 Speed, Hardtop
Bigbob is offline
post #41 of 41 Old 12-15-2006, 06:17 AM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
it also violates the KISS principle. if something goes wrong with everything that is involved in the unit, you are out of a) recovery and b) air.
i'd rather eat up space with trail gear than be stuck out there...
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
On Board Air System Tcormier106 TJ Wrangler Technical Forum 7 09-09-2009 06:33 PM
Is it wise to do a tankless on board air system? jonlb YJ Wrangler Technical Forum 4 03-15-2009 08:28 AM
On-board Air deflation/inflation system? USMC2014 YJ Wrangler Technical Forum 19 03-03-2009 09:29 PM
need write up on york on board air system Wrangler11 TJ Wrangler Technical Forum 3 11-11-2007 10:58 AM
On Board Air System fastone110 YJ Wrangler Technical Forum 13 08-28-2005 10:24 PM
