on board air - JeepForum.com
post #1 of 27 Old 09-26-2013, 06:15 PM Thread Starter
jager00
2005 WK
on board air
Looking at on board air systems. Can anyone show me some setups of where yours is mounted. And any suggestions on systems would be great. Im looking for one that will wire into the jeep, support front amd rear lockers and can also run a hose to fill a tire or use a tool.
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline
post #2 of 27 Old 09-26-2013, 06:28 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I use a Power Tank mount to the driver side rear side. I use it to run ARB lockers, fill tires, run my impact tool set and to weld under CO2 when needed...fills a lot of needs for me.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 27 Old 09-26-2013, 06:31 PM Thread Starter
jager00
2005 WK
Can you post a pic for me. And a part number for which one you bought please.
jager00 is offline
post #4 of 27 Old 09-26-2013, 09:50 PM
Filthy-Beast
I had have a York, AC compressor based, OBA on my LJ but sadly cannot find a way to do that on a JK. so I've been looking at the ARB Dual or a Viair system with brake booster bracket. With either system you'll need a manifold for your air lockers. I like the ARB because of the 100% duty cycle and higher air flow rates. but you have to be more creative in the mounting of it.
For Sale:
97 TJ: daughter 1 - 2.5L, Auto, 2" BB, 31" GY Duratrac
98 TJ: Daugher 2 - 4.0L, 5spd, D44 rear
06 LJ Rubicon: mine - Rokmen full up-armor, 8 adjustable CAs, front bumper, sliders, corners, Shrockworks rear bumper, 3" AEV/BDS lift, Currie HD stearing and Antirock, MT/r - k 35x12.5, SuperWinch, MC Overlines, York OBA
13 JKU Rubicon: Wife's for now, Ace Rock rails & rear bumper tire carrier, Truck Lites, MC Game changer 3.5 lift, RR skids, PSC Brawler front bumper, Warn 9.5cti-s, 35" GY MTRs
Filthy-Beast is offline
post #5 of 27 Old 09-26-2013, 10:25 PM
planman
Thanks to all Mod erators
planman's Avatar
I have a bracket that holds an extra AC compressor (York) on one of our JKs as part of an OBA system. I don't recall the manufacturer. I'll post pics on Saturday.
planman is offline
post #6 of 27 Old 09-26-2013, 11:11 PM
Filthy-Beast
Please do but I don't think it works on the 3.6l JKs
For Sale:
post #7 of 27 Old 09-27-2013, 12:29 PM
RockyClymer
RedRock4Wheeler
Here are pics of my PT install, air locker switches, and the manifold setup (I have replaced the red electrical hose with a reflective tape wrapped water heater hose for better thermal protection down side of engine - and also relocated it to the farthest point from the heat source....don't ask my why):
NRA Life member
post #8 of 27 Old 09-27-2013, 12:42 PM Thread Starter
jager00
2005 WK
Awesome man. Have you ran any tools off that comp? And do you mind supplying me a link or a part number so I can find it. Thanks for the pics.
jager00 is offline
post #9 of 27 Old 09-27-2013, 12:54 PM
Filthy-Beast
what he's showing is not a compressor, it's a CO2 tank with a regulator. when empty you'll need to get it refilled.
For Sale:
post #10 of 27 Old 09-27-2013, 12:57 PM Thread Starter
jager00
2005 WK
Oooh. Crap. I thought he was just using the tank to hold some air to work the comp less. Thanks for the info
jager00 is offline
post #11 of 27 Old 09-27-2013, 01:03 PM
Filthy-Beast
It's not a bad solution many people prefer them. I just have heard in my area it's pain in the butt to get a single small tank refilled.
For Sale:
post #12 of 27 Old 09-27-2013, 01:51 PM
RockyClymer
RedRock4Wheeler
My 4x4 shop is a PT dealer and they fill it for 15 bucks which can last me all summer for air ups. The impact tools, at 4cfm, would drain it pretty fast, but when I use them I only spin them for a couple of seconds...how often have you seen an impact tool turned on for a full minute? More like 4 or 5 seconds for me - I can get all lug nuts for a single wheel off in less than 30 seconds of use...welding, well that depends on how much you do. But it is easy for me to get a refill so that does make it easier on me than others. I also have an older spare tank just in case I run out in the shop.
NRA Life member
post #13 of 27 Old 09-27-2013, 02:22 PM
Filthy-Beast
yeah all that around is bigger welding supply places. drop off the tank come back in a few days and hope you get your tank back and it was not lost.
For Sale:
post #14 of 27 Old 09-27-2013, 03:12 PM Thread Starter
jager00
2005 WK
Oh crap... I thought he was using it to hold air so it wouldnt work the compressor all of the time
jager00 is offline
post #15 of 27 Old 09-27-2013, 07:43 PM
Maertz
2009 JK Wrangler
ebay. i got 2 viair 444c's and a 5 gallon tank for 320... It airs all 4 35s from 8 psi to 20 in about 2 minutes and half of that is walking between tires...
Maertz is offline
