BIG BLUE's "Kentucky Blue" JKU BUILD THREAD - Page 12 - JeepForum.com
post #166 of 1032 Old 12-13-2012, 09:16 PM
BamaJeepman21
Which means you're going to get 37's and you can sell me your 35's for a steal...right?
Are you going to install the lift yourself?
Looks to me like that shocks are going to be way too long. There's no way you can have a shock that works with 4"-6" lift. Did you order them by compressed and extended length?
-Jack
BamaJeepman21 is offline
post #167 of 1032 Old 12-13-2012, 09:44 PM
jbriones
what kind of track bars and control arms are your looking into? Brake lines?
jbriones is offline
post #168 of 1032 Old 12-13-2012, 10:13 PM
Heath
2014 JK Wrangler
Originally Posted by BigBlue7
I'm looking for opinions on lift kits. I am running 35s and factory fenders. I want something that will work well with this setup, and that will also be good for when I upgrade to 37s and the PSC Tube Fenders.
I have been looking at the 2.5 and 3.5 Rock Krawler Mid Arm Kits. But not sure which one to go with. Right now I'm leaning towards the 3.5 flex, since ill have to replace the front driveshaft either way. Any expensive drawbacks when it comes to the 3.5" system?
Please advise y'all!
Do NOT get any lit that uses Heim joints anywhere. Get something with a true encapsulated flex joint like a John y Joint or a Duroflex.
Have you looked at the Metalcloak arms? They are super nice.
I went with them on my new rig. I have to say I like the Duroflex better than the JJ for a couple of reasons. Just have to see how well they hold up. I don't think it will be an issue though.
2013 JKU Rubicon
Heath is offline
post #169 of 1032 Old 12-13-2012, 10:17 PM
Walle
Soccer Mom and Jeep Hater
Walle's Avatar
Congrats!!! Can't wait to see what it looks like! Great choice on the shocks and glad to see you bought good coil retainers!
Just a FYI...
Do you know what the front coils of your lift measure? The Currie front coils measure 22.5 without any weight on them. I'm running those same shocks on the Currie 4", and the shocks at full axle drop will allow the coils to unseat. I am running Antirock front and rear, which helps prevent that.
Just food for thought and something you may want to keep an eye out for.
| 2014 JKOTY |
Walle is offline
post #170 of 1032 Old 12-13-2012, 11:43 PM
Heath
2014 JK Wrangler
Originally Posted by Gregg79CJ7304
I'm going with OME, but I'm going to paint or powder coat the shocks black.
Let me know how that powdercoating oven does on those nitrogen and oil filled shocks with their composite internals and all!
2013 JKU Rubicon
Heath is offline
post #171 of 1032 Old 12-13-2012, 11:46 PM
Heath
2014 JK Wrangler
I thought about that as well. OME is supposed to have a really nice ride for a DD. Not a huge fan of having a stiff ride, but! I read that having a stiffer ride will help with the leaning while going through turns. Needless to say, I am a fan of keeping the Jeep on all fours.
It should turn out fine, the personal touches are what makes it yours!
Stiff ride, for leaning? No.
Get a raised AXLE end rear track bar mount and a Poly Performance front trackbar mount and drag link flip for proper geometry. Raising the trackbars with the lift will raise the roll center back like stock and your rig will drive fine. Don't ever buy shocks to fix a sway issue.
2013 JKU Rubicon
Heath is offline
post #172 of 1032 Old 12-14-2012, 07:03 AM Thread Starter
BigBlue7
2010 JK Wrangler
There's no sway issue. But yes, stiff vs soft will help. However your correct that the raised track bars are the key.
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #173 of 1032 Old 12-14-2012, 07:05 AM Thread Starter
BigBlue7
2010 JK Wrangler
We will talk. I have to dump money into drive shafts and gears before I just up to 37s. Oh, and those shox are perfect for this lift. The kit gives way more lift than what RK advertises. Its designed to give you 3.5" if you have a fully outfitted JKU (full skids, bumpers, winch, all steel corners, etc). The shox are very close to the recommended compressed/extended lengths. Installing myself with help.
BigBlue7 is offline
post #174 of 1032 Old 12-14-2012, 07:10 AM Thread Starter
BigBlue7
2010 JK Wrangler
Track bars and all 8 control arms are included in the X Factor, which is why I went with it. Brake lines are included as well. Same for the coil wedges. Bumpstops are free until Christmas through Marcus! I am good to go!
BigBlue7 is offline
post #175 of 1032 Old 12-14-2012, 07:15 AM Thread Starter
BigBlue7
2010 JK Wrangler
Just a FYI...
Thanks, sir! Im not sure, but I'll find out. I'd rather have longer shocks, thus not to limit my vertical travel. Were you using coil retainers before the antirock? Last time I checked you were in the swapping process, but I'm curious to find out once your finished.
Again thanks for your help Walle!
BigBlue7 is offline
post #176 of 1032 Old 12-14-2012, 07:26 AM
BamaJeepman21
Nice.
But then again I have to dump money too before I go to 35's... Is Daniel going to help you? He said he'd help me put mine on and I'm thinking if we have enough tools and help we can knock out 2 Jeeps in one weekend.
-Jack
post #177 of 1032 Old 12-14-2012, 07:34 AM
Walle
Walle's Avatar
I agree with having longer shocks not to limit your travel. It helps prevent damage to the shocks, but you have to just make sure you set your lift up for those shocks - retainers, bump stumps, blah, blah, blah. I was using coil retainers - RK retainers. I would recommend to anyone to use another brand just because the RK ones don't secure the coil as good as other ones, but that is just my opinion.
Actually I just got my Jeep back late last night. I did the axle swap and lift swap myself, but then it sat for a couple weeks waiting new ball joints. My buddy did the ball joint install (Synergy Ball Joints), and I got her back yesterday. I owe some people (Spyder6) some pictures, but I am leaving to NC today. The pics will come next week. Anyways...I enjoy my new lift a lot, so far. I only drove it from the shop to get and alignment and back to the house. What a difference in the gears! I think I am gonna like the 5.13s.
You will love those Fox shocks! The ride is amazing on and off the road. I was reading somewhere the other day where one guy dropped the pressure to 125 PSI for DD, and then he would charge it up to 225 PSI for wheeling. I think he had the setup at his house for that. That is gonna bug me - can't remember where I read that. I am running the 200 PSI, which comes standard with those shocks, and I have no complaints.
I am excited to see your write-ups and your progress! I bet you are anxious waiting on the parts to get there! Good luck and enjoy yourself!
Oh, and get the 37s!
| 2014 JKOTY |
Walle is offline
post #178 of 1032 Old 12-14-2012, 07:36 AM
jbriones
Good deal. Very nice
jbriones is offline
post #179 of 1032 Old 12-14-2012, 07:44 AM Thread Starter
BigBlue7
2010 JK Wrangler
Nice.
Haven't talked to him about it yet. Might be able to, but if all goes as planed Dennis is helping me on Jan 5-6 in his garage. Sat and Sunday if needed.
BigBlue7 is offline
post #180 of 1032 Old 12-14-2012, 07:48 AM Thread Starter
BigBlue7
2010 JK Wrangler
That sucks. You got all that work done yourself and then had to wait on shipping! That's tough. I was thinking about going to 5.38 yukons for 37s. Let me know how how you feel about the 5.13s after you drive it some more. Really that's why I haven't regeared yet, since I thought I'd have change them again for 36s.
Yeah I heard the RKs were crap. 5 extra dollars gets your the teraflexs front and rear.
Not sure if we're talking about the same fox shocks. These are the ones that are $114 ea on Northridge4x4. 2.0s 4-6" IFPs. Can you adjust these, I don't remember reading that for this model? Anyhow, when they will be for sale when I get larger tires. At that time I plan to go with the RDDs!
BigBlue7 is offline
