Bestop Supertop problems - Page 5 - JeepForum.com
post #61 of 84 Old 07-16-2010, 10:00 PM
Hollywood1971
Mike, I don't want to answer for Geoff but thought I should throw this out there for you. If you contact Bestop customer service they can send you a small parts bag that will include those screws.
Or here is another option: when installing my Supertop I had one bolt head break off. I contacted them and they couldn't just send the single bolt and instead sent the whole small parts bag. If you can identify which screw type it was to secure the header (I don't have my instructions and just remember that it was a lot of them) I'd be happy to send you a handful to hopefully cover any that you might strip out. PM me if you want to take me up on it.
CURRENT - 2012 2-door Rubicon, Rock Krawler 2.5 Max Travel, ATX 181 with 35" Nitto Trail Grapplers
DECEASED - 2008 2-door
Hollywood1971 is offline
post #62 of 84 Old 07-18-2010, 06:46 PM
KJNewbs
1983 CJ7
Yikes - this is scarey...I just bought a 2010 2dr with factory hard top (I wanted the dual top but they 'couldnt find one for me with all of the other options I wanted - and the saleman made it sound so easy to just get a soft top afterwards for 'like 300 bucks'). I've been researching all day and realize that the factory top is like 14hundred and has a 30 page install guide. I was looking at the Trektop, but now i'm thinking that sucks? Damn - what to do?
KJNewbs is offline
post #63 of 84 Old 07-18-2010, 07:46 PM
Coppage
2009 JK Wrangler
Our issues have been with the Bestop Supertop not the trek top. I've seen a few 4dr JKs with Trek tops and they look nice. I also looked at the install instructions for the Trek top. I appears the the header for the Trek screws on which may prevent the issues I'm having with the clamp on design. I recommend joining a local club and seeing if anyone has a Trek top installed that you could look at up close.
Coppage is offline
post #64 of 84 Old 07-21-2010, 08:21 AM
08JKSAHARAUN
This season I installed a Supertop on our 08 Unlimited Sahara. After reading all these posts, I tend to agree with the majority that the install is challenging. Be patient and definately do it on a warm day and with a buddy or two.
I have noticed the same header "tightness" issue and front corner issue. For the header tightness, I think I improved the tightness by making sure the pins on the bow mount bracket are in the last hole (towards the back of the Jeep). I still seem to share the "loose" fitting on the front sides - for at least the first three inches from the header - where you hear and feel air coming through. I think in part the plastic channel should be extend further to the front of the vehicle. This may be an overall design issue. I haven't discovered a fix for this just yet.
Going on-line today at BestTop, I noticed they have revised the kit back in May to incorporate a Header Knob bracket and plate vs the clip that came with my top in April / early May (must have just missed the update). I think this will greatly solve any header tightness issue across the front (and will save me the time and expense of adding a gasket on my own).
I'll be contacting Besttop to hopefully get the new hardware.
Overall - I'm happy with the Top. I only had one other issue with the Tailgate Retainer Bar in that the rivets on one of the clips gave (they should use a larger rivet and washer to solve this problem). Besttop sent me a new bar under warranty.
Lastly - I think everyone needs to remember that any soft top for a Jeep - whether its OE or aftermarket, will have some "give and take" if you will. You will have days where you may have a little moisture and you will have many days where you hear and feel the wind and air. Afterall - this is why they make Hardtops. I view my soft top as only necessary to combat the elements (high heat sunny days and rain). When the cold and snow come around - back to the Hardtop.
08JKSAHARAUN is offline
post #65 of 84 Old 07-21-2010, 08:43 AM
McKBrew
JK Wrangler
Craigslist.
McKBrew is offline
post #66 of 84 Old 07-21-2010, 08:44 AM
jstrubberg
2009 JK Wrangler
That is a VERY interesting change! I think that knob latch and a bit of bending at the center point of my header bar would probably fix the issues I've got completely.
I don't expect my soft top to match my hard top for either noise level or security, BUT, seeing daylight above the windshield every time I catch a wind gust just isn't acceptable.
jstrubberg is offline
post #67 of 84 Old 07-21-2010, 09:03 AM
BestopTeam
Vendor
BestopTeam's Avatar
2010 JK Wrangler
You can reach the customer service team at 800-845-3567 or csbestop@bestop.com.
They did change the header from clamps to screws - clamps are more convenient, screws work better for tighter clamping.
BestopTeam is offline
post #68 of 84 Old 07-21-2010, 09:09 AM
BestopTeam
Vendor
BestopTeam's Avatar
2010 JK Wrangler
Originally Posted by Coppage View Post
Hi Geoff,
Can I request you when I email to Bestop? I originally contacted Bestop support and the reply was to contact the merchant that I purchased the top from. I contacted JC Whitney and explained my problem to them. They in turn contacted Bestop. In end result was bestop sent me the lower metal part of the header. My top is still not fixed. I can't replace the part because some of the screw heads stripped when installing, so if I take it apart I may not be able to get it back together. When I put the top up I can force the top in the channel, but once I clip in the sides the front over the driver pops up. The clamp fails to hold the header in the channel. It's almost like when I lock in the sides the header if pushed forward and out the channel.
Thanks,
Mike
I'm not opposed to you asking for me, but I gotta tell you, it's not a great idea: I work in marketing, and have no way of getting you replacement parts, etc. My job is to make you like us, and buy more stuff (how am I doing?)
But you should contact customer support directly - otherwise it ends up like that old game of "telephone." I'd call instead of sending email - we've been known to misinterpret email from time to time. We do that on the phone too, but at least you can start yelling at us.
post #69 of 84 Old 07-21-2010, 08:50 PM
Coppage
2009 JK Wrangler
Originally Posted by 08JKSAHARAUN View Post
Lastly - I think everyone needs to remember that any soft top for a Jeep - whether its OE or aftermarket, will have some "give and take" if you will. You will have days where you may have a little moisture and you will have many days where you hear and feel the wind and air...
Dude, I have to wear safety glasses to drive in the rain. I'm going to try calling Bestop and seeing is they can send me the new screw on clamp. That should hep out a lot.
...I think I improved the tightness by making sure the pins on the bow mount bracket are in the last hole (towards the back of the Jeep)."
I'm not sure what you mean, can you post a picture?
Thanks.
Coppage is offline
post #70 of 84 Old 07-22-2010, 06:30 PM
Coppage
2009 JK Wrangler
I called Bestop support today and explained my problem with the front edge not staying in the channel. The lady I talked with mentioned the new screw down kit that replaces the weak clamps and is having a set sent to me. It'll take about three weeks since they are out of stock. Hopefully I'll have a good update for everyone then.
Thanks
Coppage is offline
post #71 of 84 Old 07-23-2010, 07:10 AM
jstrubberg
2009 JK Wrangler
Same here. In the meantime, I'm going to put together a bending caul and flex the header bar a bit so it follows the top of the windshield more closely.
post #72 of 84 Old 07-23-2010, 08:04 AM
Coppage
2009 JK Wrangler
Can you take a before and after pic? Can you post a pic of the bending caul as well? The screw down kit will help but you right that if the header more closely followed the channel it would help. Thanks
Coppage is offline
post #73 of 84 Old 07-23-2010, 08:26 AM
jstrubberg
2009 JK Wrangler
Yup, lots o' pics. I plan to cut a curve along a 2x4, then use a pair of pipe clamps and pads to provide the pull. We will see what happens.
post #74 of 84 Old 07-24-2010, 06:51 AM
08JKSAHARAUN
Update from earlier this week:
On our trip to the shore for this weekend, once reasonable highway speeds are hit, I see daylight and feel the breeze along the header.
Before I left on my trip, I did call Bestop and the knob hold downs are on their way.
Once I'm back at home, I'll post the pic on the bow bracket setting as well.
post #75 of 84 Old 07-28-2010, 07:32 AM
jstrubberg
2009 JK Wrangler
Got the knob latches yesterday and installed them last night. The header bar is still the wrong shape, but you can apply enough torque with the knob latches to knock down about 80 percent of the wind noise.
Still looking for time to set up a bending caul and fix the problem. I really, really hate paying this kind of money for a product that does not fit the vehicle I ordered it for!
bestop , bestop supertop , JK Wrangler , supertop , wrangler
YJ's with Bestop Supertop MikeB78 Jeep Picture Requests 12 07-24-2013 05:48 PM
Bestop Supertop jeepaholic91 Jeep Picture Requests 4 07-14-2009 04:58 PM
BesTop SuperTop. INCA Jeep Picture Requests 6 05-24-2009 12:54 PM
Bestop Supertop, Tinted or Not surfj9009 Jeep Picture Requests 0 10-12-2008 04:48 PM
TJs with the Bestop Supertop Jon_H Jeep Picture Requests 6 10-23-2006 07:43 PM
