Best tool for cutting pinch seam? - Page 2 - JeepForum.com
post #16 of 26 Old 09-05-2012, 02:55 PM
conifers4
Could you use a roto-zip with a metal wheel? That's what I plan to attempt.
AMERICA IS FULL
conifers4 is offline
post #17 of 26 Old 09-05-2012, 05:27 PM
HappyTrails
Sawzall X2. 20 seconds and you're back to sipping a cold one.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #18 of 26 Old 09-05-2012, 08:20 PM
Coppage
2009 JK Wrangler
Why are you cutting your pinch seam?
Coppage is offline
post #19 of 26 Old 09-05-2012, 08:40 PM
HappyTrails
Probably for larger tires to fit in the wheel wells. When I put 37's on mine, I couldn't slide a finger between the rock rails and the tires. So I trimmed the rock rails about 3" and the rear pinch seam about 2.5". Tires stuff into the wheel wells just fine now.
post #20 of 26 Old 09-05-2012, 08:42 PM Thread Starter
EarsOfLeather
Sticks out too far. Don't want to be hitting a bump in the road and slammin' that metal triangle into my nice new Duratracs. Used an angle grinder and it came off pretty easy.
Interestingly, my 35 X 12.5" tires fit real nice under my jeep with stock suspension, stock fenders, stock everything. No rubbing, no bump stops needed, lift, no nothin'.
The 4.75" BS on my wheels helped I'm sure, but still, I figured it'd rub at least a LITTLE bit from all the panicky posts I see on here all the time. Grow a pair and throw 'em under there! They fit fine. Obviously I'm not dumb enough to try articulating offroad or anything until I get my lift finished obviously.
00 White XJ
32" DuraTracs
3.5" OME lift (HD coils and leafs)
Currie HD track bar & RE quick discos
OME HD steering stabilizer
IRO adjustable UCAs and LCAs
AIRAID intake, 60" safari rack
EarsOfLeather is offline
post #21 of 26 Old 09-06-2012, 07:29 AM
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Plasma cutter. If you're going to be cutting much metal (and if you're jeeping, you will) it is a worthy investment. I got mine from a company in NH that makes them in house, only $389. It'll blow through 1/2" steel like it's not even there.
Linky:
http://plasmametalcutter.com/product...m49lfcdnvc7qo5
Need parts? Need product advice? Contact Jason at
ArticRubi is offline
post #22 of 26 Old 09-06-2012, 07:38 AM
paul84043
Chop saki kung-fu chop....
Stare at it threateningly and see if it will just fall off?
One swing of Grabthars Hammer...
Cut a notch in your tires so that it won't touch them.
Just a few more options...
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #23 of 26 Old 09-06-2012, 09:31 AM
Silverton34
Didn't I read where some people simply use a BFH and bend the pinch seam over?
Silverton34 is offline
post #24 of 26 Old 09-06-2012, 09:38 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Linky:
Although I love me some plasma cutter - I would not reach for that tool on the pinch seam. using a cutoff wheel on the die grinder darkened the paint about 1/16" - an easy hit with primer and spray touch up fixed it. The sawsall would probably have done even less - but the reciprocating part is a pain in my thinking.
A plasma cutter would have fried it back at least an inch AND on the backside where you CANT stop rust with spray!!
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #25 of 26 Old 09-06-2012, 10:52 AM
HappyTrails
I initially tried that, and said, "Aw, **** that!", took too much effort to barely bend it and isn't very precise. What if you miss and hit the broadside of the Jeep?
post #26 of 26 Old 09-06-2012, 12:52 PM
paul84043
Really, the sawzall even with a standard demo blade, went right through. Clean cut, no problem at all. If you used a finer tooth blade it would have been even smoother.
I put tape on to minimize side effects, but I really don't think even that was necessary.
Pinch Seam and 35s slapshot JK Wrangler Technical Forum 5 03-28-2012 08:17 AM
Pinch seam JASJ JK Wrangler Technical Forum 6 10-30-2011 08:54 PM
What Pinch Seam DAYJ JK Wrangler Technical Forum 12 08-25-2011 12:08 PM
Pinch seam question 0sevenjk JK Wrangler Technical Forum 9 01-22-2011 07:01 PM
Noob pinch seam question DANJEEPO8 JK Wrangler Technical Forum 19 02-25-2010 07:58 AM
