Best tool for cutting pinch seam? - JeepForum.com
post #1 of 26 Old 08-29-2012, 06:17 PM Thread Starter
EarsOfLeather
Hack-saw, hand grinder, sawzall (reciprocating saw)? Don't have a cutting torch. The metal looks beefy enough to make it a real project down there with a hack-saw.
00 White XJ
32" DuraTracs
3.5" OME lift (HD coils and leafs)
Currie HD track bar & RE quick discos
OME HD steering stabilizer
IRO adjustable UCAs and LCAs
AIRAID intake, 60" safari rack
EarsOfLeather is offline
post #2 of 26 Old 08-29-2012, 06:28 PM
LVCapo
2015 JK Wrangler
4.5" Angle Grinder with a cutting wheel, worked like a champ
Harbor Freight
LVCapo is offline
post #3 of 26 Old 08-29-2012, 06:42 PM Thread Starter
EarsOfLeather
Harbor Freight
Was thinkin' I'd go that route.. seems like it might be a lot of sparks in the vicinity of the fuel tank though. But I bet a sawzawl would be a pain in the butt.
00 White XJ
32" DuraTracs
post #4 of 26 Old 08-29-2012, 06:44 PM
nicholsmf
2010 JK Wrangler
Harbor Freight
Same here except the Dewalt version
2010 JK Wrangler
2010 Pariot
nicholsmf is offline
post #5 of 26 Old 08-29-2012, 06:56 PM
PatrickCJ8
1981 CJ8
4.5 angle grinders are good for sure. If the metal is not too thick air powered body saws work great. Here is an electric version at Harbor Frieght. Can't vouch for performance though.
http://www.harborfreight.com/electri...saw-65766.html
PatrickCJ8 is offline
post #6 of 26 Old 08-29-2012, 07:00 PM Thread Starter
EarsOfLeather
Thanks guys! The other thing about the angle grinder is it'd be handy to be able to drag that wheel across the cut surface a few times to smooth it out, too, which you can't do with a sawzawl.
00 White XJ
32" DuraTracs
post #7 of 26 Old 08-29-2012, 07:12 PM
paul84043
Standard off the shelf sawzall with regular demo blade went through it with no problem at all. Took 20 seconds.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #8 of 26 Old 08-29-2012, 07:12 PM
saddis
2014 JK Wrangler
I just used a sawzal and cleaned it up with a flapwheel on a grinder. A little silicone and spray paint and your done.
Steven
saddis is offline
post #9 of 26 Old 08-29-2012, 07:14 PM
paul84043
post #10 of 26 Old 08-29-2012, 07:30 PM
SubAtomicGenius
2011 JK Wrangler
I used a grinder. There is body foam in there, so I wouldn't recommend a torch! Lol
SubAtomicGenius is offline
post #11 of 26 Old 08-29-2012, 08:19 PM
1222
RIP John
1222's Avatar
All of the above tools will work, some better than others, but the end result will be the same. Another good tool to use, if you have an air compressor, would be a small (2-inch) air cutoff tool. Harbor freight has them for cheap. Never ever use a torch on the body.
(2011-2016)
1222 is offline
post #12 of 26 Old 08-29-2012, 08:26 PM Thread Starter
EarsOfLeather
The other cool thing about the angle grinder option is I can use it to polish up some of this petrified wood that's laying all over my living room floor.
00 White XJ
32" DuraTracs
post #13 of 26 Old 08-29-2012, 09:25 PM
1222
RIP John
1222's Avatar
^^^ Ok, that’s definitely some hardcore tech.
(2011-2016)
1222 is offline
post #14 of 26 Old 08-30-2012, 08:08 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Harbor Freight
ditto and piece of cake.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #15 of 26 Old 08-30-2012, 08:48 AM
Vin
I used a dremel while my brother used the grinder to trim the rail. I went through a lot of cutting discs, but I was happy with the cut.
Vin is offline
Pinch Seam and 35s slapshot JK Wrangler Technical Forum 5 03-28-2012 07:17 AM
Pinch seam JASJ JK Wrangler Technical Forum 6 10-30-2011 07:54 PM
What Pinch Seam DAYJ JK Wrangler Technical Forum 12 08-25-2011 11:08 AM
Pinch seam question 0sevenjk JK Wrangler Technical Forum 9 01-22-2011 06:01 PM
Noob pinch seam question DANJEEPO8 JK Wrangler Technical Forum 19 02-25-2010 06:58 AM
