Best place to tap into wire to make hazard lights flash? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Best place to tap into wire to make hazard lights flash?
Alloy usa heavy duty ball joint kitsWe have FLASHLIGHTS! Great for your Emergency bag!TJ Wrangler 4" Rough Country Suspension Lift Kits in
Unread 12-14-2014, 01:19 AM   #1
AveCat
Installing an alarm system and am looking for the best place to tap into a wire to make the hazards flash? and what color that wire is.
Thanks!
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
Go look at my photos!
AveCat is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 05:01 PM   #2
jwmbishop
2011 JK Wrangler
Why not use the interface for the alarm you are installing. You may find the wire - but flashers AND park lights are CanBUS controlled - I tapped in wrong on a CanBUS Ford Motorhome and it was very expensive - cooked the headlight switch, dash light switch, and required a reflash...
J Wm Bishop EA, ASADE
Alcohol - because great stories never run on gasoline...
jwmbishop is offline   Reply With Quote Quick reply to this message
Unread 12-14-2014, 07:36 PM   #3
AveCat
What do you mean by, use the interface?
Unread 12-15-2014, 09:34 AM   #4
jwmbishop
2011 JK Wrangler
Alarm makers also make a CanBUS interface unit that plugs in line to the computer wiring harness - and you wire the alarm to it rather than to the individual wires - interfacing the alarm with the CanBUS has the effect of the alarm telling the CanBUS to light the light - rather than supplying the 12v output from the alarm into the single wire... the interface for the JK is around 65.00 - as quoted in my bid to have a complete (remote start, 2 stage proximity, g-force and hood/door tamper) package installed.
Google "CanBUS interface for ______ alarm" (which alarm are you using?).
Unread 12-15-2014, 05:00 PM   #5
AveCat
You rock!
It's a viper.
Unread 12-15-2014, 05:05 PM   #6
AveCat
One issue is that I don't have the oem door locks.
Unread 12-16-2014, 09:31 AM   #7
jwmbishop
2011 JK Wrangler
I THINK you then just pair the lock trigger wires to the non oem harness rather than run through the interface with em... I would have to test it out (alarm unit voltage out when lock unlock, and voltage required for cycle). Some locks are three wire (G, L and U), some (mostly European) are two - G and cycle (two wire are distinctive - operating one lock operates em all).
I wont be doing my alarm til March... I was looking at the viper - my local alarm and trim guy quoted me a generic brand with all the same features, installed for about 100 more than what I would pay for just the viper and have to do the install myself. It's like my hearing aids - I wear Audibels but the same company makes Starkey which is 60% the cost of the Audibels (BUT I got the Audibels for the price of the starkeys - frequent flyer!) - the alarm he is using comes off the same line as the viper - just not branded and advertised... and he's going to co-ordinate with my work (am decking the back seat in and adding inverter, heat exchanger, water tank and refer along with locking side boxes made for the fenders and a removable headache wall) so it will go in phases.
