Best option to replace/fix a bent rear lower control arm - JeepForum.com
post #1 of 29 Old 04-05-2013, 05:40 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
During rock crawling in Moab I had bent rear lower control arm (I have a stock suspension).
I am sure Jeep OEM part is quite expensive. It has a slight bent, so is this safe or okay to drive as is, or what affect will it have?
What would be the best replacement option, in terms of price and stronger lower control arm? Of course, I would buy a pair.
Bent left control arm.
Right side normal.
2009 JK Rubicon
Shrockworks Mid-width Bumper, Warn 9.5Ti Winch; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - 4/2006, 5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - 8/2007
Rubicon - 9/2008
Thunderstrike is offline
post #2 of 29 Old 04-05-2013, 05:46 PM
SoK66
2009 JK Wrangler
Many take offs available out there from rig builds that are on their way to the scrap yard or dumpster. Just post a classified.
SoK66 is offline
post #3 of 29 Old 04-05-2013, 06:05 PM
SubAtomicGenius
2011 JK Wrangler
Personally, I'd go with a set of aftermarket.
However, like most Jeep JK enthusiasts, I've got a set of stock ones in the garage, too. Lots of people have stock take-offs, post a classified or send me money for shipping.
SubAtomicGenius is offline
post #4 of 29 Old 04-05-2013, 06:08 PM
ncb
Looks like Quadratec sells the stock arm for $34.99.
ncb is offline
post #5 of 29 Old 04-05-2013, 06:28 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Thank you, ncb. $34.99 stock replacement is very tempting. It's either this one, or a set of Synergy Suspension Rear Lower High Clearance Fixed Length Control Arms for $199. Synergy is bent for extra clearance. Anyone has experience with Synergy product?
http://www.quadratec.com/products/16315_6513_07.htm
2009 JK Rubicon
Ouray - 8/2007
Rubicon - 9/2008
post #6 of 29 Old 04-05-2013, 06:31 PM
ncb
That arm is .5" longer than stock. It will change the driveshaft angle. It's meant for a lifted rig where you would also run adjustable uppers.
ncb is offline
post #7 of 29 Old 04-05-2013, 06:32 PM
ncb
Most Jeep shops have piles of control arms you can get for cheap or free.
ncb is offline
post #8 of 29 Old 04-28-2013, 12:22 AM
Perkalater79
Hi. I just discovered the same thing on my rubicon today on the trail. I don't know if it happened today or some other time.
I will undoubtedly replace it as some point, but is it necessary? Does it cause any harm or risk anything?
Perkalater79 is offline
post #9 of 29 Old 04-28-2013, 07:21 AM
JIMBOX
Yes, it's necessary-
That small bend, puts a new structural STRESS on everything attached to that axle, and will cause undue wear/failure, ie-bushings/welds/shocks-etc, at some critical time-
Replaceit-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #10 of 29 Old 04-28-2013, 07:23 AM
Perkalater79
Bummer. Not what I wanted to spend money on the jeep .
post #11 of 29 Old 04-28-2013, 07:31 AM
Perkalater79
What if mine where less bent than the one in the picture? :/
post #12 of 29 Old 04-28-2013, 07:48 AM
JIMBOX
What if your parachute has a small tear in the rip cord ??
Is it worth the CHANCE ?
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #13 of 29 Old 04-28-2013, 08:11 AM
JTPhoto
JTPhoto's Avatar
Replace with stock part new or used ASAP. You can do your research later and and find the the best aftermarket product for your application.
For $34.99 I wouldn't think twice.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, D44HD/J8 w/ OX locker and RCVs, 37x12.50x17 Pitbull Rockers on ProComp 2635 Predator Alloys, AEV Prem Bumper, Smitty X2O 12K ETC..
JTPhoto is offline
post #14 of 29 Old 04-28-2013, 04:36 PM
Perkalater79
Ok. Thanks for the tip. Y'all sound pretty adamant about getting it fixed. I actually didn't think it would do any harm as is.
Here's mine. The passenger one is the bent one. You can see I hit the linkage pretty good too. I really have no idea how long it's been.
post #15 of 29 Old 05-07-2013, 10:47 PM
Perkalater79
So here are a couple other pics. I also took several measurements between the axle, suspension linkages, control arm bolts trying to determine if there was any measurable difference in the effective length of my control arm ad a result of the bend. Results: nothing!
I used a tap measure and took 3-4 identical measurements on each side. If the bend were to cause any stress, wouldn't it be a result of slightly different axle position as a result of a shortened control arm?
What's else might cause premature wear or extra stress? And what other components should I check?
