Best JK 2.5" lift while keeping stock driving as much as possible? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Best JK 2.5" lift while keeping stock driving as much as possible?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!
Unread 10-28-2010, 07:56 AM   #1
asere22
Hi Jeep forum members,
I need some ideas as to what is the best 2.5" JK lift (planning to add 35's). Would like to keep the jeep stock as much as possible and don't want to compromise driving quality. Money is not an issue I want quality parts but nothing too extreme since I'm not going to do any hardcore offroading.
asere22 is offline   Reply With Quote
Unread 10-28-2010, 08:10 AM   #2
jsebastian
2010 JK Wrangler
I put in a 2.5" Teraflex Budget Boost. It was the most cost effective way to raise the Jeep in order to fit 35" tires. To my surprise, the lift and the tires actually make the ride feel a lot better than stock; softer and smoother on the road. If money is not an issue, I'm sure someone can chime in with other suggestions. But if you don't plan on doing any extreme off-roading, then why not save some cash or spend it on other mods? Also take into consideration how much additional weight you will put on the Jeep; i.e. steel bumpers, winch, tire carrier, etc.
John
http://www.fuelly.com/driver/jsebastian/wrangler
jsebastian is offline   Reply With Quote
Unread 10-28-2010, 09:51 AM   #3
rlj
I went with the Rough Country 2.5" suspension lift. Running BFG 33's. I agree with the statement above that the lifted ride is better than stock. Noticed the difference immediately.
Link to the kit, Jeep JK Suspension Lift
They also sell an entry level kit (spacer) for a little less. Not sure if this kit would provide a better ride or not.
Close up pic of lifted JK:
"The problem with socialism is that eventually, you run out of other people's money."
2011 Jeep Grand Cherokee Overland
2007 Jeep Wrangler Sahara Unlimited
3.25" Rough Country lift
Nitto Trail grapplers 35-12.50R 17
AEV Pintler 17x9 Silver Wheels
AirAid CAI
Superchips @ 93 Tune
and a bunch of other stuff......
rlj is offline   Reply With Quote
Unread 10-28-2010, 10:06 AM   #4
Hilldweller
Rock Krawler 2.5" with Bilstein shocks.
But then you really should wheel it afterwords.
Safety fast, Bill
I have never been lost, but I will admit to being confused for several weeks.
I was happy in the midst of dangers and inconveniences.
Daniel Boone
2011 Power Wagon: When only the fastest-depreciating, least reliable, fuel-thirstiest, oversized land yacht will do.
Hilldweller is offline   Reply With Quote
Unread 10-28-2010, 10:29 AM   #5
rlj
Hey Bill, how did my old springs work for you?
AirAid CAI
Unread 10-28-2010, 10:39 AM   #6
Hilldweller
Perfect ride, thanks.
I put a Teraflex 2.5" BB with shocks on top of them after continuing to bump my arse on departures and a few tricky high-centers.
I was going to do a full spring lift but I liked the spring rate of the JKU springs so much I was afraid to mess with it.
The Jeep rides great with this weight and combo.
Safety fast, Bill
Daniel Boone
Unread 10-28-2010, 10:59 AM   #7
LovinFirstJeep
X2
I started off with the RC 2.5 coil kit. about a month ago i bought a Rock Krawler kit. way better then the RC kit. much smoother ride, and barley any sag.
LovinFirstJeep is offline   Reply With Quote
Unread 10-29-2010, 09:42 AM   #8
merlin4979
If money is not as much of an object, and you want the best ride, then I'd say that you're definitely better off getting a coil lift instead of a budget boost. You'll have less sag later on if you decide to go with aftermarket bumpers and whatnot. The Teraflex 2.5 coil lift with shocks, or the RK lift with Bilsteins, or the OME kit all seem to be very good setups with great results from everyone running them.
Good luck though, whichever way you go. And make sure you post some pics when you're done!
Or...again with the "money is not an issue" thought, you could also just go with something like the 2.5 Teraflex Long Arm setup!
merlin4979 is offline   Reply With Quote
Unread 10-29-2010, 10:18 AM   #9
Hilldweller
Ditto that.
The only reason that I run a BB is because I was given those springs, the stiffest, to replace my OE springs, the second softest. In addition to bumpers and winch, I also pull a trailer.
I also believe that the JKs all come undersprung and underdamped in OE trim. A little bit of washboard taxes them hysterical performance.
Safety fast, Bill
Daniel Boone
Unread 10-29-2010, 07:32 PM   #10
04 RUBI
2009 JK Wrangler
Teraflex leveling kit, flat fenders, hammer to the pinch seam.
Thats what I did to fit 35" mtr/k. Cheap and efficient. Doesn't sound Hollywood, but it works. Gives me time to buy more skids and axle reinforcement before my stock Rubi goodies go wrong.
04 RUBI is offline   Reply With Quote
Unread 10-30-2010, 07:25 AM   #11
thedirtman
thedirtman's Avatar
You don't need to run a lift to go with 35's, Rims with proper backspacing and a pinch seam trim are all that is needed. But if you must ome light duty springs and nitro shocks are a very nice set up. I got the hd springs and got 4" of lift from them and I have heavy bumpers. Also flat fenders will give you the look of a lift while keeping the suspension stock and increasing the room for bigger tires. Fill in your profile and people can give you better info on customizing your rig. Depending on your set up you might find 35's a poor choice for drivability.
If you learned something new today, you had a good day.
thedirtman is offline   Reply With Quote
Unread 10-30-2010, 09:42 AM   #12
RockyClymer
RockyClymer's Avatar
I suggest the OME coil lift and nitroshocks - great ride! I got over 3" from the HD springs and Dave at Northridge 4x4 will set you up with a good price and plenty of help.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline   Reply With Quote
Unread 10-30-2010, 11:33 AM   #13
doliss
2009 JK Wrangler
If you don't want to change the stock feel and driving of the jeep then you'll want to change as little as possible. Don't get any lift that changes the shocks and/or springs. I added a rough country 2.5 budget boost and I love the results. This particular kit actually adds a bit more in the front to level out the jeep in the process of the lift.
doliss is offline   Reply With Quote
Unread 10-30-2010, 11:43 AM   #14
RRCP08JK
2010 JK Wrangler
Only one way to go --- Old Man Emu . 2" lift gets you 2.5" - 3". I have not done it yet, buyt it's on my short list of things to do.
"It is the spirit of men who follow and of the man who leads that gains the victory" ~ George S. Patton
RRCP08JK is offline   Reply With Quote
Unread 11-01-2010, 02:34 PM   #15
yoda13
Force Wheeler
yoda13's Avatar
another vote for the OME...I love my new setup...my old was nice too, but this gave me more lift and even better ride than I had before, and I thought my Rusty's was much better than stock...at least in my opinion...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat
forum...
yoda13 is offline   Reply With Quote
2-1/2" lift , 2.5" lift , best ride , closest to stock , JK Wrangler , review , wrangler
