Best "hidden" amp location? - JeepForum.com
post #1 of 5 Old 01-06-2009, 09:22 AM Thread Starter
tweba99
tweba99's Avatar
I am about to be installing an aftermarket amp, speakers, head unit and subwoofer and I plan to make the subwoofer box as invisible as possible but I am torn on where to put the amp. The amp will fit inside the "trunk" of the JK but as we all know that is not secure at all (which can be changed) and there would be no ventalation for the amp. I was thinking under the driver seat but I figured it might be to visible when the rear doors are off. Has anybody installed an amp in the trunk and put a vent there so the amp can breath. I know the muffler is right below that area too, which might cause problems. Let me know your thoughts.
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline
post #2 of 5 Old 01-06-2009, 09:31 AM
SaharaBlackNo1
How big is your amp? If it's the PDX5 or a similiar sized amp it can go in the stock location under the steering wheel.
If you wheel, etc you probably don't want it under the front seat as there's a decent chance it could get wet.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on...
SaharaBlackNo1 is offline
post #3 of 5 Old 01-06-2009, 09:48 AM Thread Starter
tweba99
tweba99's Avatar
http://www.crutchfield.com/p_500MRPM...00.html?tp=115
It is approximately 10x10 so that location would not work. If I mount it under the seat or in the "trunk", I plan elevate it so wetness wouldn't be a problem and I like the rocks and not the mud anyway.
tweba99 is offline
post #4 of 5 Old 01-06-2009, 10:22 AM
iagainsti
Under either front seat elevated would be best.
iagainsti is offline
post #5 of 5 Old 01-06-2009, 11:35 AM Thread Starter
tweba99
tweba99's Avatar
I just realized what amp you were talking about (Alpine PDX5). I was actually looking into that amp before I decided to replace my head unit. Where under the steering wheel does the stock amp mount because that would be a great place for my amp if it would fit (since it is the same size as the PDX5). Thanks!
tweba99 is offline
Dealer says "dirty throttle body" and needs "to flush/clean the injectors"..... WheelinTJ2004 TJ Wrangler Technical Forum 18 05-17-2010 11:54 AM
a "new" TJ secret.... hidden storage. LoneJeeper TJ Wrangler Technical Forum 20 08-29-2005 12:07 PM
Hidden Hitch 2" hawleyrw TJ Wrangler Technical Forum 26 06-13-2005 05:12 PM
Can't locate "Switched" and "unswitched" wire leads behind the glove box on 04 TJ Sparty TJ Wrangler Technical Forum 4 04-03-2004 01:24 PM
