Best Differential Gear Oil? - JeepForum.com
post #1 of 13 Old 10-08-2010, 08:47 PM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Changing my Stock Differential Covers to Rancho Covers... what's the best Differential Oil to use? Is there a synthetic available?
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #2 of 13 Old 10-08-2010, 08:51 PM
MAJTodd
I use Amsoil products in my Jeep and Corvette from front to rear.
First Jeep the govt. hasn't owned.
Others: C6 Vette and Ducati bike.
MAJTodd is offline
post #3 of 13 Old 10-08-2010, 09:28 PM
Swagger
Lucas!
Swagger is offline
post #4 of 13 Old 10-08-2010, 09:28 PM
armedsks
2009 JK Wrangler
I got amsoil in my rears also. 75-90 in the fron and 75-140 in the rear. I also have mobil1 on my shelf.
armedsks is offline
post #5 of 13 Old 10-08-2010, 09:48 PM
NorthRiver
I use Mobil 1 or Royal Purple.
NorthRiver is offline
post #6 of 13 Old 10-09-2010, 03:17 AM
montero1
2010 JK Wrangler
Rear Oil
You won't find a better than gear oil than Amsoil "Severe Gear". Redline makes good gear oil as well, those would be the only two I'd use, and unless you constantly submerge the axles in water, would be good for 75k. If you chose to go with Amsoil, I can get it for you @ cost.
montero1 is offline
post #7 of 13 Old 10-09-2010, 07:38 AM
JohnRodriguez
Richmond synthetic 75w140
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #8 of 13 Old 10-09-2010, 07:44 AM
JeffinWesternWA
2010 JK Wrangler
CLEAN is best, ....I have had great luck over the years with REDLINE fluids in quieting, smoothing shift problems, reducing clutch chatter, etc., for a full synthetic. It's priced less than the botique oils and is usually available at retail jobberts/chain stores in many areas of the country...follow manufacture specs for weight and GL class though!
JeffinWesternWA
JeffinWesternWA is offline
post #9 of 13 Old 10-09-2010, 04:55 PM Thread Starter
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Royal Purple 75W-90 $20 a Quart!
PSYCH0 is offline
post #10 of 13 Old 10-09-2010, 06:01 PM
tjkj2002
2002 KJ Liberty
For HP diffs(if your lucky enough to have them) the best is the cheapest dino gear oil(85w-140),the best protection your diff can have.It has been proven that synthetic gear oil is not the best choice for your diffs,and yes I know almost all vehicles now have it from the factory but you also have very low drain intervals.The #1 reason for synthetic gear oil use is mpg's and that is it,you will loose some mpg's with dino gear oil but your diff will be better protected.
tjkj2002 is offline
post #11 of 13 Old 10-09-2010, 07:24 PM
NorthRiver
How exactly is an inferior oil (dino) going to protect better than synthetic?
Lets see the proof.
post #12 of 13 Old 10-09-2010, 07:39 PM
Unknown303
Canola oil FTW.
Unknown303 is offline
post #13 of 13 Old 10-10-2010, 01:29 PM
boostedboxer
2010 JK Wrangler
Do we use oil with friction modifiers or not, I would guess in the Rubi you wouldn't? How about in the tranny?
boostedboxer is offline
Differential gear set question MMShaggy YJ Wrangler Technical Forum 3 11-16-2008 10:28 AM
Differential Gear Ratio ID lilngineer TJ Wrangler Technical Forum 7 11-09-2007 03:55 PM
D35 Differential Gear set MUNCHED k1llerkyle YJ Wrangler Technical Forum 6 06-04-2007 09:15 PM
Removing front differential gear pasinbuy YJ Wrangler Technical Forum 13 05-26-2007 11:17 AM
what is differential gear oil? shayfae YJ Wrangler Technical Forum 17 03-06-2005 08:33 AM
