Best Decal Remover? - JeepForum.com
post #1 of 12 Old 01-06-2010, 02:39 PM Thread Starter
krutj
2009 JK Wrangler
Best Decal Remover?
I would like to remove all the decals from my JK, anybody have a recommendation?
I also read something about drilling a weep hole in mirror mounts, any tips?
krutj is offline
post #2 of 12 Old 01-06-2010, 02:41 PM
jeepndug
1981 CJ8
decals on the paint or windows
jeepndug is offline
post #3 of 12 Old 01-06-2010, 02:44 PM
hkenny90
heat gunn or hair dryer .. hair dryer will take A LOT longer haha
hkenny90 is offline
post #4 of 12 Old 01-06-2010, 02:45 PM
USAntigoon
Retired from Forum
Just use a heat-gun on low or a hairdryer.. Then use some Goo Gone..
Drilling a weep hole... look up here...
USAntigoon is offline
post #5 of 12 Old 01-06-2010, 02:46 PM
Spank
2014 JK Wrangler
Hair dryer works fine. Only took a few minutes to take everything off. I've got a Sahara.
Spank is offline
post #6 of 12 Old 01-06-2010, 02:48 PM Thread Starter
krutj
2009 JK Wrangler
Thanks for the tip, anybody drill their mirror mounts?
krutj is offline
post #7 of 12 Old 01-06-2010, 02:54 PM
hkenny90
never heard of that whats it for??
hkenny90 is offline
post #8 of 12 Old 01-06-2010, 03:02 PM Thread Starter
krutj
2009 JK Wrangler
I would guess that in cold climates water will get in and split the mount. I was going to do this as a precaution, just want to see if somebody had a problem with this.
Thanks for the link ANTIGOON.
krutj is offline
post #9 of 12 Old 01-06-2010, 03:08 PM
mav383
2009 JK Wrangler
I've done both. for the stickers just park in the sun and it will come right off using a fingernail. then use some wd40 or tri-flo for any left over sticky. The mirror tap is to let the water drain after washing so you don't get constant dribble out of it. Use a small bit first then if you feel you need more just increase the size.
It'll Buff Out!!
mav383 is offline
post #10 of 12 Old 01-06-2010, 03:17 PM
alaskanthunder
If you have had the stickers on long. Some auto polish will do wonders and clear any remaining residue that won't be seen until under certain circumstances...i.e. water(rain), certain sunlight...blah blah.
2007 JK 2-dr X | Steel Blue | 4.10 Auto D44
alaskanthunder is offline
post #11 of 12 Old 01-06-2010, 03:20 PM
Canadian-Bear
2011 JK Wrangler
The holes are drilled to allow the water to completely drain, from the mirrors, especially when you are washing your Jeep. The soapy water has a chance to drain, without pooling and causing soap streaks on the door.
I have done this project, for both of our Jeeps, and, no matter if we hand wash, auto wash, or wand wash our Jeeps, there are no soapy streaks on our doors.
Just make sure that you take the mirrors off, unless you feel confident in your drilling with them on.
2011 CANADIAN BEAR JK
/l ,[____],
l----L-OlllllllO-
()_) ()_)-o-)_)
Canadian-Bear is offline
post #12 of 12 Old 01-09-2010, 08:20 PM
Goestopless
Most parts stores sell a rubber wheel that connects to a drill, it took me 5 minutes to remove the "X" on both sides and it won't stripp the paint as long as you keep it moving. Been using these "eraser wheels" for years now.
Goestopless is offline
Suggestions please - grime remover toomanyjeeps YJ Wrangler Technical Forum 24 10-10-2007 10:15 PM
Dealer Sticker Remover Help StevieO40oz TJ Wrangler Technical Forum 20 08-31-2007 05:51 AM
Window Scratch Remover stedwest TJ Wrangler Technical Forum 12 12-04-2006 08:39 PM
Axle RTV Remover SpitNine TJ Wrangler Technical Forum 4 08-18-2004 07:36 AM
Scratch Remover mletschin YJ Wrangler Technical Forum 4 03-17-2004 08:52 PM
