Best cb antenna mount for JK - JeepForum.com
post #1 of 21 Old 04-02-2010, 09:38 AM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
What's the best CB antenna mount for the JK? My friend has the Cooltech which I installed on his JK and looks real good and serves the purpose well but I plan on relocating the license plate on the spare tire so I can not mount the antenna on the licence plate mount.
I plan on running a tall fiberglass antenna. On my TJ I had drilled and bolted a mount right in the rear body panel but there is no way I am drilling trough my 2010 Jeep.
Are there mounts that go behind the tail lights or something? Maybe behind the spare tire... Ideas?
Black 2010 Sport JK
Black 2003 Sport TJ Gone!
Baotchi is offline
post #2 of 21 Old 04-02-2010, 09:42 AM
yoda13
Force Wheeler
yoda13's Avatar
Terraflex makes one that bolts behind the sparetire carrier...I used it for a year, no problems and it was good, now I have put an aftermarket bumper on and I do not need my stock carrier anymore, so I bought an aftermarket 3rd tail light assembly from Terraflex and it came with a mount...either way you can't go wrong...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Bilsteins, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, Delta replacement non-quadbar xenon headlamps, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, †John 3:16†
RIP Mrs. yoda13... My life is better for having had you in it and you made me a better man...I can't wait to see you again...I love you always and forever, and for all eternity
If you want to help the sport of off-roading, and protect your right to do so, please visit the
forum...
yoda13 is offline
post #3 of 21 Old 04-02-2010, 09:49 AM
PSKJEEP
i went to home depot for a 4 peice of angle iron and mounted mine to my license plate bracket. I reninforeced it with some washers on the other side so it wouldnt ripe it off. then i got a peice of sting and looped it around the screw that hold the hard top on and tied it to the cb ant so when i go 4 wheelin it doesnt go crazy. and then all you need to do it ground the ant. to the car. it cost me a total of 6 bucks. before that u mounted it to my window bracket. you know that peice that holds the window upright. dont waste your money on a bracket off line they cost to much.
PSKJEEP is offline
post #4 of 21 Old 04-02-2010, 10:00 AM
USAntigoon
Retired from Forum
The best antenna mount .. if you mean the best RF radiation and counterpoise then you need to have it mounted on the tub.. Alas a hole needs to be drilled...(no pain, no gain).. If the esthetics are what you are looking for.. Indeed there are a lot of solutions with brackets and alike..
Here is my set up.. (hole in the tub of course...)
ARR has some nice brackets which can be mounted on the spare carrier hub... However they don't do a good job for the 11 meter band.. VHF is OK
USAntigoon is offline
post #5 of 21 Old 04-02-2010, 10:24 AM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
I'm not "going for esthetics" but I'm not going to drill the tub. I had a bracket mount on my TJ and I installed a ground cable to the frame, was pretty effective too. I need something that wont bang the antenna on the hard/soft top, and something that's strong because I like running a tall antenna (yeah mostly for looks).
I'll keep looking until I find the perfect mount. I might as well end up making it myself.
Black 2010 Sport JK
Baotchi is offline
post #6 of 21 Old 04-02-2010, 10:24 AM
McKBrew
JK Wrangler
I am using the teraflex mount. No issues with it.
McKBrew is offline
post #7 of 21 Old 04-02-2010, 10:43 AM
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
X2. Teraflex is the best. Additional hole drilled for a flag for on the dunes too. Uses existing spare tire mount holes so no drilling.
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread
TJ Tub Trailer
BRICKTOP2 is offline
post #8 of 21 Old 04-02-2010, 11:50 AM
DominicR
2011 JK Wrangler
I installed my Teraflex mount last weekend (it's great) and I'll be installing the rest of the cb / antenna this weekend. One question: what's the best connector to use to get the antenna on the mount and connected to the coaxial? I didn't even realize I needed one when I bought all the pieces but I don't see how the antenna will stay on if there isn't something to screw it into the mount with.
Thanks.
DominicR is offline
post #9 of 21 Old 04-02-2010, 12:13 PM
McKBrew
JK Wrangler
Thanks.
You need an antenna mounting stud like this.
fire stick antenna stud - Google Product Search
McKBrew is offline
post #10 of 21 Old 04-02-2010, 12:23 PM
DominicR
2011 JK Wrangler
Thanks for the info!
DominicR is offline
post #11 of 21 Old 04-02-2010, 12:30 PM
Hollywood1971
Have you considered the Gatemount kit from Cooltech? I just picked one up. Very solid peice of stainless steel and good instructions for mounting and running the wires through an existing hole in your tailgait.
CURRENT - 2012 2-door Rubicon, Rock Krawler 2.5 Max Travel, ATX 181 with 35" Nitto Trail Grapplers
DECEASED - 2008 2-door
Hollywood1971 is offline
post #12 of 21 Old 04-02-2010, 12:43 PM Thread Starter
Baotchi
Baotchi's Avatar
2010 JK Wrangler
Yess and that is what I had in mind when I said "make my own". There is no way I am paying 40$ for a bent piece of steel but I may just mesure and bend my own and spray paint it and drill and call it a free mount.
Black 2010 Sport JK
Baotchi is offline
post #13 of 21 Old 04-02-2010, 12:47 PM
Poor Boy
All Around Nice Guy
Poor Boy's Avatar
i had one like that, too. when i got my rockhard, i left the little bracket up there. i figgered i already had it all run, why change it?
Originally Posted by Hank Venture
It's like someone with a fever is yelling at my pants!
USN Hull number 54
Poor Boy is offline
post #14 of 21 Old 04-02-2010, 12:48 PM
McKBrew
JK Wrangler
Absolutely agree.
Were I to do it all over again, I'd buy an L bracket of some sort from Home Depot, drill a few holes in it and put it on the tire holder.
McKBrew is offline
post #15 of 21 Old 04-02-2010, 01:41 PM
NorthRiver
What kind of swr reading do you have?
Unless its better than 1.3 I'm calling BS on having to have an antenna mounted to the tub.
My antenna is mounted to a hole I drilled in the tire carrier. I'm not drilling a hole in the body chasing after that last .2 on the meter.
NorthRiver is offline
CB Antenna Mount for JK nota4re JK Wrangler Technical Forum 90 02-22-2011 06:46 PM
Opinion on Antenna Mount / Antenna HammerG26 JK Wrangler Technical Forum 22 01-04-2011 06:49 PM
CB antenna mount SoCalJK JK Wrangler Technical Forum 9 05-02-2008 01:52 PM
capping antenna mount when antenna is off Jeeper-4-Life TJ Wrangler Technical Forum 0 02-10-2007 08:57 PM
CB antenna - where to mount? Keymaster YJ Wrangler Technical Forum 7 09-01-2002 11:05 AM
