Best aftermarket clutch for a JK? - JeepForum.com
post #1 of 11 Old 01-25-2011, 03:28 PM Thread Starter
boatycall
2014 JK Wrangler
Need a new clutch due to the mud-in-the-bellhousing problem. What's a good clutch to replace the OEM, and why?
boatycall is offline
post #2 of 11 Old 01-26-2011, 02:37 AM
WSOffroad
We have done Spec II clutches in 2 JK's and they are a great upgrade over the factory clutch.
The pedal feel is extremely light, it takes very little effort to depress. The Spec clutch grabs right at the top of the pedal. It is very easy to drive, but it will take a bit of getting used to because it grabs in a totally different place than the stock one does.
Here are some highlights:
Features segmented or full faced pure Kevlar disc with steel backing. This lining features excellent drivability like the stage 1, but offers slightly longer life and higher torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Best for street, drag, pulling and autocross.
•High clamp pressure plate
•Pure Kevlar friction material
•High torque sprung hub and disc assembly
•Bearing and tool kit
PM or Call 813.361.0869
WSOffroad is offline
post #3 of 11 Old 01-27-2011, 09:10 PM Thread Starter
boatycall
2014 JK Wrangler
Anybody else? Yes, this is a shameless attempt at a bump.....
post #4 of 11 Old 01-27-2011, 09:20 PM
Warlord2
I know there are aftermarket clutches, just cant remember who made them. Back in 07-08 someone blew theirs out on just going down a trail and he replaced his with a stage 2, maybe stage 3....With the stage 3 you dont have to worry about destoying them while forging water, the dirt wont even hurt it. It could of been AGT, might try searching the other forums.....Im sure many others have upgraded by now.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #5 of 11 Old 01-28-2011, 01:04 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Found it!
http://www.jeepforum.com/forum/f96/j...ml#post8499939
Jim
JLC08JK is offline
post #6 of 11 Old 01-28-2011, 01:57 AM
Warlord2
Yup thats the one! Im going to bookmark it this time
Thanks for searching JLC08JK, I should of known it was SPEC
Warlord2 is offline
post #7 of 11 Old 01-31-2011, 03:44 PM Thread Starter
boatycall
2014 JK Wrangler
Boy, there sure is a limited number of clutches to choose from. Tons for 4.0/4.2L. So I called Spec and talked with them at length.
Because I live in Seattle where it's very damp very frequently, and it's not my daily driver, they recommended the 2+ for my application. They said the issue I'd have with the 3+ is that the high metallic content of the clutch could actually actually create a rust bond in just a couple days to the flywheel if I don't drive it regularly.
Any thoughts before I buy it?
post #8 of 11 Old 01-31-2011, 06:07 PM
Spaf
2011 JK Wrangler
For the sake of everyone else's knowledge I think you should get the 3+, park it for a week and let us know if it sticks.
Yellow Jeep Club #54
"Que scais-je?"
Spaf is offline
post #9 of 11 Old 02-01-2011, 03:39 PM Thread Starter
boatycall
2014 JK Wrangler
Ordered a 2+. After another long chat with a tech at Spec, this looked to be the best.
Also, I've talked with 3 people now, my tranny guy, a tech at Centerforce, and the tech at Spec. All 3 have said the same thing as far as the tranny vents - Leaving the ones on the top of the bellhousing open and sealing the bottom should not yield any problems. Worst case, if I know I've gotten gunk in through the top(which is very unlikely given where I go), I can drill and tap a drain hole in the bottom and hit it with compressed air to try and blow stuff out the top.
Never thought I'd have to put a bilge pump in my tranny, but that'd be next.
post #10 of 11 Old 02-01-2011, 04:37 PM
2012Rubicon
Im a fan of the Prada and Coach clutches...
wait...damnit.
Ignore me please.
[[NEW]] 2013 Jeep Wrangler "S" True Blue
[[OLD]] 2007 Jeep Wrangler.....2.5 TF Coil lift...TF Quick Disconnects...Bilstein 5100's...35's....Rancho Front/ Rear tire carrier...hi-lift jack..
2012Rubicon is offline
post #11 of 11 Old 12-02-2013, 01:18 PM
allinder
Replacement clutch for 2012 Wrangler
As of December 2nd Centerforce has no replacement for the 2012 model. Spec has one but the stage 1 is $699 without the bearing. anyone know if there is another performance aftermarket clutch for the 2012?
allinder is offline
Replacing Fan Clutch, OEM or Aftermarket toberste TJ Wrangler Technical Forum 4 12-06-2009 11:05 PM
aftermarket 3 or 5 finger clutch?? ghost183 YJ Wrangler Technical Forum 3 09-22-2009 04:35 PM
Aftermarket Clutch River Ryder YJ Wrangler Technical Forum 6 08-02-2009 07:14 PM
Aftermarket Clutch Options? rockon JK Wrangler Technical Forum 6 12-17-2008 10:23 AM
Good aftermarket clutch? daaaaaan YJ Wrangler Technical Forum 9 12-19-2006 09:34 AM
